Question about Saws
Hook-up 2 external speakers to toshiba 46" tv and keep internal speakers
  • 2 more comments
  • Don lineberry
    Don lineberry Oct 20, 2013
    The problem me and apparently other owners of the toshiba 46ux600u is a desire to hookup additional speakers (external of course) to produce a fill the room audio experience. Since I started researching a solution for my self I've learned several things to either add more variabableson this. toshiba states in manual asI understand it is that (1) If your using HDMI w/the Audio out port (these can be found on the back side next to each other
  • Don lineberry
    on viewers right(pg.12).This will mute the RCA terminals, last bottom two on side, viewers righ. (2) Using the Digital Optical audio output found bottom center cancels out internal speakers. This is the port toshiba manual states to use for external intertanment center. This amp or reciever may have signal problems if not digital compatible or optical cables are not used .The (3) and final item I came across is the use of USB ports for Audio output and use of a splitter, one USB to "any" USB on source split to 2 RCA males or bare wire which connect to speakers. SO with all this in mind. With my pc iusing the Toshiba as it's monitor. what connection path could I use to add external speakers to operate along side toshiba's audio system
  • Don lineberry
    OK. What ports (or terminals) do you use to connect t)
  • Don lineberry
    external speakers to toshiba 46' pc monitor and use WITH the internal speakers ,allworing together at the same time.
  • 124 Answers
SOURCE: need to turn external speakers on (ilo tv)
What is the model of the DVD player and the Television.
Posted on Nov 12, 2008
SOURCE: toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Posted on Nov 24, 2008
  • 14 Answers
SOURCE: External speaker hook-up possibility
Yes, its absolutely possible. You can connect external speakers from analog output of TV. Even you can use AV receivers available in the market which can be used to amplify OR process the tv sound with latest digital processing techniques, it would be very much pleasant than the sound from tv.
--Sandy
Posted on May 26, 2009
  • 92 Answers
SOURCE: hooking up external speakers to a VIZIO
There is only one choice of audio out and that is the optical out put which locate on the far right if facing back of TV.
Posted on Jun 16, 2009
  • 1099 Answers
SOURCE: external speakers do not work on my MacBook pro
Plug in your external speakers then go to system preferences then sound when in the sound control panel go to the output tab and select the external speakers as the device for sound output and of course at the bottom of the control panel make sure that the mute check box is unchecked and turn up the volume. Hope this helps
Posted on Oct 10, 2009
No sound from speakers,46 inch led tv,has sound on external audio
What kind of speakers are you connecting to the TV? The audio amplifier in the TV is only strong enough to drive the internal speakers in the TV. You have to use amplified speakers or route the audio through your sound system
Jan 04, 2017 | Televison & Video
No sound coming from internal speakers Toshiba Projection television Model 50h82.
Some TVs have a set up option to disconnect internal speakers when an external audio amplifier will be used.
Dec 29, 2016 | Samsung Audio Players & Recorders
How do I get external speakers to come on?
You can select the option at its sound menu. Get it, and select 'External speakers' which in turn switch off the internal speaker, and bypass the signal to the external speaker. But; the you can't bypass the audio output, but the audio signal output from the back of the TV to any external amplifier or so. If you've any doubt, contact any technician. Gopakumar Gopalan Google
Sep 16, 2014 | Samsung LN46A650 46 in. LCD HDTV
Troubleshooting
using the TV remote access the menu then go to sound settings and turn the speakers back on
Nov 10, 2013 | Sharp LC46LE810UN 46 in. LCD TV
External speaker hook up
If the internal speaker is hooked up, then unplug the set from the wall for 40>, and that will reset the audio processor if it is locked up, also make sure you are getting a audio signal from your signal source.
Jan 10, 2011 | Toshiba CN36V51 TV
Volume on tv is locked volume wont go up or down and not even able to put on mute
Go to Menu from remote.
Select "Audio" and confirm "Internal" speakers vs. "External". Internal is the built in speaker sna external is when you are using a surround sound or reciever for audio.
Check this and follow up.
Jun 29, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I hooked up my stereo amp to my external speakers that were also still hooked up to my tv. now I don't get any audio from my tv just a high pitch sound. Is this an easy fix?
Hi, I can help. It sounds like the TV internal speakers were turned off so that the only speakers to have sound were the external ones. Go to your menu and find the sound area. There you can tell the TV to send sound to the internal speakers once again and not to external.
Jun 21, 2009 | Televison & Video
No sound
there is a switch on the back of the tv that has internal and external speakers slection i would check that especialy if you have hooked up any new componants
Dec 07, 2008 | RCA P46924 46" Rear Projection Television
No volume
On the back of your set there are 2 switches that tell the tv whether you are using the internal speakers or the external speakers.
Make sure the switches are set to internal so the speakers in the TV receive the sound signals. If they're set to internal maybe the internal speakers are bad. Set the switches to external and hook up external speakers to the speaker terminals on the back of the TV. If neither setup works then it sounds like an output transistor or related parts.
Sep 01, 2008 | Proscan PS60690 60" Rear Projection...
Toshiba 32 in. model cf32c50
Good day.
Please check if your internal speakers are busted. Trying out the external speakers are good isolation to the problem thats why, you can pinpoint the problem to be in the audio section.
chris
Nov 03, 2007 | Toshiba 36A40 36" TV
Saws Logo
50 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
