Question about Creative Labs Audio Players & Recorders
My creative A235 right speaker wire pins are broken what should i have to do
3 Suggested Answers
  • 3940 Answers
SOURCE: Hi there, Due to space constraints, i had to
It should have little if any effect on the monitor, LCDs are not nearly as sensitive about EMP as CRT monitors were
Posted on Oct 15, 2010
  • 5 Answers
SOURCE: i want the image of cable pin of creative speaker
Thesee days, every speaker uses a 3.5mm jack. Its become a standard now.
Posted on Oct 15, 2013
How to connect the right speaker straight to the board of the main Creative A200 2.1 speakers? My male pin is cut and lost, I want to solder the wires straight to the board.
Look at the board and trace the route of the circuit on the board. solder it to the trace closest to where the pin is on the board. You should be able to solder it to the stub of the broken pin as well. Just make sure you have no solder bridges when you are done. Best practice if you can is to take a picture of the area before you start so you can see exactly what was soldered and compare it to your repair, any solder bridge will be obvious.Don't overheat things traces are easily ruined by overheating!
Jan 01, 2015 | Creative Inspire 2.1 A200 Computer...
How to fix creative A235 speaker main controller or right speaker not producing any sound
You must check the 9 pin connector and wire connectivity in the right speaker PCB board.
If you can post the pin and cable colour of attachment I may help. If you can draw circuit diagram of the small pcb in right speaker than it will be advantage.
May 22, 2014 | Audio Players & Recorders
Win 7 drivers for creative sbs a235 speaker
creative a 235 doesnot require any computer driver. Just plug into headphone jack and enjoy. If your headphone is working in the same jack and your speakers must also work. Use a working headphone to check the problem is with laptop or speakers.
Apr 20, 2014 | Creative Labs Audio Players & Recorders
I want the image of cable pin of creative speaker sbs a235
Oct 15, 2013 | Audio Players & Recorders
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
Creative Inspire 5300 Volume Control broken!
For those searching the answer "How to replace/repair Creative Inspire 5300 volume control":
Its simple : looking at the back of the suboofer, the pins are as follows from top right, clockwise : LED VDD , Balance pot middle leg, GND, pots + legs, Volume pot middle leg, on switch input. Connect one pots ends to GND and the other ends to pots +, connect a switch on GND and on switch input, anode of led to LED VDD, cathode to GND (there is a 1,8k resistor inside so no external resistor needed)
Dec 19, 2008 | Bose Companion III Computer Speakers
Creative Inspire 5.1 5200 Remote Wiring
Hi glopher
pin 1 (starting from far left when LED is facing up) = green
pin 2 = light blue/lime blue
pin 3 = black
pin 4 = yellow
pin 5 = pink
pin 6 = red
pin 7 = violet
pin 8 (far right) = blue
I hope this helps
Open345
May 18, 2008 | Audio Players & Recorders
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
155 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
