Question about Radio Communications
Troubleshoot jabra gn9300e headset
Headset on gn9300e does not always hang up or sometimes picks up and there is no dialtone
    Sergeant:
  • 396 Answers
CLICK HERE for a great video for this model Jabra headset.
Hope this helps you out!
Posted on Oct 19, 2013
SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
Posted on Jul 10, 2007
informatica
  • 1114 Answers
SOURCE: Manual for Jabra BT150 ????
You can download the manual & get other information from the link below: http://web.jabra.com/JabraCMS/EM/EN/MainMenu/Support/WirelessHeadsets/JabraBT150/ Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 12, 2007
SOURCE: jabra bt160
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2)
For optimal performance, wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight. In general, you will get better performance when
there are no obstructions between your headset and your mobile phone. (See fig. 5)
Answer a call
Tap the answer/end button on your headset to answer a call
End a call
Tap the answer/end button to end an active call
Reject a call (Dependent on your phone supporting this feature)
Press the answer/end button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (subject to phone
settings) automatically transfer to your headset
Activate voice dialing (Dependent on your phone supporting this feature)
Tap the answer/end button. For best results, record the voice-dialing tag through
your headset. Please consult your phone’s user manual for more information about
using this feature
Redial last number (Dependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+ or –) to adjust the volume (See fig. 1)
5 How to...
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode
Make sure that the headset is on.
Press the answer/end button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT160
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’
‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’
or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 4)
3 Pair it with your phone
English
2 Turn on your headset
Press the answer/end button to turn on your headset
Press and hold the answer/end button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
Posted on Jun 16, 2008
SOURCE: unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
Posted on Jan 28, 2009
SOURCE: Need PIN code to re-connect Jabra BT350 Bluetooth Headset w/phone
I had the same problem-- i asked a verizon wireless guy and he said it's almost always four or six zero's so "0000" or "000000". Hope it works for you!
Posted on Apr 28, 2009
I cant get it to hang up after the call..thank you
The headset will not automatically hang up. There is a handset lifter that can accompany this which will enable you to hang up.
Jun 17, 2011 | Jabra GN9350e Wireless Headset
Hi I broke the tool to hang the Jabra to my ear, do you know were can I buy a new one?
If you are somewhere they will ship to you here are two places they are available.
Amazon
Ebay
While not recommending a seller there appear to be adequate supplies available.
It looks like Amazon will sell you a new headset or a spare earhook.
I didn't look past the new headset on eBay. I presume they have earhooks too.
Feb 14, 2011 | Jabra BT125 Headset
Can't get droid to pick up Jabra VBT185Z bluetooth.
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Feb 05, 2010 | Jabra BT350 Bluetooth Headset Headset
I'm trying to pair my A7010 with a Phonak icom. I can't hear a dialtone
What is the model number of icom, it seems that icom not support it.
Post comments for more info.
Thanks
Jul 14, 2009 | Jabra A7010 Bluetooth Headset
Make jabra bt 150 discoverable
within connections settings on your phone your jabra will always be discivered if you have set your bluetooth within phone to be on all the time, when you switch on head set it will be automatically picked up by your phone.hope this helps
Mar 02, 2009 | Jabra BT150 Wireless Headset
Plantronics cs55 problem
Turn on the wireless headset as soon as the HL10 lifter picks up the headset. Remember to press the call answer switch. A steady green light should come on the base and the wireless headset should have a small green blinking light on, on its side.
* Make sure your hand receiver is off the hook when using the headset. Also check that you hear a dial tone on the handset/hand receiver before turning on the headset.
Aug 04, 2008 | Plantronics PL-CS55 Wireless Headset
BT250v vibrating after picking up the call
Check Jabra website for manual.
It is a simple hold volumne button up or down when switching on or off to disable /enable it
Apr 21, 2008 | Jabra BT250 Consumer Headset
Turning on headset freezes wireless controller at times
one of the best wireless headsets on market is a jabra.its the one they sell with warhawk for £40. otherwise you can pick one up for around £20....
Apr 16, 2008 | Sony Playstation 3 (PS3) Console
Jabra BT 320s Headset
If you have no problem pairing the headset to the cellphone, maybe the issue comes from the headset that has a defect in it. These bluetooth headsets are kinda fragile, check out where you bought it if you have a warranty.
May 21, 2007 | Motorola Mobility V170
Radio Communications Logo
90 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
