How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770:
Insert an original simcard and turn phone on
Enter sim PIN if required
Enter 2945*#770#
From the menu that pops up select "SIM unlock"
Enter unlock code you received and press OK
The phone will then reboot and the unlock is complete
How to enter Unlock Codes to LG GB250 & GB220
Power on your phone without SIM card
Enter 2945#*505#
Enter unlock code and press OK
How to Enter Unlock Codes on LG GT505:
Enter 2945#*505#
How to Enter Unlock Codes on LG KP100:
1) Insert a not allowed SIM card
2) Press the unlock button
3) Enter the code
OR
1. Insert allowed SIM.
2. Booting (Request PIN Code, PIN Code enable)
3. In Idle Screen, Input the hidden number (2945#*20001#)
4. Input the number (above), go back to the idle screen
5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate:
6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:".
7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code
How to Enter Unlock Codes on LG KF390 and KF390q:
1) Insert a SIM Card from the network the mobile is locked to and turn it on
2) Insert the following sequence *#865625#;
3) Select 'Unlock USIM'
4) Select 'Network Lock'
5) Insert the unlock code
6) Reinsert the unlock code
7) Select OK. Done!
How to Enter Unlock Codes on LG Prada (e.g KE850, etc):
1. Switch the telephone on with Original SIM card inside.
2. Enter SIM pin if required.
3. Enter 2945#*8501# and press the call button (middle button bottom of the screen).
4. SIM unlock mode will appear on screen.
5. Enter unlock code
6. Select Reboot.
7. Switch phone off, and then turn back on again. Phone is now unlocked
How to Enter Unlock Codes on LG KE990 / KU990 Viewty:
1. Insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990#
3. A menu will pop up, select sim unlock:
4. Another menu will appear, select Network lock. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
How to Enter Unlock Codes on LG KG245 (Vodafone Australia):
1. Insert a Vodafone Australia working SIM card.
2. Ensure the phone is charged and then switch the phone on.
3. Optional Step: If the SIM card has a PIN, enter your PIN number
4. Wait for the phone to power up then enter 2945#*7101#
5. Select Menu , then go to Settings > Security > SIM Lock > Network
6. Select Deactivate and enter the 8-digit unlocking code provide for your handset.
7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
How to Enter Unlock Codes on LG KG800 or TG800 Chocolate:
1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2. Go to: Settings>Security>SimLock>Network
3. Select deactivate. Enter the unlock code
How to Enter Unlock Codes on LG C2000:
1. Insert non-Cingular SIM card
2. Power on the handset - phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM Unlock code
5. Select "OK" - the handset is now successfully unlocked
How to Enter Unlock Codes on LG U8150:
1. Switch ON your phone with a not allowed SIM card.
2. Compose: 277634#*#.
3. Go to menu "SIM Lock".
4. Enter the unlock code
How to Enter Unlock Codes on LG INCITE CT810
Power on phone with original SIM card
Type 2945#*810#
In the menu that appears select Sim unlock
Enter supplied unlock code
Your phone is unlocked
How to Enter Unlock Codes on LG F2250
Power on phone with Orange SIM card inserted
While in the Start menu type 2945#*3311#
Return to the startup screen
Press Menu key
Select Settings > Security
