Question about Diesel mr daddy black steel dz7214
My DZ7214 Stem broke.Where can I find one stem (crown). I asked official seller and thay told me, when they order crowns, Diesel send them package of 30 crowns (but I need one)
CROWN-STEM WILL NOT STAY IN PLACE
possibly you will need to clean around the threaded part of the case (pipe), when screwing the crown down push against the case and rotate gently back and forth until the crown catches the thread.
Jan 01, 2018 | Watches
What is the cost to for a new crown for my Anne Klein watch? The model # is 10/6417
depends if you want the same factory crown or just one that looks nice but not the official crown , but crown , if stem is not broking around 15 - 20 dollars to replace, crown and stem around 30 4-5 dollars to replace.
Oct 17, 2010 | Anne Klein Watches
I have a diesel watch model dz-2136 I need to know how to remove stem
Thank you for contacting FixYa.
I dont know why you want to remove the stem but here you go.
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder. Now you can remove the stem as described above
Aug 26, 2010 | Diesel Audio Diesel Watch
The stem and crown fell out of my fossil watch, i would like to obtain replacements and install them myself.
mcdevito75 here, You may not be able to fix your fossil watch, it"sa quartz and once the crown and stem came out, the mechanism that holds it in plce may be broke.
Jun 14, 2010 | Watches
I pulled the stem out completely trying to reset time.
if you broke the stem and its left a peice inside the movement then i would ask your repairer for a module exchange this is cheaper than servicing and a new crown 55.00 or send it back to seiko they are very good with there prices.you wont have the tools you need to replace it yourself..
Mar 25, 2010 | Seiko SUJ051 Wrist Watch
Stem of watch won't return to its original position
The winding crown is loose on the stem. Get the stem completely out of watch and while holding in vice or pair of pliers screw the crown back on tight. Do not overscrew it, as the stem may brake. Even better would be to unscrew the crown first, dip the threaded stem end in to the Superglue and then screw the crown back. It will prevent from the same problem in future.
Rate, please.
Jul 29, 2009 | Watches
I pulled on the crown and it came off the stem
Do not open the watch yet, as you do not know how to get the stem out.
Take an eyeglass and examine the crown. You will find the small hub in the centre of the crown. If the centre of this hub is hollow and you can see the thread in it- you will be able to screw it back on stem (all watch crowns are screwed on to stems, never pressed).
If the centre of that hub looks filled with metal, then the stem end is broke and you will need replace stem AND crown (the metal filling the hub is the broken end of stem).
In case if the crown still in tact, let me know by asking questions and I'll guide you through all the process HOW TO.
Rate me, please.
Mar 24, 2009 | Watches
Missing piece?
You are not missing anything. The stem (metal bar, wich is going into movement) from the crown (you say knob) is broke. The stem is made of one piece and screws directly into crown. You've been unfortunate to brake it and the tiny end of stem still in the crown - the rest looks OK , but actually it is what's left of the stem. This is not the job you can do yourself, so, find the nearest watchmaker and ask for replacement. Do not forget to rate, please.
Mar 03, 2009 | Fossil Metal Casual Green Dial AM4071...
Removing the crown/stem of CASIO EF-321
Other case for a simple Casio quartz watch :
Jan 15, 2009 | Casio Edifice EF106D2AV Wrist Watch
The stem cap is missing on my Polar watch
Yes, the crown can be replaced. Find your nearest watchmaker and ask to do that.
Crown=stem cup.
Dec 20, 2008 | Polar F6 Wrist Watch
Diesel mr daddy black steel dz7214 Logo
52 people viewed this question
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Diesel Watch Expert? Answer questions, earn points and help others
