Question about Nikon D7000 Digital Camera
When i take pictures pink lines appear on my monitor and my subject is not clear and sometimes cannot be seen at all. what is the problem? Is it on my lens or on the settings?. help me please...
    Top Expert:
  • Nikon Master
  • 6,702 Answers
I think you are photographing in life view. I can't reproduce the error on my D7000. I don' think is has to do with the settings nor with the lens. If you think it has something to do with the settings, try to put the camera back to factory settings, by pressing both buttons marked with the green dots for 2 seconds. One button is on top, the +/- button and one is the Qual button. Be aware that you lose all settings. There are two other possibilities to reset settings, that are less changing, look it up in the manual. One is in the menu recording options and one in the menu personal settings. Both the top lines in the menu's
Posted on Oct 25, 2013
Pink vertical line in acer aspire 4736z
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 09, 2009 | Compaq Presario M2000 Notebook
Pink tint in pictures taken using canon s500
CCD FAILURE !
Call Canon for FREE REPAIRS it is a known issue ask them about BAD CCD see this link for service advisory
RATE ME WELL !
Regards
Zohail
Jun 01, 2009 | Canon PowerShot S500 IXUS 500 Digital...
The screen is pink tinted
A pink (or any tinted) screen is usually an indicator of one of two things:
1. The cable going from the video card to the monitor is loose. Try adjusting the cable and see if the picture changes. Put pressure in all directions slowly to see if it clears up. If it does, you should change your monitor cable.
2. One or more of your CRT "guns" or "rays" is malfunctioning, causing the red gun to be too strong, or causing the green or blue to be too weak. This is difficult to fix... time for a new monitor. Sometimes you can get a little more life out if by smacking the monitor on the side.
May 13, 2009 | Acer Professional P211 21" CRT Monitor
Monitor screen with pink line
While I've never seen the stripe be pink, it's not impossible for it to appear that color. Your monitor is bad, and isn't easily or cheaply fixed.
Apr 30, 2009 | Computers & Internet
Display has gone bad with fine vertical pink lines
Connect an external monitor to your laptop, if you get a clear image on this monitor the the video card in the laptop is OK.
The fault could be a defective inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp. Most likely a faulty CCFL lamp.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) as reached the end of the life and all you need to do is replacing the CCFL lamp
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 06, 2009 | Toshiba Satellite 5205-S703 Notebook
Pink discoloration and vertical lines in light areas
Possibly a form of flare caused by including the light source in the image.
Jun 25, 2017 | Olympus FE-280 Digital Camera
Pink tint when shhoting in bright sunlight
Sane problem with C713, the view screen is dark and gives focus warning, then the pics come out with a pink tint. I believe it is the sensor or shutter problem. Can't get any solutions either.
Nov 12, 2007 | Kodak EasyShare CX7530 Digital Camera
Horizontal Lines
your camera needs repairs as the auto apparture system is not working.
Nov 02, 2006 | Canon PowerShot S500 IXUS 500 Digital...
Pink lines/dots in pictures
Pointing a digital camera directly at the sun can damage its sensor. You should have the camera checked by a qualified repair facility
Aug 30, 2005 | Kodak EasyShare DX4330 Digital Camera
Nikon D7000 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
