Question about Roland Music
Service center philippines - Roland Music
Where can I go to get my Roland mc 909 check out
Contact Roland in whatever country you're in for the service centers in your area. For instance in the USA check this link-
Roland Support Service Repair Service Center Locator
Apr 18, 2016 | Roland Music
Nearest authorized service center
First of all, it is never a good idea to post your full address online. At most, your Zip Code should be more than enough information for people to help find things like a service center.
But, to answer your question, according to line6.com/service_centers, the closest shop to you is:
Field Services
4215 North 16th Street Building B
Phoenix Arizona, 85016
Aug 14, 2013 | Line 6 Music
Where can I get my Fender passport PA system services in Brooklyn, NY
Here ya go:
  • Jeff Bloch's Amp & Guitar Center 1700 10th Ave Brooklyn, NY 11215 Ph: (718) 369-7080
Authorized Fender electronics Service Center
Sep 17, 2011 | Fender Passport Deluxe 500watt Sound...
My digitech rp 500 has power supply but it won't
Make sure you have the OFFICIAL Digitech power adapter. Universal adapters or those for MOST other pedals will NOT work... things may light up but you will NOT get audio. This unit requires an adapter supplying 9 VAC (not DC) at about 1 amp. These AC output adapters are not very common and people get the units without an adapter and try using universal adapters and they do not work. An AC adapter is used by Digitech so they can generate both plus and minus voltages internally. I don't know what your utility power voltage is in Cebu, so you need to get an adapter for your voltage that will give 9 VAC output and fit the power jack on the unit.
Sep 15, 2011 | Digidesign Digitech Control 2 pedal for...
I have a Gemini CDM 3600 combo unit. The Jog wheel doesn't work on the left cd. Any ideas on how to remedy? the unit only has about 5 hours of playtime on it but is over a year old.
You would have to get it to a service center. It could be the control or some supporting circuitry. If there is no service center near you. You can send it in to pro Line Music 215-736-8055
Jul 15, 2011 | Gemini Sound Products Gemini CDM 3600
My P150 model has a problem with power...had it fixed in local repair shop but works only for a while then goes back to the same problem..i person fixed it already gave up an told me to bring to a Fender...
How silly to replace all the capacitors without knowing they were bad. Usually the problem in these is NOT the caps. You say it is a problem with the power. That is NOT a symptom that gives us a clue of how we might help you.
May 11, 2011 | Fender 150 Watt PA System
We took our roland KR-177 to a roland service center and they said the motherboard was bad and they are no longer available. Where do i find a new motherboard?
The motherboard is probably not available... You haven't mentioned any symptoms of the problem you are having. Some service centers really don't want to be bothered and give up too easily.
Feb 07, 2011 | Roland Music
Where is the casio keyboard repair in the philippines?
Try this link:http://www.casio-intl.com/emi/
Oct 03, 2010 | Casio Music
Music Logo
50 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
