Canon ir 3035
Out copy comes half side dark letters and half is light letters
SOURCE: Canon iR 3570
Open your top paper tray drawer and there should be a dial on the on the tray drawer (light blue). On there is different paper sizes. Turn it until you get "Ltr" and the paper is going up & down. This should fix the problem. We just had that same problem today and that's what the tech person told us. (Also, this dial only turns in one direction to the left). MMc
Posted on Nov 29, 2007
Cogz
  • 1326 Answers
SOURCE: canon ir c3200 copies are shake what i do
Is the copier making a load noise? You may have a broken driver gear in the fixing unit.
Posted on Apr 06, 2009
canontech
  • 1219 Answers
SOURCE: copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Posted on Jul 25, 2010
Testimonial: "so thanks"
SOURCE: I have a canon copier
this error is power related. reset the fixing error by pressing * 2 & 8 then * Go to function, clear, error switch off the machine then switch on
Posted on Sep 03, 2010
spinal
  • 287 Answers
SOURCE: I need to know how
Hello mhitt,
Even though you have a pretty new copier, the ability to print the meter reading is not available. I know it's crazy since other copiers have been able to do it for years. Only the most recent models of Canon copiers have this ability. To print the meter readings for your copier would require that you go into SERVICE MODE and print a report that has several pages of **** and if you know what you are looking for you can find it.You could use the REMOTE USER INTERFACE (RUI) and view the meter and do a "screen print". I know it's not a happy answer but its correct. I wish you well. :-) By the way, the main meter reading (designated 101) is the count of sheets of paper that have successfully exited the copier regardless of size. My company uses meter "102" which counts 11x17 as 2 clicks on the meter. You probably cannot see this meter unless a service tech programmed it in.
Posted on Mar 17, 2011
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jun 25, 2016 | Canon imageRUNNER 3035 Black and White...
Why are copies dark at top, light at bottom? - Canon IR 3300 Digital Copier but computerice print is ok good
1. Glass could be dirty, smoggy
2. Lid that is not closing on the one side.
3. Scanner unit faulty.
Nov 06, 2015 | Canon Ir 3300 Black & White Copier
IR 3300 copier. Why are copies half light and half dark?
Drum unit needs to be replaced. (and ordered if you dont have spare one on you of course)
Nov 01, 2015 | Canon Office Equipment & Supplies
MY CANON IR 3035 START UP PROBLEMS
you are not very clear in you problem but i think that maybe you have to make the firmware first of the copier and than if does not work change the hdd and again firmware.
Oct 31, 2014 | Canon iR3035 Copier
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Dirty copies
clean corona wires--heater roller and if did not success change the drum.
Nov 30, 2009 | Canon imageRUNNER 3035 Black and White...
29 people viewed this question
k24674
jasbo
jasbo
