Question about Canon Pixma MG5220 InkJet Printer
Printing blurred or missing bar codes - Canon Pixma MG5220 InkJet Printer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
Get new ink cartridges...or u may have to clean ur slide inside the printer....
Posted on Oct 18, 2013
  • Tim Souder
    Tim Souder Oct 18, 2013
    Tried new cartridges, still the same. How do you clean the slide, what part is the slide.
  • Tim Souder
    Add a Commen Thanks
Printing barcode + overwriting RFID tag
no most bar codes will print out but it must be printed in black and wite as for changing the barcode no you have to download a special program that lets you make bar codes. not sure how though
Jun 17, 2013 | Office Equipment & Supplies
The printer will print a bar code but the reader will not read it. the reader reads the bar code from a second printer just fine
Sounds like there are some elements worn off of the printhead causing some of the bars to not be printed. To test, create a label that prints a thick black line or solid black box across the width of the label (assuming a 4" label). Any vertical white lines that show indicate elements that are not functioning.
You could also put one label above the other, lining up the barcodes and you'll probably see bars that are missing from the label that won's scan.
The only ways to correct the problem are to install a new printhead or move the barcode field on the label so that the missing elements fall in the spaces between the bars.
Hope that helps !
Apr 08, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Describe your Ricoh Aficio 1232C Error Code SC481 Problem
Defective main motor
• Image transfer belt out of position
• Belt mark blurred or absent
Right from the service manual
My best guess is belt mark blurred or missing
or image belt out of position
Feb 01, 2010 | Ricoh Aficio 2027 All-In-One Laser Printer
All of the sudden my bar codes are not fully printing. Missing some lines on the bottom. Also the numbers are not printing rel clear. Have ran this label before and no problem. Now it is all bar codes.
Try cleaning the printhead, then print the zebra test print. (see user manual) or just print a solid black box 4" wide by 1" long. If you have white vertical lines through it you may need a new printhead.
If print test is good try increasing the heat/darkness setting
Nov 09, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Incoming fax blurred and incomplete. Can the
The bar can be replaced but usually the blue lever on the right and left of the bar break and don't hold the bar correctly. UF6085001, and
UF6087001 are their part numbers, easily changed by removing one cover with phillips screwdriver.
Aug 13, 2009 | Brother MFC 1850MC Thermal Printer
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Brother dcp 150c pinting out of focus / blurry
YOu need to Do Print Test First I suspect One of the Color have Missing Dot..If the Print Quality have missing dot on The 4 colour the print our will blur ....The aligment of the print head maybe swicted ......Need to Be purge Or Replace new print Head...usually print head needed to be replace...
Nov 01, 2008 | Office Equipment & Supplies
Out of focus print
check what type of paper you are using if laser paper images bleed and look blurred use good quality injet paper.
Oct 07, 2008 | Epson Stylus C48 InkJet Printer
Blurred lines
hi, try a new ink catridge and after that no change, the head needs to be cleaned.
Jun 28, 2008 | Cannon i70 Printer
Blurred printing printer i255
Hi, check the nozzle and test , if the result not in solid color there are spaces within the color means need head cleaning after head cleaning twice test print .
Jan 23, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Canon Pixma MG5220 InkJet Printer Logo
65 people viewed this question
old marine
old marine
