Question about MicroBoards G4 Disc Publisher G4 CD/DVD Disc Publisher
The G4 ejects the disc after copying 25 tracks, the total time of recording for 26 tracks is 32 mins
Why doesn't it record to md?
You can't make a copy of a copy of a digitally recorded MiniDisc, so make sure that isn't what's happening- if so, it usually says "Din Unlock" and you can't record. I think when I record from one deck to the other digitally, I have set the recording deck to "REC", then I hit 'play' on both decks at the same time. Using the digital input, it should automatically set your track marks. You cannot make a digital copy of this MiniDisc, BUT you can make an Analog copy. Let me know if you need more info.
Dec 11, 2015 | Audio Players & Recorders
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
I have a Phillips CDR 775 2 -disc cd recorder and my track time is automatically set to 20 seconds. How do I increase this time per track? Also, I cannot seem to get the auto track to work when...
It's all in the manual...
20 seconds is the amount of digital 'silence' the machine will let pass during recording before it marks a new track. t will Pause and wait one minute for a digital signal to resume. (Page 21)
On digital copying it will automatically increment track numbers as the source advances.
For analog sources you should switch Auto Track to OFF and manually press Track as applicable. (Page 28)
Jan 21, 2011 | Philips CDR775 2-Disc CD Recorder
If I want to record let's say someone speaking for 90 min and burn 2 cd's , one 60min and the other 30 min from the one 90min recording , each one divided into tracks , how would I do this ?
If you want to burn a CD you have to make a master. For 2 cd's you have to make 2 masters, one for each recording.
The best way to handle this is to "create a song" for each speech giver and give each a name.This is because you can make only one master copy of a song before burning a Cd.
But another way is to :
1. Make a master of the first speech giver (who is on one track) and record to the Cd.
2. Make a new master of the second speech giver (on the other track) and record to Cd.
As long as you don't mind, the second mastering will overwrite the first one that you did, but then you already have burned a copy of that Cd!
Nov 02, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
Apr 12, 2009 | Computers & Internet
My philips cd recorder is not recording
the recorder philips cdr-778 put my 80 min sony cd-r audio in it start recording 20 second on track 1 go to track 2 for 20 second then stops goes to update some times it reads no disc when installing the disc we have been recording at the Church for the past 2 years
from clyde
Mar 02, 2009 | Philips CDR778 2-Disc CD Recorder
T30 always comes up with record-ready display screen
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Nov 06, 2008 | iRiver T30 MP3 Player
RCA CDRW 140 dual deck CD recorder
READY
Place cd you want to copy in tray A (EVEN WHEN YOU WANT TO GET ONE SONG COPIED )
Blank Disc in tray B .
Program tacks in any desired sequence
Press the TIME SET / PROGRAM button on recorder or remote..."WAIT" appears then "01" flashes to let you know the unit is ready for the first track.
Enter the first track you want to program using the numbers buttons on the remote .
or SKIP / SEARCH button on recorder.
When the track flashes PRESS TIME SET / PROGRAM on remote or recorder.
to select it , "OK " appears
HOPE THIS IS HELP YOU NEED >> GOOD LUCK
I WISH MINE WOULD WORK IS DOWN AND OUT !
Oct 08, 2008 | RCA CDRW120 2-Disc CD Recorder
How long can I record using a DVD-RAM disc?
• Extra Fine mode (3-9Mbps record speed): Approx. 20 min. minimum per side. • Fine mode (6Mbps record speed): Approx. 30 min. per side (1 hour total). • Standard mode (3Mbps record speed): Approx. 1 hr. per side (2 hours total).
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Open Questions:
The printer won't work on disclabel or other software. It only works good on the testing in the printer setup. Macbook with Microboards MX 2. It goes on till the printing fase. ERROR LOG:Process: DiscPrinter [607] Path: /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/MacOS/DiscPrinter Identifier: DiscPrinter Version: 2.1.0 (2.1.0.6) Code Type: X86-64 (Native) Parent Process: cupsd [577] Responsible: DiscPrinter [607] User ID: 26 Date/Time: 2015-11-03 12:41:50.899 +0100 OS Version: Mac OS X 10.11.1 (15B42) Report Version: 11 Anonymous UUID: AA3DFA29-60FC-5C3B-34A4-014DDC5F4116 Time Awake Since Boot: 1000 seconds System Integrity Protection: enabled Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000 Exception Note: EXC_CORPSE_NOTIFY VM Regions Near 0: --> __TEXT 0000000100000000-00000001001f9000 [ 2020K] r-x/rwx SM=COW /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/MacOS/DiscPrinter Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 com.Microboards.print.driver.cups.disc_printer 0x00000001000b2488 bool com_sps_cups_disc_printer_util_2_1_0::ABucket::FindNoThrow(std::string const&, EIOTypeValue&) const + 126094 1 com.Microboards.print.driver.cups.disc_printer 0x000000010001ac1d 0x100000000 + 109597 2 com.Microboards.print.driver.cups.disc_printer 0x000000010001b3a6 0x100000000 + 111526 3 com.Microboards.print.driver.cups.disc_printer 0x000000010001dada 0x100000000 + 121562 4 com.Microboards.print.driver.cups.disc_printer 0x000000010001ed07 0x100000000 + 126215 5 com.Microboards.print.driver.cups.disc_printer 0x0000000100028a1a void com_sps_cups_disc_printer_util_2_1_0::ABucket::Set(std::string const&, com_sps_cups_disc_printer_util_2_1_0::AHPString const&) + 34458 6 com.Microboards.print.driver.cups.disc_printer 0x000000010001917a 0x100000000 + 102778 7 com.Microboards.print.driver.cups.disc_printer 0x0000000100019462 0x100000000 + 103522 8 com.Microboards.print.driver.cups.disc_printer 0x0000000100010ef0 0x100000000 + 69360 Thread 1: 0 libsystem_kernel.dylib 0x00007fff8927350a read + 10 1 com.Microboards.print.driver.cups.disc_printer 0x000000010002919b void com_sps_cups_disc_printer_util_2_1_0::ABucket::Set(std::string const&, com_sps_cups_disc_printer_util_2_1_0::AHPString const&) + 36379 2 libsystem_pthread.dylib 0x00007fff9d56c9b1 _pthread_body + 131 3 libsystem_pthread.dylib 0x00007fff9d56c92e _pthread_start + 168 4 libsystem_pthread.dylib 0x00007fff9d56a385 thread_start + 13 Thread 2: 0 libsystem_kernel.dylib 0x00007fff8927278a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff9d56c58c _pthread_wqthread + 1283 2 libsystem_pthread.dylib 0x00007fff9d56a375 start_wqthread + 13 Thread 3:: Dispatch queue: com.apple.libdispatch-manager 0 libsystem_kernel.dylib 0x00007fff892730a2 kevent_qos + 10 1 libdispatch.dylib 0x00007fff8ce2711d _dispatch_mgr_invoke + 216 2 libdispatch.dylib 0x00007fff8ce26d85 _dispatch_mgr_thread + 52 Thread 4: 0 libsystem_kernel.dylib 0x00007fff8927278a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff9d56c58c _pthread_wqthread + 1283 2 libsystem_pthread.dylib 0x00007fff9d56a375 start_wqthread + 13 Thread 0 crashed with X86 Thread State (64-bit): rax: 0x0000000000000000 rbx: 0x0000000000000000 rcx: 0x00000000001f8100 rdx: 0x0000000000000000 rdi: 0x0000000000000000 rsi: 0x0000000000000020 rbp: 0x00007fff5fbfe480 rsp: 0x00007fff5fbfe350 r8: 0x0000000000000001 r9: 0x0000000000000001 r10: 0x0000000000000002 r11: 0x0000000101d00000 r12: 0x0000000101d6ec10 r13: 0x00007fff5fbfe710 r14: 0x00007fff5fbfe710 r15: 0x0000000000000000 rip: 0x00000001000b2488 rfl: 0x0000000000010206 cr2: 0x000000010a8aa000 Logical CPU: 0 Error Code: 0x02000170 Trap Number: 133 Binary Images: 0x100000000 - 0x1001f8fef +com.Microboards.print.driver.cups.disc_printer (2.1.0 - 2.1.0.6) /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/MacOS/DiscPrinter 0x10024a000 - 0x10024ffff libcupsimage.2.dylib (435) /usr/lib/libcupsimage.2.dylib 0x100254000 - 0x1002eefef +libspsutils.dylib (1.2) /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/lib/libspsutils.dylib 0x7fff6c1ad000 - 0x7fff6c1e3f5f dyld (360.17) /usr/lib/dyld 0x7fff88482000 - 0x7fff8857dff7 libFontParser.dylib (158.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib 0x7fff8857e000 - 0x7fff88805ff3 com.apple.CFNetwork (760.1.2 - 760.1.2) /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x7fff88bdf000 - 0x7fff88beeffb com.apple.LangAnalysis (1.7.0 - 1.7.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x7fff88c00000 - 0x7fff88c05fff com.apple.TCC (1.0 - 1) /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC 0x7fff88c06000 - 0x7fff88c0efef libsystem_platform.dylib (73.1.1) /usr/lib/system/libsystem_platform.dylib 0x7fff88d9c000 - 0x7fff8925afcf com.apple.vImage (8.0 - 8.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x7fff8925b000 - 0x7fff89279fff libsystem_kernel.dylib (3247.10.11) /usr/lib/system/libsystem_kernel.dylib 0x7fff8927a000 - 0x7fff8927bfff libsystem_secinit.dylib (20) /usr/lib/system/libsystem_secinit.dylib 0x7fff89282000 - 0x7fff89285fff libCoreVMClient.dylib (119.5) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib 0x7fff89286000 - 0x7fff8928fff3 com.apple.CommonAuth (4.0 - 2.0) /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth 0x7fff89299000 - 0x7fff892a4ff7 libChineseTokenizer.dylib (16) /usr/lib/libChineseTokenizer.dylib 0x7fff8951e000 - 0x7fff89523ff7 libmacho.dylib (875.1) /usr/lib/system/libmacho.dylib 0x7fff89524000 - 0x7fff89582fff com.apple.SystemConfiguration (1.14 - 1.14) /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x7fff8967b000 - 0x7fff8976afff libxml2.2.dylib (29) /usr/lib/libxml2.2.dylib 0x7fff897a7000 - 0x7fff897c2ff7 libCRFSuite.dylib (34) /usr/lib/libCRFSuite.dylib 0x7fff897c3000 - 0x7fff897c6ff7 libsystem_sandbox.dylib (459.10.4) /usr/lib/system/libsystem_sandbox.dylib 0x7fff8aade000 - 0x7fff8ab0fffb com.apple.GSS (4.0 - 2.0) /System/Library/Frameworks/GSS.framework/Versions/A/GSS 0x7fff8ab7a000 - 0x7fff8ab93fff com.apple.CFOpenDirectory (10.11 - 194) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x7fff8ae6f000 - 0x7fff8b0eefff com.apple.security (7.0 - 57336.10.29) /System/Library/Frameworks/Security.framework/Versions/A/Security 0x7fff8b0ef000 - 0x7fff8b0f5fff com.apple.IOAccelerator (203.10 - 203.10) /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator 0x7fff8b29e000 - 0x7fff8b2d8fff com.apple.QD (3.12 - 302) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x7fff8b2dc000 - 0x7fff8b30aff7 com.apple.DictionaryServices (1.2 - 250) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x7fff8b343000 - 0x7fff8b460fff libsqlite3.dylib (216.4) /usr/lib/libsqlite3.dylib 0x7fff8c222000 - 0x7fff8c34efff com.apple.CoreText (352.0 - 494.5.1) /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText 0x7fff8c34f000 - 0x7fff8c351ff7 libRadiance.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x7fff8c355000 - 0x7fff8c3aafff com.apple.AE (701 - 701) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x7fff8c6c7000 - 0x7fff8c6d5ff7 libbz2.1.0.dylib (38) /usr/lib/libbz2.1.0.dylib 0x7fff8c6d6000 - 0x7fff8c749fff com.apple.framework.IOKit (2.0.2 - 1178.10.1) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x7fff8c9e7000 - 0x7fff8c9f2fff libkxld.dylib (3247.10.11) /usr/lib/system/libkxld.dylib 0x7fff8cc1c000 - 0x7fff8cc32ff7 libLinearAlgebra.dylib (1159) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib 0x7fff8cc33000 - 0x7fff8cc83fff libcups.2.dylib (435) /usr/lib/libcups.2.dylib 0x7fff8cc84000 - 0x7fff8ccc2ff7 libGLImage.dylib (12.0.34.12) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x7fff8ccc3000 - 0x7fff8cde8ff7 com.apple.LaunchServices (728.4 - 728.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x7fff8ce1f000 - 0x7fff8ce4cfff libdispatch.dylib (500.10.1) /usr/lib/system/libdispatch.dylib 0x7fff8ce4d000 - 0x7fff8ce50ff7 libCoreFSCache.dylib (119.5) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib 0x7fff8d075000 - 0x7fff8d092fff com.apple.AppleVPAFramework (2.0.15 - 2.0.15) /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA 0x7fff8d12a000 - 0x7fff8d199fff com.apple.SearchKit (1.4.0 - 1.4.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x7fff8d410000 - 0x7fff8d414fff libcache.dylib (75) /usr/lib/system/libcache.dylib 0x7fff8d41b000 - 0x7fff8d4d4ff7 libvMisc.dylib (563.4) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x7fff8dc7e000 - 0x7fff8dcadfc3 libsystem_m.dylib (3105) /usr/lib/system/libsystem_m.dylib 0x7fff8dd01000 - 0x7fff8dd43ff7 com.apple.Metal (54.26.3 - 54.26.3) /System/Library/Frameworks/Metal.framework/Versions/A/Metal 0x7fff8dec4000 - 0x7fff8f12fff7 com.apple.CoreGraphics (1.600.0 - 938) /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x7fff8f137000 - 0x7fff8f13ffff com.apple.CoreServices.FSEvents (1222.1.1 - 1222.1.1) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents 0x7fff8f146000 - 0x7fff8f14efff libGFXShared.dylib (12.0.34.12) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x7fff8f573000 - 0x7fff8f57dfff com.apple.NetAuth (6.0 - 6.0) /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth 0x7fff8f57e000 - 0x7fff8f5c9ffb com.apple.print.framework.PrintCore (11.0 - 472) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x7fff8f6be000 - 0x7fff8f6d8fff com.apple.Kerberos (3.0 - 1) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x7fff8f6d9000 - 0x7fff8f7cbff7 libiconv.2.dylib (44) /usr/lib/libiconv.2.dylib 0x7fff8f7cc000 - 0x7fff8f811ff3 libFontRegistry.dylib (155) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib 0x7fff8f93d000 - 0x7fff8f940fff com.apple.IOSurface (108.0.1 - 108.0.1) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x7fff8fc06000 - 0x7fff8fc07ffb libSystem.B.dylib (1225.1.1) /usr/lib/libSystem.B.dylib 0x7fff8fc08000 - 0x7fff8fc0dff7 libheimdal-asn1.dylib (452.1.1) /usr/lib/libheimdal-asn1.dylib 0x7fff8fc0e000 - 0x7fff8fc1cfff com.apple.opengl (12.0.34 - 12.0.34) /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x7fff8fc30000 - 0x7fff8fc4cff7 libextension.dylib (78) /usr/lib/libextension.dylib 0x7fff8fc4d000 - 0x7fff8fc58ff7 libcommonCrypto.dylib (60074) /usr/lib/system/libcommonCrypto.dylib 0x7fff8fd0b000 - 0x7fff8fd0bfff com.apple.CoreServices (728.4 - 728.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x7fff90895000 - 0x7fff908baff7 libPng.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x7fff9092d000 - 0x7fff90939fff com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x7fff90959000 - 0x7fff90a6bfef libvDSP.dylib (563.4) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x7fff90d13000 - 0x7fff90d16ffb libdyld.dylib (360.17) /usr/lib/system/libdyld.dylib 0x7fff90d31000 - 0x7fff90d33fff libsystem_coreservices.dylib (19) /usr/lib/system/libsystem_coreservices.dylib 0x7fff90f60000 - 0x7fff90f64fff libpam.2.dylib (20) /usr/lib/libpam.2.dylib 0x7fff90fa2000 - 0x7fff91016ff3 com.apple.securityfoundation (6.0 - 55126) /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x7fff912e5000 - 0x7fff912e7ff7 libquarantine.dylib (80) /usr/lib/system/libquarantine.dylib 0x7fff91302000 - 0x7fff91306fff libGIF.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x7fff91374000 - 0x7fff913e7ffb com.apple.Heimdal (4.0 - 2.0) /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal 0x7fff91ba2000 - 0x7fff91bc6ff7 libJPEG.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x7fff91cc4000 - 0x7fff91cc4ff7 liblaunch.dylib (755.1.19) /usr/lib/system/liblaunch.dylib 0x7fff92319000 - 0x7fff9235eff7 com.apple.coreservices.SharedFileList (24.4 - 24.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList 0x7fff928b9000 - 0x7fff928bafff liblangid.dylib (122) /usr/lib/liblangid.dylib 0x7fff9313c000 - 0x7fff93141fff com.apple.DiskArbitration (2.7 - 2.7) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x7fff934f9000 - 0x7fff93557fff libsystem_network.dylib (582.1.4) /usr/lib/system/libsystem_network.dylib 0x7fff94247000 - 0x7fff94249fff libCVMSPluginSupport.dylib (12.0.34.12) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib 0x7fff94393000 - 0x7fff94393fff com.apple.ApplicationServices (48 - 48) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x7fff94470000 - 0x7fff94506ff7 com.apple.ColorSync (4.9.0 - 4.9.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x7fff94542000 - 0x7fff94542fff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x7fff9454c000 - 0x7fff94551ff3 libunwind.dylib (35.3) /usr/lib/system/libunwind.dylib 0x7fff945d1000 - 0x7fff945d1fff libOpenScriptingUtil.dylib (169) /usr/lib/libOpenScriptingUtil.dylib 0x7fff945d2000 - 0x7fff949d4fff libLAPACK.dylib (1159) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x7fff95587000 - 0x7fff959fcff7 com.apple.CoreFoundation (6.9 - 1255.1) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff95a62000 - 0x7fff95a70fff libxar.1.dylib (302) /usr/lib/libxar.1.dylib 0x7fff95b84000 - 0x7fff95b94fff libbsm.0.dylib (34) /usr/lib/libbsm.0.dylib 0x7fff95b95000 - 0x7fff95b9cff7 libcompiler_rt.dylib (62) /usr/lib/system/libcompiler_rt.dylib 0x7fff95d16000 - 0x7fff95ebbff3 com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x7fff95ebc000 - 0x7fff960c9fff libicucore.A.dylib (551.30) /usr/lib/libicucore.A.dylib 0x7fff96188000 - 0x7fff961d6ff7 libstdc++.6.dylib (104.1) /usr/lib/libstdc++.6.dylib 0x7fff965e2000 - 0x7fff9666fdd7 com.apple.AppleJPEG (1.0 - 1) /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG 0x7fff96673000 - 0x7fff966e1ff7 com.apple.ApplicationServices.ATS (377 - 394.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x7fff966e2000 - 0x7fff96782fff com.apple.Metadata (10.7.0 - 972.9) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x7fff967dd000 - 0x7fff967f9ff7 libsystem_malloc.dylib (67) /usr/lib/system/libsystem_malloc.dylib 0x7fff967fa000 - 0x7fff968ecff7 libJP2.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x7fff968ed000 - 0x7fff968edfff libmetal_timestamp.dylib (600.0.41.2) /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib 0x7fff968fc000 - 0x7fff96959fff com.apple.CoreServices.OSServices (728.4 - 728.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x7fff9695a000 - 0x7fff96971fff libmarisa.dylib (4) /usr/lib/libmarisa.dylib 0x7fff96b6c000 - 0x7fff96e01fff libmecabra.dylib (696.1) /usr/lib/libmecabra.dylib 0x7fff96e55000 - 0x7fff96e89ff7 com.apple.CoreVideo (1.8 - 191.1) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x7fff96f38000 - 0x7fff96f49fff libz.1.dylib (60) /usr/lib/libz.1.dylib 0x7fff9701e000 - 0x7fff97038ff3 liblzma.5.dylib (10) /usr/lib/liblzma.5.dylib 0x7fff97507000 - 0x7fff97508fff libsystem_blocks.dylib (65) /usr/lib/system/libsystem_blocks.dylib 0x7fff97fcd000 - 0x7fff97fd5fff libcopyfile.dylib (127) /usr/lib/system/libcopyfile.dylib 0x7fff98031000 - 0x7fff98032fff libDiagnosticMessagesClient.dylib (100) /usr/lib/libDiagnosticMessagesClient.dylib 0x7fff98033000 - 0x7fff9839dddf libobjc.A.dylib (680) /usr/lib/libobjc.A.dylib 0x7fff9839e000 - 0x7fff9839eff7 libkeymgr.dylib (28) /usr/lib/system/libkeymgr.dylib 0x7fff983c1000 - 0x7fff983d1fff libSparseBLAS.dylib (1159) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib 0x7fff98ca3000 - 0x7fff98d30fe7 libsystem_c.dylib (1081.1.3) /usr/lib/system/libsystem_c.dylib 0x7fff98ea0000 - 0x7fff98ef3ff7 libc++.1.dylib (120.1) /usr/lib/libc++.1.dylib 0x7fff99073000 - 0x7fff9907bfff com.apple.NetFS (6.0 - 4.0) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x7fff990cc000 - 0x7fff990ceff7 com.apple.xpc.ServiceManagement (1.0 - 1) /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement 0x7fff992b2000 - 0x7fff992c9fff libsystem_asl.dylib (322) /usr/lib/system/libsystem_asl.dylib 0x7fff992cd000 - 0x7fff99573fff com.apple.CoreData (120 - 640) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x7fff9a401000 - 0x7fff9a5caff7 com.apple.ImageIO.framework (3.3.0 - 1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x7fff9a5cb000 - 0x7fff9a5d6fff libGL.dylib (12.0.34.12) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x7fff9a5d7000 - 0x7fff9a5d7fff com.apple.Accelerate (1.10 - Accelerate 1.10) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x7fff9a6aa000 - 0x7fff9a6fbff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x7fff9a6fc000 - 0x7fff9a725ff7 libsystem_info.dylib (476) /usr/lib/system/libsystem_info.dylib 0x7fff9a89d000 - 0x7fff9a8a6ffb libsystem_notify.dylib (149) /usr/lib/system/libsystem_notify.dylib 0x7fff9aa0d000 - 0x7fff9aa36fff libxpc.dylib (755.1.19) /usr/lib/system/libxpc.dylib 0x7fff9aa37000 - 0x7fff9aa39ff7 libsystem_configuration.dylib (801.10.2) /usr/lib/system/libsystem_configuration.dylib 0x7fff9aa6c000 - 0x7fff9aa7dff7 libsystem_trace.dylib (200) /usr/lib/system/libsystem_trace.dylib 0x7fff9aa7e000 - 0x7fff9aa86fff libsystem_networkextension.dylib (384.1.2) /usr/lib/system/libsystem_networkextension.dylib 0x7fff9ac9f000 - 0x7fff9acc8ff7 libxslt.1.dylib (14) /usr/lib/libxslt.1.dylib 0x7fff9adec000 - 0x7fff9adedffb libremovefile.dylib (41) /usr/lib/system/libremovefile.dylib 0x7fff9b218000 - 0x7fff9b218fff libenergytrace.dylib (10) /usr/lib/libenergytrace.dylib 0x7fff9b219000 - 0x7fff9b25aff7 libGLU.dylib (12.0.34.12) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x7fff9b396000 - 0x7fff9b398fff com.apple.loginsupport (1.0 - 1) /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport 0x7fff9bbf9000 - 0x7fff9bc1dfff com.apple.MultitouchSupport.framework (304.9 - 304.9) /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport 0x7fff9bc7f000 - 0x7fff9bc87ffb libsystem_dnssd.dylib (624.10.1) /usr/lib/system/libsystem_dnssd.dylib 0x7fff9bc88000 - 0x7fff9bca4ff3 libresolv.9.dylib (60) /usr/lib/libresolv.9.dylib 0x7fff9cd6e000 - 0x7fff9cd7ffff libcmph.dylib (6) /usr/lib/libcmph.dylib 0x7fff9cd80000 - 0x7fff9cdabffb libarchive.2.dylib (32.10.1) /usr/lib/libarchive.2.dylib 0x7fff9cdaf000 - 0x7fff9d094ff3 com.apple.CoreServices.CarbonCore (1136 - 1136) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x7fff9d095000 - 0x7fff9d0adfc7 libcompression.dylib (23) /usr/lib/libcompression.dylib 0x7fff9d0c4000 - 0x7fff9d13bfc7 libcorecrypto.dylib (334) /usr/lib/system/libcorecrypto.dylib 0x7fff9d13c000 - 0x7fff9d148ff7 com.apple.OpenDirectory (10.11 - 194) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory 0x7fff9d14c000 - 0x7fff9d198ffb com.apple.HIServices (1.22 - 548) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x7fff9d19f000 - 0x7fff9d4f3fff com.apple.Foundation (6.9 - 1255.1) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff9d569000 - 0x7fff9d572ff7 libsystem_pthread.dylib (137.1.1) /usr/lib/system/libsystem_pthread.dylib 0x7fff9db15000 - 0x7fff9dcd5feb libBLAS.dylib (1159) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x7fff9dee0000 - 0x7fff9dee0ff7 libunc.dylib (29) /usr/lib/system/libunc.dylib 0x7fff9dee1000 - 0x7fff9df27ff7 libauto.dylib (186) /usr/lib/libauto.dylib 0x7fff9e491000 - 0x7fff9e4bafff libc++abi.dylib (125) /usr/lib/libc++abi.dylib 0x7fff9e529000 - 0x7fff9e53dfff libsystem_coretls.dylib (82) /usr/lib/system/libsystem_coretls.dylib 0x7fff9eacf000 - 0x7fff9eb76fff com.apple.LanguageModeling (1.0 - 1) /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling 0x7fff9eb88000 - 0x7fff9ebe3ff7 libTIFF.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 912 thread_create: 0 thread_set_state: 0 VM Region Summary: ReadOnly portion of Libraries: Total=178.5M resident=0K(0%) swapped_out_or_unallocated=178.5M(100%) Writable regions: Total=39.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=39.5M(100%) VIRTUAL REGION REGION TYPE SIZE COUNT (non-coalesced) =========== ======= ======= Activity Tracing 2048K 2 Dispatch continuations 4096K 2 Kernel Alloc Once 4K 2 MALLOC 21.6M 18 MALLOC guard page 32K 7 Process Corpse Info 2048K 2 STACK GUARD 56.0M 6 Stack 9824K 6 VM_ALLOCATE 20K 3 __DATA 8572K 144 __LINKEDIT 91.2M 6 __TEXT 87.3M 149 __UNICODE 552K 2 mapped file 25.1M 2 shared memory 20K 5 =========== ======= ======= TOTAL 307.8M 341 E [03/Nov/2015:12:41:50 +0100] [Job 31] Job stopped due to filter errors; please consult the error_log file for details. D [03/Nov/2015:12:41:50 +0100] [Job 31] The following messages were recorded from 12:41:50 to 12:41:50 D [03/Nov/2015:12:41:50 +0100] [Job 31] Adding start banner page "none". D [03/Nov/2015:12:41:50 +0100] [Job 31] Queued on "Microboards_PF_Pro" by "dennis". D [03/Nov/2015:12:41:50 +0100] [Job 31] File of type application/pdf queued by "dennis". D [03/Nov/2015:12:41:50 +0100] [Job 31] Setting job-hold-until to no-hold D [03/Nov/2015:12:41:50 +0100] [Job 31] Adding end banner page "none". D [03/Nov/2015:12:41:50 +0100] [Job 31] Job released by user. D [03/Nov/2015:12:41:50 +0100] [Job 31] time-at-processing=1446550910 D [03/Nov/2015:12:41:50 +0100] [Job 31] 1 filters for job: D [03/Nov/2015:12:41:50 +0100] [Job 31] /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/MacOS/DiscPrinter (application/pdf to printer/Microboards_PF_Pro, cost 100) D [03/Nov/2015:12:41:50 +0100] [Job 31] job-sheets=none,none D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[0]="Microboards_PF_Pro" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[1]="31" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[2]="dennis" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[3]="Microboards PF-Pro - Untitled1 - DiscLabel" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[4]="1" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[5]="AP_ColorMatchingMode=AP_VendorColorMatching AP_D_InputSlot= noBookletBinding..b. BookletType..n.=0 nocollate com.apple.print.DocumentTicket.PMSpoolFormat=application/pdf com.apple.print.JobInfo.PMApplicationName=DiscLabel com.apple.print.JobInfo.PMJobName=Microboards\ PF-Pro\ -\ Untitled1\ -\ DiscLabel com.apple.print.JobInfo.PMJobOwner=Dennis com.apple.print.PageToPaperMappingMediaName=cd-120mm com.apple.print.PageToPaperMappingType..n.=1 com.apple.print.PrinterInfo.PMColorDeviceID..n.=16828 com.apple.print.PrintSettings.PMColorSpaceModel..n.=2 com.apple.print.PrintSettings.PMCopies..n.=1 com.apple.print.PrintSettings.PMCopyCollate..b. com.apple.print.PrintSettings.PMDestinationType..n.=1 com.apple.print.PrintSettings.PMFirstPage..n.=1 com.apple.print.PrintSettings.PMLastPage..n.=2147483647 com.apple.print.PrintSettings.PMLayoutColumns..n.=1 com.apple.print.PrintSettings.PMLayoutRows..n.=1 com.apple.print.PrintSettings.PMPageRange..a.0..n.=1 com.apple.print.PrintSettings.PMPageRange..a.1..n.=2147483647 DestinationPrinterID=Microboards_PF_Pro media=cd-120mm PaperInfoIsSuggested..b. pserrorhandler-requested=standard SPSClippingDiameters={\ Inner=360\ Outer=1180\ } SPSClippingHubDiameters={\ Inner=220\ Outer=360\ } job-uuid=urn:uuid:484af430-bba9-369f-4b62-be25bc4f6ac7 job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1446550910 time-at-processing=1446550910 document-name-supplied=Microboards\ PF-Pro\ -\ Untitled1\ -\ DiscLabel job-impressions=1 com.apple.print.PrintSettings.PMTotalSidesImaged..n.=1 sides=one-sided Duplex=None com.apple.print.PrintSettings.PMTotalBeginPages..n.=1 PageSize=cd-120mm" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[6]="/private/var/spool/cups/d00031-001" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[0]="" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[1]="CUPS_CACHEDIR=/private/var/spool/cups/cache" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[2]="CUPS_DATADIR=/usr/share/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[3]="CUPS_DOCROOT=/usr/share/doc/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[4]="CUPS_FONTPATH=/usr/share/cups/fonts" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[5]="CUPS_REQUESTROOT=/private/var/spool/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[6]="CUPS_SERVERBIN=/usr/libexec/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[7]="CUPS_SERVERROOT=/private/etc/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[8]="CUPS_STATEDIR=/private/etc/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[9]="HOME=/private/var/spool/cups/tmp" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[10]="PATH=/usr/libexec/cups/filter:/usr/bin:/usr/sbin:/bin:/usr/bin" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[11]="SERVER_ADMIN=root@macbookandennis.lan" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[12]="SOFTWARE=CUPS/2.1.0" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[13]="TMPDIR=/private/var/spool/cups/tmp" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[14]="USER=root" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[15]="CUPS_MAX_MESSAGE=2047" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[16]="CUPS_SERVER=/private/var/run/cupsd" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[17]="CUPS_ENCRYPTION=IfRequested" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[18]="IPP_PORT=631" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[19]="CHARSET=utf-8" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[20]="LANG=nl.UTF-8" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[21]="APPLE_LANGUAGE=nl" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[22]="PPD=/private/etc/cups/ppd/Microboards_PF_Pro.ppd" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[23]="RIP_MAX_CACHE=128m" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[24]="CONTENT_TYPE=application/pdf" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[25]="DEVICE_URI=usb://Microboards/PF-Pro?serial=PFP0004319" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[26]="PRINTER_INFO=Microboards PF-Pro" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[27]="PRINTER_LOCATION=MacBook van Dennis" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[28]="PRINTER=Microboards_PF_Pro" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[29]="PRINTER_STATE_REASONS=none" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[30]="CUPS_FILETYPE=document" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[31]="FINAL_CONTENT_TYPE=printer/Microboards_PF_Pro" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[32]="AUTH_I****" D [03/Nov/2015:12:41:50 +0100] [Job 31] Started filter /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/MacOS/DiscPrinter (PID 607) D [03/Nov/2015:12:41:50 +0100] [Job 31] Started backend /usr/libexec/cups/backend/usb (PID 608) D [03/Nov/2015:12:41:50 +0100] [Job 31] usb: AppleLanguages="nl" D [03/Nov/2015:12:41:50 +0100] [Job 31] STATE: +connecting-to-device D [03/Nov/2015:12:41:50 +0100] [Job 31] Looking for 'Microboards PF-Pro' D [03/Nov/2015:12:41:50 +0100] [Job 31] Opening connection D [03/Nov/2015:12:41:50 +0100] [Job 31] Directory '/System/Library/Printers/Libraries/USBGenericPrintingClass.plugin' heeft juiste bevoegdheden (040755/uid=0/gid=0). D [03/Nov/2015:12:41:50 +0100] [Job 31] load_classdriver(/Sys
Nov 03, 2015 | MicroBoards MX-2 Disc Publisher MX21000
MicroBoards G4 Disc Publisher G4 CD/DVD Disc Publisher Logo
763 people viewed this question
Top MicroBoards Computers & Internet Experts
Rick Moore
Rick Moore
 Grubhead
Grubhead
Are you a MicroBoards Computer and Internet Expert? Answer questions, earn points and help others
