I have a g560 laptop that had a broken screen then i took it to repair shop. they replaced the screen but it was flickering when on password screen, which did not bother me until i installed windows7 eternity now it flickers when unplugged to power source or when the screen is idle, i tried lowering refresh rate but nothing changes and i have screwdrivers and i had opened my pc before
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
Take it back to the shop whi fixed a new screen and ask them to fix the problem...
dont u touch anything..as this will wave the warranty..if u have...dont tell them when u bring it back...
Posted on Oct 18, 2013
Testimonial: "problem is this happened last year and like i said i ddnt mind it then bt now after installin win7 eternity problem started. i dnt wana loose eternity and why does it flicker only when the is no activity in the screen"
4 Suggested Answers
bunnydawg
  • 5158 Answers
SOURCE: Compaq Presario 1700 Laptop screen flickers and locks up
it sounds possibly that it is going into hibernation. a single press of the power button should bring it back alive.
also feel the bottom of the laptop.... if it is getting close to meltdown you need to clean the dust and dirt from the heatsinks. the fan area may appear to be clear but all the junk gets blown against copper heat sinks so you need to remove the covers to get at it.
Robert
Posted on Sep 05, 2008
  • 476 Answers
SOURCE: Sony Vaio Laptop VGN-CR240E LCD screen flickering
Hi - I have replaced lots of LCD screens,it can be done
HOW TO REMOVE LCD PANEL OF MY ACER LAPTOP.
First ===>>> Remove all power and battery
Each machine is different in construction and size,
but they operate in the same fashion,motherboard,power inverter,lcd panel and cable connecting them together,also there may be a wireless aerial and or camera as well inside the lids frame housing the lcd screen so be careful while dismantling the front frame,it should be a good tight fit,
the lid has a base and a front panel covering the workings of the screen and wiring in a compact frame,remove the screws from the front panel and lift the front frame free from the base,remove the power panel by the screen next to the keyboard this should expose the motherboard insides,then unplug the inverter from the screen,unscrew the screws holding the the frame and carefully lie the screen on a flat surface to unplug the data cable from the rear of the screen, top of the screen rear contains IC chips required to make the pictures,
DO NOT TOUCH THESE >>> STATIC KILLS
It dosent mater if the screen is already dead just remember this when you fit the new screen
Hope this helps,Misterdj
Posted on Aug 10, 2009
  • 93 Answers
SOURCE: flickering of the screen
just open the system and reseat the display cable...
Posted on Sep 20, 2009
G560
you probably damaged that spot and unfortunately it cant be fixed you will have to replace th screen
May 17, 2013 | Lenovo G460 Laptop Computer 06774CU Intel...
try to plug the laptop to a external monitor. I the display doesn't flicks your Motherboard or the graphics card fine and you need to replace your screen LCD
Aug 20, 2012 | Lenovo G530, G550, G560...
After being on for 10 minutes, screen flickers, black and grey, becoming nonlegible
Sounds like the LCD inverter is broken, or starting to fail. It will probably need professional repair, most laptop repair shops can do that for $100-$150.
Mar 21, 2011 | HP Pavilion ze4420us Notebook
Lenovo G560 will not allow printer drivers to be loaded.
your os and your printer driver is not compatible, download latest driver for your printer.
Thanks!
Jul 15, 2010 | Lenovo 3000 G530 Notebook
Viewsonic vp171s lcd flickers on start up then goes black.
This is typical of a back-light problem, especially when you view the LCD screen at a sharp angle and you see a dim Windows image. This fault is caused by either a faulty inverter board or a faulty CCFL lamp.
The inverter supplies high voltage to the CCFL lamp. the CCFL lamp is a mini fluro lamp which fails with age and use.
This LCD screen can be repaired, the cost of an inverter board and CCFL lamp is a lot cheaper than a new LCD screen, but this is an opportunity/excuse to buy a larger size LCD screen as these monitors have dropped in price.
For service, parts and DIY info check out LCD Parts WEB site, please click on this link to their site :-
www.lcdparts.net
Feb 08, 2010 | Computers & Internet
Half of screen flickering
Yes, the probability is that either the circuitry that drives the screen, or the screen itself is on the verge of failing. It is also remotely possible that the backlight is failing. In either case, the likelihood is that a screen replacement is in order. Take it to a computer shop that specializes in Laptop repairs - or call Computer Geeks.
Sep 22, 2009 | Toshiba Satellite P35 PC Notebook
My laptop screen is flickering
That could be ths connector that connect the LCD to the Motherboard in the laptop. Ive seen something similiar wherein i took down the screen, cleaned up the connectors and it worked like new...... for a few weeks then it went back and started he flickering again. We finally fixed the problem by replacing the screen. Apparently the connector behind the screen was giving trouble. Have someone check the cable from your LCD to the board but I think you might need to fix the connector or replace the LCD screen. Regards, babb
Apr 19, 2007 | Evesham Voyager 5800 Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
