Question about Kenmore Electric Smooth Top Stove
I have a Kenmore model 790.95322304 glass top stove. The eyes on tops work but the clock and oven do not. What could be wrong?
reg501
  • 413 Answers
SOURCE: Kenmore range model 790.90152300 the
The electronic oven controller has failed. The cost is around $160.00.
Posted on Jun 26, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
smartr10U
  • 1305 Answers
SOURCE: Can I replace the glass stove top on my Kenmore Range????
Yes! check at repairclinic.com you can find parts for your appliance. be sure to have your model number handy.
Posted on Jun 06, 2009
SOURCE: Kenmore 665-9580 error code ''E1 F2''
What happened I am getting the same error LCD Message.. TX... Steve in Florida
Posted on Feb 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore gas range, oven touchpad and clock are out
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
Large pop noise tonight while using oven, then problems where buzzer would come on by itself & lock oven. Oven does not work now, nor do the buttons make the usual noise. The stove top burners work...
Sounds like you overloaded a capacitor on the clock assembly. Before you replace the clock, you should check the voltage to your stove to be sure it's a steady 110 to 125 volts. But yes, it sounds like your combo clock brain got zapped.
Mar 07, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Have a Kenmore glass top stove model 911.95361590 I can't get oven or broiler to work.
I have a broken glass top for this model. Do you still have the top and are u willing to sell?
Nov 14, 2009 | Kitchen Ranges
sounds like you need to replace the oven temperature sensor.
Nov 07, 2009 | Kenmore Kitchen Ranges
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Open Questions:
Kenmore simmer select board problem The SS button tripped my house breaker. I haven't used SS since (button is now 'off') so not sure it is working - pretty sure it is not. Otherwise, all of the stovetop elements seem to work fine. The 'Element on' light works (on when any burner is on, off when they are all off). However, none of the 'hot surface' lights work for any of the burners now. Is this just a SS board component that needs replacing? Or the whole board? I do have meters and experience to fix if someone can link me to a schematic or steps to test. Whatever happened to the SS board appears to have prevented the 'hot element' lights from working. EDIT: the model info is 790.96223409 **************************************** EDIT2: I found a schem for this; as the SS board indicator light shares neutral wiring with the other lights, is there a simple fix to disconnect one of the connections to this part of the board wiring, so that those lights will work again while I'm waiting for a new board? Pretty sure I have a bad relay on this board and will need to swap the whole board out, but I'd like to be able to check that those other indicator lights and circuits are ok so when I do get a new board, everything will work normally. ************************************** EDIT3: I rechecked the stove around lunch today; it does look like my 'hot burner' lights now work (maybe a relay was partly stuck open or shut on the board?); so, I may only need a new SimmerSelect board. I'll check for anything that looks burnt when I have the time to pull the oven out and open up the back. I did get the time to turn on each burner to 5 or 6, make sure they all got hot, and then turned down and they do all seem to regulate ok. If my 'hot burner' lights stop working again/become intermittent, I'll drop another update here. It does appear these boards are a common problem - are the relays not designed for 'hot switching' on these, and the burner switch should be completely 'off' when tripping the SS switch? That would seem to be a design flaw, if so.
Sep 27, 2016 | Kenmore Electric Smooth Top Stove
See all Kenmore Electric Smooth Top Stove Questions
Kenmore Electric Smooth Top Stove Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
