Question about Atf Refill Accessory Toyota Adapter
Drained atf but filler bottle still full why - Atf Refill Accessory Toyota Adapter
    Problem Solver:
  • 8 Answers
There should not be an external filler bottle on your vehicle for ATF. What you are seeing is probably the radiator overflow as the ATF is all in the trans. You should get just under 4 US quarts out when removing the fluid from a prius, and 7-8 from something like a Tacoma.
Posted on Oct 18, 2013
How many amount of atf fluid to be filled with my 2001 audi a4 1.8L non turbo?
How to check & change oil in automatic transmission on 2001 Audi A4 1.8L
At the bottom of the automatic gearbox (Tiptronic) you will find 2 threaded plugs on below surface. First (in front of the car) is for emptying, and second is for filling up. Tightening torque is 24 Nm for drain plug, respective 80 Nm for filler plug.
Automatic Transmission Fluid (ATF) checking:
1. Requirements for check:
1.1. Vehicle standing on level surface.
1.2. Transmission must not be in fail-safe mode.
1.3. Shift lever in "P" position, parking brake applied.
1.4. Engine idling.
1.5. Air Conditioner and heater OFF.
1.6. ATF temperature must not exceed 104 Fahrenheit degree (40 Celsius degree) at start of test.
1.7. Only ATF with designation ESSO LT 71 141 may be used. Do not use any lubricant additives.
1.8. Automatic Transmission Fluid ATF - part number: G 052 162 A2 (1 liter wrapping)
1.9. An ATF level check when transmission oil temperature is too low results in overfilling, when too high results in underfilling.
2. CAUTION: Too much or too little ATF will affect the operation of the transmission. The ATF level must be checked at regular intervals.
3. The oil level is correct if a slight amount of oil runs out when ATF temperature is between 86 Fahrenheit degree (30 Celsius degree) and 113 F deg (45 C deg) (caused by increase of oil level when heated). For warmer climates, 122 F deg (50 C deg).
4. Hang filled ATF reservoir VAG 1924 as high as possible.
5. Shift lever in "P" position, engine running at idle.
6. Place oil drip pan under transmission oil pan.
7. Remove ATF filler plug (at the bottom of the automatic gearbox you will find 2 threaded plugs on below surface. First (in front of the car) is for emptying, and second is for filling up.
8. With ATF temperature between 86 Fahrenheit degree (30 Celsius degree) and 113 F deg (45 C deg), for warmer climates, 122 F deg (50 C deg), a slight amount of oil will flow from filler hole when ATF level is correct.
9. If necessary drain or top off ATF to attain correct oil level. Top ATF with filler hook from VAG 1924 ATF reservoir. Insert VAG 1924 (tool) ATF reservoir filler hook into filler hole and top off until a slight amount of oil flows from filler hole.
NOTE: Fit filler hook into one of the oil deflector cap slots placed on the filler opening.
CAUTION: Do not press filler hook upward or oil deflector cap can be pushed off.
10. Reinstall ATF filler plug. Tightening torque is 80 Nm.
Sep 20, 2011 | 2001 Audi A4
Tip
Where are located oil plugs for AUDI tiptronic automatic gearbox
At the bottom of the automatic gearbox (tiptronic) you will find 2 threaded plugs on below surface. First (in front of the car) is for emptying, and second is for filling up. Tightening torque is 24 Nm.
1.4. Engine idling.
10. Reinstall ATF filler plug. Tightening torque is 24 Nm.
on Dec 19, 2009 | Audi A4 Cars & Trucks
Transmission slips
At the bottom of the automatic gearbox (tiptronic) you will find 2 threaded plugs on below surface. First (in front of the car) is for emptying, and second is for filling up. Tightening torque is 24 Nm for drain plug, respective 80 Nm for filler plug.
1.4. Engine idling.
Sep 19, 2011 | 2001 Audi A4
How do you check transmission fluid
How to check & change oil in automatic transmission on 1999 VW Passat
1.4. Engine idling.
Sep 18, 2011 | 1999 Volkswagen Passat
Looking for fill plug location on a 2000 audi s4 automatic trans. and what type of fliud to use? please help with diagram please
How to check & change oil in automatic transmission on 2000 Audi S4
At the bottom of the automatic gearbox (tiptronic) you will find 2 threaded plugs on below surface. First one (in front of the car) is for emptying = drain plug, and second one is for filling = filler plug. Tightening torque is 24 Nm for drain plug, and 80 Nm for filler plug.
1.4. Engine idling.
Please do rate my response. Thanks!
Sep 05, 2011 | 2000 Audi S4
My 2000 vw passet is reving high when going up a hill and very slugish it as 85000 on the clock and i av been recomenned to change the transmission fluid
How to check & change oil in automatic transmission on 2000 VW Passat 4Motion:
1.4. Engine idling.
The automatic gearbox oil capacity (drain & refill) is 2,6 ... 3,0 litres.
The front differential oil capacity is 0,75 litres. Oil type: SAE 75 W / 90 Synthetic.
The rear differential oil capacity is 1,5 litres. Oil type: SAE 90.
Another automatic gearbox type for 2.5 TDI engine:
Front differential versions:
Rear differential versions:
Feb 28, 2011 | 2000 Volkswagen Passat 4Motion
L have a 2000 vw 4motion need to change automatic gearbox oil how do l put in new oil and how many liters does it take
1.4. Engine idling.
Feb 19, 2011 | 2000 Volkswagen Passat 4Motion
Checking transmission oil 2003 audi a6 tdi auto
1.4. Engine idling.
Oct 16, 2010 | 2000 Audi A6
How to locate the transmission fluid filler screw ?
1.4. Engine idling.
Aug 17, 2010 | 1999 Audi A4
Gear oil top up audi a4 2.4 auto
1.4. Engine idling.
Please rate my response. Thanks!
Apr 16, 2010 | 1998 Audi A4
Atf Refill Accessory Toyota Adapter Logo
49 people viewed this question
Top Mityvac Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Mityvac Vehicle Part and Accessory Expert? Answer questions, earn points and help others
