Question about i-mate Ultimate 8502 Cell Phone
Software update - i-mate Ultimate 8502 Cell Phone
How do I update my kindle?
Kindle Keyboard 3G (Free 3G + Wi-Fi)
Your serial number starts with "B006"
Kindle Keyboard Software Updates
Mar 21, 2016 | Tablets & eReaders
How do I update my humax box?
Hello
You have to getin to this site for a software update to your Humax Foxsat.
(http://www.humaxdigital.com/freesat)
From ite main Menu, come to "Edit Channels" window and select the third option 'Software Update" and 'OK".
# When there is no new software to update, a popup will appear
# Software updates for products will be detected using the Automatic Update option
OTA - Over the Air Software Updates will be broadcast via satellite for the product when new updates are
available. Humax reserves the right for deciding when the software updates will be released.
Follow below to ensure that you receive the OTA Software Updates when they are released:
1* You are connected to a suitable satellite dish and are receiving the all of the freesat service.
2* The signal strength and quality are at a high level; if you are experiencing problems with the signal
then please do not continue with the download.
3* The product is in Standby mode each night allowing it to detect, download, and install the updates
when broadcast
Caution:
* Please do not unplug the product from the mains during the software update procedure; this can
cause the product not to operate.
* Please do not remove the antenna cable from the dish from the product during the update as this can
Note:
* For information on the release of new software or the changes made please visit www.humaxdigital.
com/freesat.
* The download can take between 5 - 10 minutes to complete.
* During the update process you will not be able to use the product.
* During the software update scheduled recordings will not take place.
* You cannot schedule programmes during software update
OK.
Sep 18, 2011 | Humax FOXAT HDR DTV Receiver
Hello... nokia n73 my device software is V4.0726.2.04,can you help me to update it?tnx and more power
first of all you have to download the software updater from the nokia webite..and once your done,connect your cellphone to the computer with a USB cable..
update software:
With device software updates and application updates, you can get new features and enhanced functions for your device. Updating the software may also improve your device performance. You can update your device's software using the Software Updater in your device or using the Software Updater PC application. Learn how to update your device's software using both methods.
It is recommended that you back up your personal data before updating your device software.
Warning: If you install a software update, you cannot use the device, even to make emergency calls, until the installation is completed and the device is restarted. Be sure to back up data before accepting. installation of an update.
Downloading software updates may involve the transmission of large amounts of data (network service). Make sure that the device battery has enough power, or connect the charger before starting the update. After you update your device software or applications, the instructions in the user guide may no longer be up to date.
Update device software using your PC You can use the Nokia Software Updater PC application to update your device software. To update your device software, you need a compatible PC, a high-speed internet connection, and a compatible USB data cable to connect your device to the PC.
To get more information and to download the Nokia Software Updater application, go to www.nokia.com.ph/softwareupdate.
Update software over the air Your service provider may send device software updates over the air directly to your device (network service). This option may not be available, depending on your device.
Warning: If you install a software update, you cannot use the device, even to make emergency calls, until the installation is completed and the device is restarted. Be sure to back up data before accepting installation of an update.
Request a software update
  1. Select Menu > Ctrl. panel > SW update.
  2. The device scans for available updates.
  3. Select the desired update from the list, and follow the instructions on the screen.
  4. If the installation was cancelled after the download, to start the installation, select Install sw update.
The software update may take several minutes. If there are problems with the installation, contact your service provider.
Jun 16, 2011 | Nokia N73 Cellular Phone
I WANT TO INSTALL RM 32.001
sir just download the nokia software updater from the below given link
link
se your phone's SW update feature to get software updates over the air or via Wi-Fi - no PC needed.
Please note that not all device updates are available over-the-air. To see what the latest version for your phone, see the "Can I Update" section of Device Software Updates.
To learn more about SW update and its benefits, see the "How to" section of Device Software Updates.
Set your device to alert you when new software updates are available.
  1. Select Applications > SW Updates.
  2. Choose the software you'd like to update.
  3. Follow the instructions.
You may also be able to update individual applications even if there is no software update available for your device.
Jan 05, 2011 | Nokia N79 Cellular Phone
How can i update my nokia n72 phone
by connecting ur phone with pc and the option 'update phone software'..................
Dec 24, 2010 | Nokia N72 Cellular Phone
For Nokia-6131 model what type of cabli to be used for software flashing & upgrading?
For Nokia handset you upgrade the software by using the normal data cable as well:
I will guide you to upgrade the software by using the normal data cable.
First you need to download the "nokia software updater" from Nokia site, Here is the website you can download nokia software updater:
http://europe.nokia.com/support/download-software/device-software-update
select the model, you will get download button.
Install the nokia software updater, Connect your phone to pc by using normal data cable:
Run nokia software updater.
you need an internet connection while doing the updating.
Follow the procedures in the nokia software updater, Once the process is done in the nokia software updater, it will update your phone software.
Note: Remember Never switch off the PC or Power or disconnect the phone while the updating is in phone this might damage your phone.
The normal data cable is DKU-2 series compatible.
The flashing cables are bit costly, so i suggest you to go by these above mentioned steps to update software by using normal data cable.
Any further issue you can contact me.
Regards
May 24, 2010 | Nokia N95 Cellular Phone
Need an update for magellan roadmate 1200
Magellan® RoadMate® 1200 Software Update Version 1.50/3.12 - Release Notes This update applies to Magellan RoadMate 1200. It includes the following features, fixes, and improvements:
Improvements:
  • Point of interest (POI) Search Improvements reduce POI search times
  • Map Draw Improvements improve zooming, panning, and time to display the map
The software update version corresponds to your current software version:
  • If you have software version 1.46 or 1.48, your software will be updated to v1.50.
  • If you have software version 3.10, your software will be updated to v3.12.
You can locate your software version by following these steps:
  1. Start at the Main Menu.
  2. Press the arrow on the bottom right of the screen.
  3. Select "User Options"
  4. Select "System Settings"
  5. Select "Next"
  6. Select "Product Information"
  7. Your software version is on the line titled "Firmware Version"
Download Update: (Click here:)
I WANT TO DOWNLOAD THIS UPDATE
Feb 07, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Nokia n73 after disconnecting from software updater is not workin
so u have messed with ur software update dnt wrry go in a nokia care nd tell them to update ur software version of phone ur owrk is done.....
Aug 30, 2009 | Nokia N73 Cellular Phone
Update nokian93 driver software
Install PC suite in your PC, connect your phone with pc through data cable
open PC suite, you fill see nokia software updater icon in it.
it will download nokia software updater to your pc,
after the installation you can update your software with Nokia Software Updater
Note: Before the updating process, recharge your battery, also network disconnection may cause harm to your cellphone during the process!
Mar 11, 2009 | Nokia N93 Cellular Phone
i-mate Ultimate 8502 Cell Phone Logo
16 people viewed this question
Top i-mate Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you an i-mate Cell Phone Expert? Answer questions, earn points and help others
