Question about Sony Ericsson Cell Phones
Obex Protocol could not be initialized. - Sony Ericsson Cell Phones
    New Friend:
Mimi
Posted on Oct 18, 2013
How can call with nimbuzz
SIP (Session Initiation Protocol) is a protocol used to establish, modify and terminate VOIP telephone calls. Using SIP, you can make cheap calls to a landline and regular mobile phones. With Nimbuzz SIP support, you can make Internet calls via the Nimbuzz Phonebook feature by adding any SIP provider you already use. Costs depend on your SIP provider rates.
SIP calling is mostly used to make cheap international calls.
You can go to Options > Settings > SIP Accounts to register an account.
After that you can place VoIP calls via the Phonebook.
User Fring if you want to make free calls. It works on Yahoo Messenger and Gtalk so you can call your buddies available on Yahoo! or Gtalk.
Apr 11, 2011 | Nokia N73 Cellular Phone
How to turn on a dhcp on a rca model dcm425 cable modem?
Enabling DHCP at the Client To enable the Windows NT DHCP client, you must log on as administrator at the Windows NT client.
Normally, you enable DHCP as part of the installation procedure for Microsoft TCP/IP, however, you can use this procedure if you have manually configured TCP/IP:
  1. Run Control Panel and choose Network.
    The Network Settings dialog box appears.
  2. Under Installed Network Software, select TCP/IP Protocol and then choose configure.
    The TCP/IP configuration dialog box appears.
  3. Select Enable Automatic DHCP Configuration.
    A Microsoft (MS) TCP/IP message appears, indicating that the DHCP Protocol attempts to configure the server automatically during system initialization.
  4. Choose Yes.
    A MS TCP/IP Configuration dialog box appears, displaying current TCP/IP configuration parameters. The IP Address and Subnet Mask boxes are not available (grayed out) and the manually configured values are no longer displayed.
  5. Choose OK to return to the Network Settings dialog box.
  6. Choose OK again.
  7. Shut down and restart the computer.
To enable DHCP on a Windows for Workgroups client if TCP/IP is not installed yet:
  1. Use Network Setup to install the MS TCP/IP-32 3.11 protocol.
  2. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose Continue.
  3. Restart the computer to initialize TCP/IP using DHCP.
To enable DHCP on a Windows for Workgroups client if TCP/IP is installed:
  1. To access the Network Drivers dialog box, run Network Setup.
  2. Select Microsoft TCP/IP-32 3.11, and then choose Setup.
  3. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose continue.
    A message box appears indicating that the configuration of DHCP overrides any values established locally.
  4. Choose Yes.
  5. To initialize TCP/IP using DHCP information, restart the computer.
Dec 19, 2010 | RCA Computers & Internet
Can't pair Samsung C3053 with Motorola bluetooth. I have followed the directions to use the Bluetooth messenger (whatever that is) and have gone to (in order) Menu, Settings, Messages, Bluetooth...
any one of the cell might have newer ver of bluetooth whicdh other 1 cannot recongonise.... try some other bluetooth headsets of own brand
Apr 10, 2010 | Cell Phones
Error trying opening Obex File Transfer LG 265 script
did u reboot the phone,maybe it had to be refreshed
Mar 02, 2010 | LG RUMOR Cellular Phone
Trying to bluetooth from blacberry curve to iphone 3gs how do i do this
You cant due to firmware restrictions Iphone has a lot of em
Jul 28, 2009 | Apple iPhone Smartphone
Motorola v3
OBEX file transfer works if you have bluetooth. If not use BitPim or P2K commander or Motorola Phone tools with the drivers from here:
http://www.vzam.net/MEK/Default.aspx
Sep 14, 2008 | Cell Phones
Blueetooth help on my phone
iphone dosnt support OBEX.
obex is the method for file transfer. it only supports handsfree headsets. there is no method for file transfer via bluetooth, u wanna go for app "dropcopy" this is for file transfer b/w 2 iphones.
Jul 24, 2008 | Apple iPhone Smartphone
Replacing Comms board on iphone
wifi problem is common.....reset the network settings ...and then try ...it might help....or else restore the iphone. It will surely get sorted out. Bluetooth only works for the headset. You cannot transfer files using bluetooth since the OBEX protocol is disabled in iphone :(. Enjoy
Jun 18, 2008 | Apple iPhone Smartphone
Ring tone
This information is from the Motorola Customer Help web pages.
To connect your phone via USB to computer and access your phone's memory card:
On your phone:
  1. Press the Center Select Key
  2. Scroll to and Select Settings
  3. Scroll to and Select Connection
  4. Scroll to and Select USB Settings
  5. Scroll to and Select Default Connection
  6. Scroll to and Select Memory Card
    This directs the USB connection to your memory card. Attach the Motorola Original USB cable to the accessory port on your phone and to an available USB port on your computer.
question.gif How do I use my own ring tones on my phone?
space.gif space.gif answer.gif To put ring tones on your phone using Motorola Phone Tools 4.36c and higher:
  1. Start Motorola Phone Tools.
  2. Choose your phone's profile or create a new profile.
  3. Click OK to wait for a picture of your phone to appear or for your phone to be setup for the first time.
  4. Once the image of your phone appears in the lower right of your computer screen select Multimedia Studio.
  5. On the screen that pops up select Melody Studio.
  6. Select a tab at the top of the screen to find a source for a ring tone. (Samples, My Melodies, My PC, My CD, My Phone).
  7. Select an audio phone you wish to transfer or edit.
  8. Edit the file to your taste or simply choose Transfer to phone.
  9. The file will be put in your ringtone folder.
To transfer music to your phone via Bluetooth(The computer must have a Bluetooth Profile that supports OBEX File Transfer ):
Note: The steps you may need to use to transfer music via Bluetooth may differ from the steps used below. A PC and a Motorola PC850 Bluetooth Adapter were used in the steps seen below.
  1. On your computer
    1. Go to My Bluetooth Places
    2. On your phone
      1. Push Menu
      2. Scroll to and Select Bluetooth
      3. Scroll to and Select Setup
      4. Turn Bluetooth Power On
      5. Push Back (right softkey)
      6. Scroll to and Select Find Me
      7. Press Back several times to return to the home screen
    3. Double click Find Bluetooth Devices
    4. Let your computer search and find your device
    5. Double Click on Motorola Phone (Phone's default name is "Motorola Phone" unless you have renamed it in Bluetooth>Setup>Name
    6. Double Click on OBEX File Transfer on Motorola Phone
    7. Computer will be prompted to enter a Passkey
    8. Enter 0000 on your computer and press OK
    9. Phone will ask if you want to Bond with your computer. Select Yes or No
    10. Phone will then prompt you to enter the 0000 Passkey then press OK
    11. Phone will then prompt to Grant or Deny OBEX File Transfer
    12. Double click on audio Folder
    13. Phone will then prompt to Grant or Deny OBEX File Transfer
    14. Computer will now display a conversations and voicerecords folder. Copy and paste or Drag and Drop your m4a (AAC) or MP3 ring tones to the audio folder and NOT into the conversations or voicerecords Folders.
    15. Phone will then prompt to Grant or Deny OBEX File Transfer to complete the transfer
Note: By putting ring tones on your phone using Bluetooth or Motorola phone tools, you may not be able to remove the ringtone from your phone. Motorola is aware of this and in the future removing the user added ringtones
Regards,
Worldvet
Jun 10, 2008 | Motorola Mobility RAZR V3
Help!!
Have a look around for a program called OBEX.
Mar 08, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
159 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
