Question about Leupold Wind River RB800C Rangefinder
When I place a new battery it will not last over a day
My 2009 Chevy Malibu just had a new battery put in within the last 60 days. Then I needed a new transmission. Got it fixed. Today my battery light comes on and stays on. What is this?
The light means that your battery is not being charged properly. It could be that when the transmission was replaced, they alternator belt was not put in properly or tight enough. I'd do the following:
1. Check battery connections to make sure they are clean and tight.
2. Check the drive belt to the alternator. It should be tight and not slipping.
3. If neither of the above is the problem, fully charge the battery with a battery charger so you can drive it for a while. Don't drive it without charging or you may get stranded. Don't let the battery run all the way down either or it may ruin it.
3. Check alternator output by driving to a nearby auto store or the place you had it repaired. They usually can check your charging system for free. The alternator could have decided to malfunction, although it's pretty new.
Good luck...
Jan 03, 2017 | AC Cars & Trucks
Rover 75 forum
the car as a wire connected to the chassis and he is descharging the battery. you have to go to a car electrician and look wall the cables to see where he is not isolated.
Mar 11, 2014 | Cars & Trucks
Chair was charged last night and now the power light flashes and chair will not move
NEW BATTERIES NEEDED TRY CHARGING CONSTANT FOR 16 HOUR IF POSS OR OVER NIGHT. IF BATTS KEEP FAILING THEN SERCH NEW BATTERIES ON THE WEB A PLACE IN WALES DO THEM NEXT DAY DELIVERY GOOD VALUE
Dec 24, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Our new battery won't charge up fully, and is gradually going down 1% every few days. Now at 95%. Just like why we replaced the last batter.
a battery will not hold full charge when its not being used it will slowly lose charge over time keep your battery in a dark cool place if it is connected to your thinkpad it will gradually lose charge
hope this helps
Oct 03, 2010 | IBM Lenovo ThinkPad T60 ThinkPad T60P...
Batteries only last a couple of days
The scale has a short and needs to be replaced, if it is new, or under warranty, return it to the place of purchase.
Sep 10, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
Panasonic toughbook cf-48 two batteries went bad within a day
Place battery in freezer for 2 hours / remove and recharge, might make it last longer. (Removes any "memory" in them)
Might be worth checking the charger to ensure its working OK. Just becuase the light is on doesn't always mean its working.
Mar 10, 2010 | Panasonic Toughbook CF-51 Notebook
Every time I put new batteries in (rechargable batteries or not) the camera will only last to take 1 or 2 photos then say the battery is flat. why is this and is it repairable?
If the camera has been exposed to moisture there may be condensation still inside the camera; this causes a short and cause undue drain on the battery. Will also eventually damage the camera. remove the battery and leave the battery cover off .Place the camera in a warm place for a couple of days, or aim a blow dryer into the battery compartment for a few minutes.
If that doesn't help,then it's probably a defect in the camera circuitry and it's not worth repairing with the low price of digital cameras these days.
Jul 23, 2009 | HP Photosmart M447 Digital Camera
New mouse, still has problems
Some mice eat batteries like they are nothing. I myself have a logitec wireless mouse and i must replace the batteries every two weeks. I would suggest getting another mouse.
May 24, 2007 | GE Wireless Optical Mouse
Leupold Wind River RB800C Rangefinder Logo
Top Leupold Optics Experts
ray gallant
Bill Boyd
Are you a Leupold Optic Expert? Answer questions, earn points and help others
