Question about Lands Phones
Answercall tt150 instructions
Phone only rings 3 times before the answermachine comes on, how do I change it? Please
WHERE CAN I GET AN INSTRUCTION MANUAAL FROM FOR A CORDLESS PHONE ANSWERCALL ct100
Google the model number and make. It will give you all the info you need, and where to get the manual.
Jun 12, 2017 | Lands Phones
I cannot set my phone to ring 3 times read instructions will not work phone rings ar least 12 times please help with this problem
There is usually a switch for that. May be dirty contacts. Try switching back and forth a billion times (if you cannot take it apart to actually _clean_ the switch).
May 18, 2015 | Lands Phones
Setting up answermachine for calls I need to set up answermachine for my calls after a certain number of rings
Hit and hold the number 1. This should bring you to your voice mailbox set-up. Follow prompts from there. If that doesn't work call your cell phone number from your cell phone.
May 02, 2011 | Samsung J700 Cellular Phone
INCREASE RING TONES FROM 3 RINGS TO 6 RINGS
Generally (without knowing what phone yopu have) you need to press menu, arrow up to answermachine or TAM then press OK then arrow up to settings or TAM settings then press ok then arrow down to answer delay/ring delay/ring number press ok then use arrow keys to adjust rings, when on required number, press ok.
Feb 25, 2011 | Cell Phones
Hai i am vino. i don't know how to download themes for samsung s3310 . pls help me...
Support for you phone can be found here:
http://www.samsung.com/in/consumer/mobile-phone/mobile-phone/multimedia-phone/GT-S3310ASAINS/index.idx?pagetype=prd_detail&tab=support
Mobile Phone : How to delete or download image / ringtones / wallpaper?
To download ring tone, picture and wallpaper you have two procedures. First get the Gprs activated by your Service Provider and download the same. Secondly get a data cable and download the same using Pc Link Software.
Through Gprs please follow the below mentioned steps:
Step 1. In the WAP browser, enter the URL. http://202.87.41.147/samsung/home_new.php
Step 2. Select Zone.
Step 3. Select option, (Game, image, Ring tone etc.)
Then follow the Instructions to Download images.
Through Data Cable please follow the below mentioned instructions:
For sending data from pc to mobile please use Pc Link software that is coming totally free with Samsung Mobile. For more information for data synchronization please refer to manual.
To delete a downloaded image,
Step 1. Go to "Fun box".
Step 2. Select "Download".
Step 3. Select "View Picture"
Step 4. Select "Option".
Step 5. Select "Delete".
Wallpaper can't be removed, you can only change it.
Trust this is what you are looking for. Please vote. :)
Dec 12, 2010 | Computers & Internet
Answermachine not picking up
I emailed Motorola support. Email bounced back and was redirected to their broadband support. Not what i needed at all. Tried again, same result. Gave up in the end and contacted BT who round a fault at the exchange which was blocking my Caller Id. Once they fixed this, the answer machine worked too. Weird. Especially as I plugged in an older phone earlier to test it and the answer machine on that one worked. Nil points to Motorola for support I have to say....
May 28, 2009 | Motorola Lands Phones
Remote access to doro answermachine
type in 4 zero's.but if you have changed the password from 4 zero's then type in the new password...i hope this helps
Dec 22, 2008 | Doro 830R Cordless Phone
BT Freestyle 2200 - my phone is linked to an answermachine at hom
It is possible that you accidentally turned off the ringer.
Here are the instructions for the ringer on the BT Freestyle 22000000000.jpg
Dec 17, 2008 | British Telecom Freestyle 2200 Trio...
Changing the time on dispaly?
1 press menu
2. press system program
3 press exit
4 press system
5 press time
6 follow time instructions
Mar 10, 2008 | Lucent Merlin Legend MLX-20L Phone
Lands Phones Logo
20 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
