Question about Kohler 12 kW Emergency Power System - 12RES-L
I have an older Kohler Power Pro 5000kw generator with a bad rectifier (#B239244) that is no longer available. I am trying to find a replacement but so far I am coming up with nothing. Any help would be appreciated.
    Prodigy:
    An expert who has answered 500 questions.
  • Kohler Expert
  • 573 Answers
Try contacting Nixon Power Services in TN. If they cannot help, you take the old rectifier out, note wiring. A rectifier is nothing special as long as it is the same current rating, if the part is truly obsolete then a good electrnic supply house can give you an equiv
Posted on Nov 16, 2013
2 Suggested Answers
  • 10865 Answers
SOURCE: wiring schematics
Kohler has an entire technical library on their website. Go to Kohler.com and you will find it. good luck
Posted on Jan 21, 2009
Why will it not strike an ark but it will idle up like it is supposed to. Found a blown fuse (replaced it) and the rheostat,.same problem blew fuse again
first, make sure your brushes are making good contact at the slip rings, and the brush connectors are clean and tight.
There are two bridge rectifiers which you will see if you remove the top cover of your machine, test the rectifiers, one of them has probably failed, before testing make sure you mark the wires before you pull them off of the rectifiers you will find a wiring diagram on the inside of one of the panels, the rectifiers are connected across the fuses, they are typically 40 amp/600 volt rectifiers
Mar 10, 2016 | Miller Bobcat 225 OHV Welder Generator...
How can I make my 15.5 h.p.kohler charge again
Check the rectifier to make sure you have AC power on the AC terminal, if you do stator windings are good, if not stator is bad.
If you have AC then check the DC wires on the rectifier, if you do not have battery voltage, change rectifier, if you do suspect wiring / fuses
Aug 02, 2013 | Electrical Supplies
First start up
Try disconencting the remote start wires between the transfer switch and the generator, if ot still does it you have a bad control board. If it stops, then check the transfer switch for correct wiring of utility and generator power wires, also check with an ohm meter if the run contacts in the transfer switch are closed, that would indicate loss of sensing, or bad board
Jul 19, 2013 | Kohler Electrical Supplies
If I lose street power momentarily and my generator immediately starts than quits because the street power comes back on, the weekly 20 minute generator excercise does not work.I have to reset the transfer...
Although A bit inconvienent this does seem to be the norm for some Kohler units. Actually a small price to pay rather than having a technician come out to replace the ATS control board. There are time delays that could be set longer to keep the unit running longer and may prevent this from happenng
Jan 03, 2011 | Kohler 18RESL 18 kW Emergency Power...
I have a automotive battery charger thats a Snap-On BC4200 I believe the rectifier is burnt up in it and am looking for a replacement part. Snap-On book says the part number is BC4200-2000R but it...
if you can find out the current it takes you can go online and buy rectifiers all day long they are pretty cheap too also you need find the type of rectifer like full wave, half wave, bridge rectifier. the bridge is usually the most common tho.
Nov 12, 2010 | Generac Guardian 065795 - battery charger...
Put new battery on engine thinking that was problem. Engine drew down battery till it won't start engine.
most common problem is the regulator/rectifier going bad. it has a built in diode that changes ac volts to dc & then sends it to the battery.
Oct 23, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
I have an older model Coleman Powermate 3750 Premium Plus. It is not charging. What do I need to replace?
it can be the voltage regulator that's in the control box or most likely the rectifier in the back side of the gen head it looks like a 1 inch by 1 inch by 3/8 inch black cube with 4 wire posts on it with a hole in the middle for mounting these will go bad in time and are currently avail in electronics stores even radio shack has them make a diagram and mark the wires to where they go on it and mark the rectifier as well they can be cross ref to newer ones as well their just a couple bucks get a spare to have do to a older machine this part is not in the catalog of the manufacture and un avail from them yet they are other places hope this helps
Aug 29, 2010 | Coleman Powermate Premium Plus 6250W...
I would like to know if it is possible to replace a kohler cv15t-41629 with a cv15t-41582. This is mounted a 2005 Toro 52 inch pro line. The shaft is bent, don't ask HOW. Am trying to find a reasonable...
You might check with a Harbor Freight store either locally or on the web. They have several engine sizes available (with overhead valves) that are Chinese made, but the prices are certainly reasonable. You may have to do some adapting to get one to work. Hope this helps!
Jun 28, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Wiring schematics
Jan 14, 2009 | Kohler Electrical Supplies
Kohler 12 kW Emergency Power System - 12RES-L Logo
116 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
