Question about Watches
Stauer 19093 digital works but analog does not: why and how to fix?
Hour, minute and second hands don't work, why?
Yes, there are two batteries in the 19093 (Compendium Hybrid). The first battery (CR2025) is visible as soon as you remove the back cover plate. The CR2025 controls the digital half of the watch and the back light. The second battery is underneath the circuit board that the CR2025 is connected to. There are 6 small screws that will need to be removed to lift the circuit board and gain access to the second battery. The second battery is an SR626SW.
Aug 22, 2014 | Watches
Stauer watch will not work after battery change.
I have no ideal how old your watch is nor where you had the battery changed. Ideally I would take back to whom changed the battery to see if it was a good battery. If your watch is older it may be time for an adjustment.
Contace Stauer for further assistance at link following:
http://www.stauer.com/customer_service.asp
Good luck.
Aug 21, 2010 | Bulova Watch
How do you reset the time after changing the battery in a stauer 11475 atomic watch??
Take a look at http://www.stauer.com/pdf/17468.pdf
I see that this watch gets it's time signal from Boulder, Colorado so it will only work properly in North America. Perhaps they also do models for the European market - if so I would expect them to work in the same fashion so the manual should still be relevant.
Jul 29, 2010 | Casio Wave Ceptor WVA430A-1AV Wrist Watch
I want to send my atomic stauer watch for repair. Could not set watch when newly received. Where do I send Stauer watch for repair?
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
May 12, 2010 | Fossil Watch
Removing Links from the Stauer Atomic Watch band
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove links. Rate me, please .
Apr 08, 2010 | Swiss Stauer Deep Dive Watch
Go to "Stauer.com" and at the bottom of the page you will find "customer service".
Click on this and your customer support details will appear.
Mar 20, 2010 | Bulova Watch
How to set the time on a stauer atomic watch
i have a stauer 33 watch i can not get the pin to come out so i can set the date and time it is like it is stuck or am i not doing it wright. thanks for your help
Oct 21, 2009 | Bulova Watch
Digital/analog watch... analog part doesn't run
A lot of times they hide a second battery for the analog display under the larger battery used to run the digital display. Also, the 2025 may not have a full charge.
Oct 17, 2009 | Watches
My stauer atomic signal watch won't set correct time
Aug 08, 2009 | Bulova Watch
Watch goes slow when wearing it but keeps time when not wearing it Because I started having a problem with an old reliable Acqua quartz analog watch running slow,  I replaced it with a new Timex quartz...
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Jan 07, 2009 | Watches
Watches Logo
175 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
