Question about Dell Computers & Internet
Why dell n3010 aerial wire not connected? - Dell Computers & Internet
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 225 Answers
Explain the issue in detail
Posted on Oct 22, 2013
Wireless aerial wire not connected
USE UR USB CONNECTION AND PLUG IN UR WIRELESS STICK..WHO SHOULD HAVE A CONNECTION TO PLUG IN UR AERIAL...
Oct 18, 2013 | Dell Inspiron Computers & Internet
Web cam is not working. it shows plug in a supported device
There are two possible issues:
1. May be your wiring is disturbed and you need to take it to the technician.
2. And the most possible issue is that you need to upgrade the drivers of it.
Aug 10, 2013 | Dell Inspiron 13R (N3010), 14R (N4010),...
How to disable the dell inspiron n3010 touch pad? there is a button on the keyboard to press in order to enable/disable the touch pad; but it does not work.
If you want to permanently disable it, you can go to device manager and disable the driver. You can enable it if you ever want to use it again.
Feb 25, 2011 | Dell Inspiron 13R (N3010), 14R (N4010),...
I recently bought a Dell Inspiron N3010 in September. Within the first few weeks of purchase, the laptop blue screened me. I maintain my laptops very well, and avoid downloading junk programs, as well as...
driver or hardware problem if it is happening when using the web cam and mic then thats a good place to start update the divers for them and see if it takes care of the problem
Jan 28, 2011 | Dell Inspiron 13R (N3010), 14R (N4010),...
Stereo wiring on mk4 golf r32? Fitted new stereo bit radio isn't working I Need to know what colour wire to connect to the power supply for the amplified ariel?
12 volt accessory or same wire that goes to red wire on stereo or cigarette lighter.
OR
What is the current draw on amplified aerial ? or are you talking bout electric aerial(up and down automatically ?) If current draw is really low like 500 milliamp or so then hook her up to blue wire (remote output) on back of stereo but REMEMBER this is LOW current and only meant to switch on amps and raise electric aerials etc.If you think amp on aerial is too much for it then run the rem wire to a 12 volt relay and wire it so that when rem triggers and closes the gate will be connecting an accessory wire OR perm 12v wire to aerial power . That way aerial ONLY turns on(POWERS UP) when stereo is on as opposed to other way where aerial will be powered up every time car ign or acc is turned on regardless of whether the stereo is on or not.
Jun 18, 2010 | Car Audio & Video
On a Panasonic radio/cassette player model-CQ-RD910 Len,which colour wire is the trigger/sender wire for an electric aerial/antenna to extend or retract the mast. The electric aerial/antenna drive motor...
The " Blue & red spotted " wire that is spare from the rear of the radio transpires to come from the " cold " side of the radio's on / off switch , and serves to be only energized when the radio is switched-on and slowly shuts down on supply voltage when the radio is switched off , thus giveing a supply voltage for the relay & switch over reed switches in the aerial / antenna motor unit for a short run-down-time , to change over and allow the aerial mast to retract , in readyness for when the radio is switched on again and the aerial/antenna mast will power up .
This trigger / sender wire is connected via a 2 amp. fuse through to the aerial / antenna power relay.
The main aerial power motor unit is fed via a 6 amp. fuse.
Dec 12, 2009 | Panasonic Car Audio & Video
How I can down load audio driver for N3010?
Follow this link to the driver downloads page at Fujitsu. Choose Notebook PC > N series >N3010 and all of the drivers will be available to download.
http://support.fujitsupc.com/CS/Portal/support.do?srch=DOWNLOADS
Oct 18, 2009 | Fujitsu Siemens LifeBook N3010 Notebook
I have a CXSGT08HP sony car stereo. It was installed by a friend at home. The memory does not work. Can you tell me which wire is the memory wire and were i need to hook it up to?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hi Justtamera,
I’m attaching a wiring diagram which hopefully isreadable. I’ll also list the “where to”instructions for all of the other wires. It’simportant that several wiring steps be done in a particular order.
About the Memory Wire:
The memory wire is Yellow and should be connected to the +12 V power terminal (which isenergized at all times). First besure to connect the black ground (earth) lead to a metal surface of the car.
Important…
>>Before making connections, turn the stereo unit and carignition off to avoid short circuits.
>>Connect the yellow and red power input leads onlyafter all other leads have been connected.
>>The power antenna (aerial) control lead (blue)supplies +12 V DC when you turn on the tuner.
Hope this helps. Lemme know if you have more questions or would like me to email you acopy of the owner’s manual.
Thanks, and take care.
Gail :-)
Connecting the Sony CXS-GT08HP Car Stereo Unit
1. To a metal surface of the car
>First connect the black ground (earth) lead, thenconnect the yellow and red power supply leads.
2. To the power antenna (aerial) control lead orpower supply lead of antenna (aerial) booster amplifier
>Notes
>>It is not necessary to connect this lead if there isno power antenna (aerial) or antenna (aerial) booster, or with a manually-operatedtelescopic antenna (aerial).
>>When your car has a built-in FM/AM antenna (aerial)in the rear/side glass, see “Notes on the control and power supply leads.”
3. To AMP REMOTE IN of an optional power amplifier
>This connection is only for amplifiers. Connecting anyother system may damage the unit.
4. To the +12 V power terminal which isenergized in the accessory position of the ignition switch
>Notes
>>If there is no accessory position, connect to the+12 V power (battery) terminal which is energized at all times.
>>Be sure to connect the black ground (earth) lead toa metal surface of the car first.
5. To the +12 V power terminal which isenergized at all times
>Be sure to connect the black ground (earth) lead to ametal surface of the car first.
Important…
>>Before making connections, turn the car ignition offto avoid short circuits.
>>When your car has built-in FM/AM antenna (aerial) inthe rear/side glass, connect the power antenna (aerial) control lead (blue) or theaccessory power supply lead (red) to the power terminal of the existing antenna(aerial) booster. For details, consult your dealer.
>>A power antenna (aerial) without a relay box cannotbe used with this unit.
Nov 29, 2008 | Car Audio & Video
Can't heat radio
Hi There Laura,
For you to get radio reception then you will need an aerial...
The FM stations are very weak and thus need a good long aerial to collect these weak signals.
Some receivers need the aerial to be a "loop" so and on the rear of the receiver there will be a special two port aerial connector for the FM..
You dont say where you are but if you are in the "outback' then a good long aerial will be needed...
The same can be said for the AM radio signals these are much lower in frequency but still need an aerial.
There is a difference with the AM signals as they also need a good earth as follows.
On the back of the receiver there will be an aerial connector marked AM and it will show an earth connector and and aerial connector.
There needs to be a good earth connected to the earth connection and another long wire connected to the aerial connector.
The earth should be a metal spike about 500mm long driven into the soil outside in the garden
and connected to a wire which comes inside thru the window to the earth connector on the rear of the receiver.
The aerial wire must not be connected to earth at all, but insulated.....
this wire connects to the AM connector out thru the window and up to the nearest high point. Like a tree or a pole...NOT A POWER POLE as that dangerous.
When you connect to the tree use a piece of plastic rope or something to insulate the wire from what ever it touches, as the radio signals are not allowed to come in contact withthe earth until they get inside the receiver...
You can use a wire with a plastic cover on it if you like..
You may wish to ask your neighbour if you can look at his aerial connections and learn how its done...
He wont mind.... unless you are "outback" and the nearest neighbour is 100miles away..
That makes it more difficult.
If you get stuck ask here again and I'll pass on more detail for you..
Cheers for now
From YUBEUT..
Apr 29, 2008 | Durabrand W600 Shelf System
Computers & Internet Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
