Question about Frigidaire FEF366DC Electric Kitchen Range
I have a Kenmore Model 790.95322 glass top stove. The eyes work, but the clock and oven do not.
  • 14 Answers
SOURCE: F1 - oven will not turn on
You can try turning the power off for a couple minutes then back on but this is typically caused by a stuck key or a faulty control board. Either way you're looking at needing a new control board.
Hope this helps.
Posted on Dec 22, 2007
rickzilla
  • 706 Answers
SOURCE: broken glass top on my gas stove
Hello Cathy,
Pretty much everything on earth CAN be replaced but it will become your call how much you are prepared to spend to accomplish that. I suggest you contact any Frigidaire dealer or repair site and provide them with your model number and ask for a replacement top price. Not sure that helps but it should get you headed in the right direction.. There are also many online appliance part sites that you can get a better feel for the cost of your glass top ..
Regards,
Rick
Posted on Feb 16, 2009
memturbo
  • 226 Answers
SOURCE: Can you replace electric eyes with glass top?
there is more to it than just replacing the glass .
and I'm not aware of any kits that allow this .
Posted on Mar 27, 2009
ameliorate
  • 19 Answers
SOURCE: Who can replace a Admiral stove glass top?
i cracked mine too. the tops cost enough to make you just wanna buy a new stove.
Posted on Jul 16, 2009
SOURCE: Frigidaire Stove clock resets to 12:00 when igniters turned on
I have the same problem. This is an intermittent problem, maybe once every 20 to 30 starts the clock goes resets and the appliance beeps just like if unplugged it and then plugged it in again. I’m an electrical engineer and this sounds like the microcontroller that runs the appliance is being reset by noise caused by the spark igniters. This is definitely a design problem. Separating the wiring of the igniters and the control board should help. When I get a chance I’ll have to connected an oscilloscope and look at the noise. The control board microcontroller reset pin probably needs an RC snubber or an isolated ground. If /when I find something more definite, I’ll place another posting.
Posted on Jan 18, 2010
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
Large pop noise tonight while using oven, then problems where buzzer would come on by itself & lock oven. Oven does not work now, nor do the buttons make the usual noise. The stove top burners work...
Sounds like you overloaded a capacitor on the clock assembly. Before you replace the clock, you should check the voltage to your stove to be sure it's a steady 110 to 125 volts. But yes, it sounds like your combo clock brain got zapped.
Mar 07, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Have a Kenmore glass top stove model 911.95361590 I can't get oven or broiler to work.
I have a broken glass top for this model. Do you still have the top and are u willing to sell?
Nov 14, 2009 | Kitchen Ranges
Kenmore 665-9580 error code ''E1 F2''
sounds like you need to replace the oven temperature sensor.
Nov 07, 2009 | Kenmore Kitchen Ranges
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Aug 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Frigidaire FEF366DC Electric Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
