Question about Garden
Does anyone know where I can get a new Transmission Drive Belt for my Concord T11-75 sit on mower?
  • 33 Answers
Don't know what the belt looks like but auto parts stores, like Carquest, have a large variety of belts and can order the odd ones. They also carry Primeline products which are for small engines, eveything from tune up kits to hard to find products, Take the old belt with you, even if it's cut in half.
Posted on Oct 22, 2013
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Yth2248 loses speed on slightest grade. new drive belt not helpful
Roy if it is the correct belt and fairly new, check your manual for belt adjustment, if it shows that there is no adjustment the pulleys may be worn out, on a lot of mowers the pulleys are ware items and changed more often to correct slipping issues. The other thing to check is the belt tensioner if equipped, it could be seized, weak or missing spring or it may even be adjustable by cable end being threaded or slotted bolt holes on tensioner arm.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Drive Pulley Replacement On Craftsman Lawn Tractor
Mower Engine Pulley Replacement Craftsman Riding Lawn Mower Repair Part...
Cub Cadet LT1045 Transmission Drive Belt Replacement
husqvarna LGT24k54 drive belt install
Apr 22, 2016 | Garden
Hydrostatic transmission
May have air in system. Purge your system. Your owner's manual tells you how.
Mar 01, 2014 | John Deere Garden
The drive belt on my Honda HRT broke. I replaced it and within a few seconds the new belt broke. I know the blades are turning, but I'm wondering if the wheel on the transmission is not turning thus the...
could be rear end is locked up you will have to get another belt try turning wheels by hand if loose see if there are broken bearings anywhere on the drive usally thats the case with the belt bearing goes out and shreds thr belt try those ideals
Jul 30, 2013 | Garden
I have a Craftsman DYS 4500 that the will not go forward or reverse. It cranks fine and the blades will engage but when you shift it in either forward or reverse nothing happens. It was working fine the...
did you have a back wheel off if so make sure the key way is in place it sits in the grove of the axle and the rim its about 1/4"x1/4" x 2" long if this is missing you will have no drive also if its a auto trans check your buypass lever hope this helps
Sep 06, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower will shift into forward and reverse gears but not engage. Mower will not run forward or backward.
either your drive belt has failed or your transmission has failed. make sure the drive belt is snug and not broken, do not do this while the engine is running. if the belt is good, then it is new transmission time. they cost more than a good used replacement mower.
May 08, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
What is the main problem with mower not wanting to move forward or reverse?
if the engine is running, but the mower is not moving generally you have a problem such as:
1) the main drive belt between the engine and transmission has failed
2) the main drive belt is good, but the hydrostatic transmission has failed.
first issue can be resolved by about anyone with a good selection of tools, a twelve pack, and a couple warm sunny hours. second issue means you are going to get a new mower unless you have an expensive mower and it is worth spending 1500 dollars to get a new transmission for it.
Mar 16, 2011 | Briggs & Stratton Garden
Ihave a craftsman 20 horsepower riding lawn mower. It starts fine but it barely moves. It stops moving. Seems to have no power, especially if on a slight slope. I had a new clutch installed, but still...
Either your drive belt is loose or your transmission is going bad.
I would have another mechanic, not the one who installed your "new clutch" take a look at it.
Sep 27, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My sears kraftsmen riding mower goes into gear but does not drive. I dont know where to start looking for this issue.
First is the rear free wheel lever in the right position? Its located in the back of the mower between the wheels. It usually pulls out to disengage transmission to be able to push it. Second...is the belt on? There is a drive belt that loops back over the transmission pulley to make it drive.
If not those two...your looking at a new, used or rebuild transaxle. www.nnyparts.com
May 29, 2010 | Garden
Husqvarna yth20k46 - When turning transmission does not work
I only had my mower 3 months and that problem started. I was told to change the drive belt, It got worse. Now the transmission will only drive the mower for about 15 min and will come to a complete stop. I have to let it sit about 30 min before the drive will work again. No solution yet but I'm looking at replacing the "sealed" drive assy. I do have a very healthy yard of St Augustine which is tough. I can mow a thinner yard a little longer.n
Apr 06, 2010 | Husqvarna Garden
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
