Question about Dell Inspiron Computers & Internet
Wireless aerial wire not connected - Inspiron Dell Computers & Internet
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
USE UR USB CONNECTION AND PLUG IN UR WIRELESS STICK..WHO SHOULD HAVE A CONNECTION TO PLUG IN UR AERIAL...
Posted on Oct 18, 2013
What do I hook the wire for illumination to on the vehical thanks
Illumination can be connected to anything that is live when the lights are on!
The blue antenna wire is live for power aerials, if you do not have a power aerial just tape it up to stop it shorting out! This will not affect your manual aerial connection!
Aug 13, 2015 | Jeep Wrangler 1998 TJ Sport Bestop
More Specific Toshiba Satellite M35X-S349 assembly
The long thin wires are the aerial wires that connect to the wireless card. they are normally a black and a white wire and they have a connector that attaches to the wireless card.
Nov 06, 2012 | Toshiba Satellite M35X-S349 Notebook
I have a wired network in my house. An aerial on my roof picks up a wireless signal from a transmitter/receiver unit in the village. I can also pick up a wireless signal from the same aerial. I want to...
You can, in most cases, connect a Wireless router to your POS and let your provider know the MAC address of the device and then go from there for setting up your network. If you don't wish to replace your current router you can connect the wireless router to the current LAN router and establish a wireless network from there. Make sure you set up WEP or WPA security on your Wireless network to keep other people from hacking or using it without your knowledge. This is normally the only requirement Service Providers place users establishing a wireless network.
Oct 12, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
Stereo wiring on mk4 golf r32? Fitted new stereo bit radio isn't working I Need to know what colour wire to connect to the power supply for the amplified ariel?
12 volt accessory or same wire that goes to red wire on stereo or cigarette lighter.
OR
What is the current draw on amplified aerial ? or are you talking bout electric aerial(up and down automatically ?) If current draw is really low like 500 milliamp or so then hook her up to blue wire (remote output) on back of stereo but REMEMBER this is LOW current and only meant to switch on amps and raise electric aerials etc.If you think amp on aerial is too much for it then run the rem wire to a 12 volt relay and wire it so that when rem triggers and closes the gate will be connecting an accessory wire OR perm 12v wire to aerial power . That way aerial ONLY turns on(POWERS UP) when stereo is on as opposed to other way where aerial will be powered up every time car ign or acc is turned on regardless of whether the stereo is on or not.
Jun 18, 2010 | Car Audio & Video
On a Panasonic radio/cassette player model-CQ-RD910 Len,which colour wire is the trigger/sender wire for an electric aerial/antenna to extend or retract the mast. The electric aerial/antenna drive motor...
The " Blue & red spotted " wire that is spare from the rear of the radio transpires to come from the " cold " side of the radio's on / off switch , and serves to be only energized when the radio is switched-on and slowly shuts down on supply voltage when the radio is switched off , thus giveing a supply voltage for the relay & switch over reed switches in the aerial / antenna motor unit for a short run-down-time , to change over and allow the aerial mast to retract , in readyness for when the radio is switched on again and the aerial/antenna mast will power up .
This trigger / sender wire is connected via a 2 amp. fuse through to the aerial / antenna power relay.
The main aerial power motor unit is fed via a 6 amp. fuse.
Dec 12, 2009 | Panasonic Car Audio & Video
Low signal strenth...looking for an antenna for a wireless connection for a laptop. Where can I find an antenna ? Local stores ? Walmart, Bestbuy, OfficeMax ? etc...
If you look on eBay there are hundreds of add on aerials that give you plenty of signal boost. I bought several recently and they really do work. I even added a +24dB booster on my main wireless hub now I can really use the power of wireless and roam away from the house and the office!
Just enter "wireless aerial" or "wireless antenna" as the search term and you shoud literally get hundreds of results.
Sep 12, 2009 | Computers & Internet
I have a CXSGT08HP sony car stereo. It was installed by a friend at home. The memory does not work. Can you tell me which wire is the memory wire and were i need to hook it up to?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hi Justtamera,
I’m attaching a wiring diagram which hopefully isreadable. I’ll also list the “where to”instructions for all of the other wires. It’simportant that several wiring steps be done in a particular order.
About the Memory Wire:
The memory wire is Yellow and should be connected to the +12 V power terminal (which isenergized at all times). First besure to connect the black ground (earth) lead to a metal surface of the car.
Important…
>>Before making connections, turn the stereo unit and carignition off to avoid short circuits.
>>Connect the yellow and red power input leads onlyafter all other leads have been connected.
>>The power antenna (aerial) control lead (blue)supplies +12 V DC when you turn on the tuner.
Hope this helps. Lemme know if you have more questions or would like me to email you acopy of the owner’s manual.
Thanks, and take care.
Gail :-)
Connecting the Sony CXS-GT08HP Car Stereo Unit
1. To a metal surface of the car
>First connect the black ground (earth) lead, thenconnect the yellow and red power supply leads.
2. To the power antenna (aerial) control lead orpower supply lead of antenna (aerial) booster amplifier
>Notes
>>It is not necessary to connect this lead if there isno power antenna (aerial) or antenna (aerial) booster, or with a manually-operatedtelescopic antenna (aerial).
>>When your car has a built-in FM/AM antenna (aerial)in the rear/side glass, see “Notes on the control and power supply leads.”
3. To AMP REMOTE IN of an optional power amplifier
>This connection is only for amplifiers. Connecting anyother system may damage the unit.
4. To the +12 V power terminal which isenergized in the accessory position of the ignition switch
>Notes
>>If there is no accessory position, connect to the+12 V power (battery) terminal which is energized at all times.
>>Be sure to connect the black ground (earth) lead toa metal surface of the car first.
5. To the +12 V power terminal which isenergized at all times
>Be sure to connect the black ground (earth) lead to ametal surface of the car first.
Important…
>>Before making connections, turn the car ignition offto avoid short circuits.
>>When your car has built-in FM/AM antenna (aerial) inthe rear/side glass, connect the power antenna (aerial) control lead (blue) or theaccessory power supply lead (red) to the power terminal of the existing antenna(aerial) booster. For details, consult your dealer.
>>A power antenna (aerial) without a relay box cannotbe used with this unit.
Nov 29, 2008 | Car Audio & Video
Can't heat radio
Hi There Laura,
For you to get radio reception then you will need an aerial...
The FM stations are very weak and thus need a good long aerial to collect these weak signals.
Some receivers need the aerial to be a "loop" so and on the rear of the receiver there will be a special two port aerial connector for the FM..
You dont say where you are but if you are in the "outback' then a good long aerial will be needed...
The same can be said for the AM radio signals these are much lower in frequency but still need an aerial.
There is a difference with the AM signals as they also need a good earth as follows.
On the back of the receiver there will be an aerial connector marked AM and it will show an earth connector and and aerial connector.
There needs to be a good earth connected to the earth connection and another long wire connected to the aerial connector.
The earth should be a metal spike about 500mm long driven into the soil outside in the garden
and connected to a wire which comes inside thru the window to the earth connector on the rear of the receiver.
The aerial wire must not be connected to earth at all, but insulated.....
this wire connects to the AM connector out thru the window and up to the nearest high point. Like a tree or a pole...NOT A POWER POLE as that dangerous.
When you connect to the tree use a piece of plastic rope or something to insulate the wire from what ever it touches, as the radio signals are not allowed to come in contact withthe earth until they get inside the receiver...
You can use a wire with a plastic cover on it if you like..
You may wish to ask your neighbour if you can look at his aerial connections and learn how its done...
He wont mind.... unless you are "outback" and the nearest neighbour is 100miles away..
That makes it more difficult.
If you get stuck ask here again and I'll pass on more detail for you..
Cheers for now
From YUBEUT..
Apr 29, 2008 | Durabrand W600 Shelf System
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
