Question about HTC One X Android Smartphone Glamour Gray
Dial pad not working
DIAL PAD KEYS 4 5 6 NOT WORKING
How to access voicemail when dial pad is nessed up
You'll have to do that from another phone the process may vary based on your carrier but usually you dial your number and let the voicemail start. Press THE # key then enter your pin when prompted
Aug 15, 2016 | LG G2
MagicJack upgrade left me with a HUGE dial pad! How can I reduce the size of this key pad?
Here are a couple things I would try:
  • Ctrl and the minus "-" key will make some windows smaller.
  • If it's a particular resolution, say 600X400 pixels you can make it smaller, in relation to the desktop by increasing the resolution form say, 800x600 to 1080x768. You can then increase the font sizes so everything else is similar to the sizes they were before. But in some windows that open, the text might mot fit the limited window size..
Jul 29, 2014 | magicjack.com
What steps do I take to change the time on my NEC DTERM 80 phone system? I have already tried the Feature+9+# as well as the Recall+728 but those do not work. The first gives me an error message.
NEC Electra Elite IPK
  • 1 Press the "Feature" key on the phone system's main terminal. This is one of the Dedicated Feature keys and is located at the bottom left hand corner of the keypad.
  • 2 Dial 9# to enter the clock setting menu.
  • 3 Enter the hours and minutes using the key pad. For example, if it is 12:15, you would press "1," "2," "1," and "5."
  • 4 Press the "Recall" key on the bottom left hand side of the phone key pad to toggle between AM and PM.
  • 5 Press the "Feature" key to exit the system.
NEC Electra Elite IPK II
  • 1 Press the "Speaker" key located at the bottom left of the phone key pad.
  • 2 Dial "728" to enter the phone's clock menu.
  • 3 Dial the hour using two digits. Use military time for any time in the afternoon. For example, 1:00 AM would be "01," but 1:00 PM would be "13."
  • 4 Type the minutes using two digits ranging from "00" to "59."
  • 5 Press the "Speaker" button to set the time
Read more: How to Change the Time on an NEC Phone ' eHow.com http://www.ehow.com/how_7338757_change-time-nec-phone.html#ixzz1XUGjOOet
Sep 09, 2011 | NEC Dterm DTP 16D-1 Corded Phone
How do I change the time on my Panasonic KXDT343?
1. From extension 101, press the PROGRAM key.
2. Then, using the number pad, dial *#1234 (Display shows SYS-PRG #).
3. Using the number pad 000.(Display: 000 DATE / TIME)
4. Press the SP-PHONE key (Display example:'93 Jan. 1 FRI).
5. Press the SP-PHONE key again (Display example: 12:00 PM 24).
6. Enter the new hour using the number pad.
7. If you need to adjust the minutes press the FWD/DND key.
8. Enter the new minutes using the number pad.
9. If you need to adjust the AM/PM press the FWD/DND key.
10. Press the AUTO ANSWER/MUTE key to select AM or PM.
11. When finished entering the new time press the AUTO DIAL/STORE key.
12. Press the HOLD key.
13. Press the PROGRAM key to exit programming.
Jan 11, 2011 | Panasonic KXDT343 Phone
Cant do anything the padlock sign is on and I dont know how to remove it so I can upload my pics to pc thanks averil, greece
It sounds like you have put the photo's into a protected state.
According to Pentax guides, you may have inadvertantly set it to protect all photo's. To release this you need to:
Set the mode dial to >
Press the key/padlock sign button twice
Select Unprotect using the 4 way control pad
Press ok.
To unprotect a single photo
Set the mode dial to > and select the individual photo
Press the key padlock sign button once
Press ok.
Hope that helps!
Nov 18, 2009 | Pentax Cameras
I have a NEC Dterm80 I need to program a button on the phone to be my handset button so I may be able to use my handset. I dont what to have to call a DeltaCom tech in to program.
First and foremost we need to know what system you have. Then we can proceed with how to program the button.
NEC Elite 48, 192, IPK 1
First pick the button you want to program. Lets say button 13 in this example. Next check to see if that button is programmed by pressing Feature and that key. If that key says Vacant then it is available for use.
Next you will need to hit "Feature and 4" on that station to find the port #. Port # is Tel 10 for example. That means port 10 is where your extension resides.
Now type in "Feature, #, 0 *, 8974". The phone should say Program Mode. Now look at the Line Keys. These are the keys right above the # pad. Count from left to right 4 keys. Hit Line Key 4 and then type 12 on the dial pad.
Now that we are in key programming we need to enter the port of your phone. Make sure the blinking cursor is on the far left. If not press * to move to the left. Now enter 10 (port 10 or Tel 10) on the dial pad. The cursor should be right near the L. If not then press # to move to that position on the right. Remember * will bring you back to the left and # to the right.
This is where you are to enter the key #. In our example it is key 13. Dial 13 on the dial pad. Next we are going to change the key to a headset key by pressing "Recall, Line key 3". It should say H Set on the right. Now that you have the proper key set you need to hit transfer to write the programming. Remember to try and find a key that is not programmed, this will ensure that you don't undo any programming that is already in place.
Any other system other than the NEC 48, 192 or IPK 1 will not work.
Nov 17, 2009 | NEC Dterm DTP 16D-1 Corded Phone
My panasonic kx-tsc10mxw keypad locked
take this:
1- Press Function
2- Press Down button until menu “Change password” displayed -> ENTER
3- " Current password " : Press this Number "726276642" -> Enter
4- “New password”
5- 0000 ENTER
6- EXIT
7- Press DIAL LOCK KEY
Jul 12, 2009 | Panasonic Lands Phones
Jog dial and keypad is not working
my keypad is not activated how to use them and how to download via internet
Dec 01, 2008 | Sony Ericsson P910i Cellular Phone
Nokia N72 Geting a dialing problem pls help me
yes, this mobile have some technical problem
Eg. keypad, Ic
May 25, 2008 | Nokia N72 Cellular Phone
KEYPAD PROBLEMS
Dear Make is software if ur phone key are working on wrong function. if not ok then change the key pad ic (both)even not ok then its prob from CUP check might be possible that when u press the button with speed ur mobile goes on restart then its prob from CPU.
Mar 30, 2007 | Nokia 7610
HTC One X Android Smartphone Glamour Gray Logo
19 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
