Question about Remote Start System
AVITAL 4103 CAR WONT START - Remote Start System
2 Suggested Answers
  • 171 Answers
SOURCE: AVITAL 4103 REMOTE STARTER STARTS BY ITS SELF
Check the alarm program it shoudl be programing to turns it On every 2 hours, or if you have a temperature sensor should be programed to turns it On when is too cold.
Posted on Jan 05, 2010
Id there a way to program the remote on a avital 4103....thx mark
Yeah, get new remotes from you car dealerships. Not cheap though. They can probably change the chip inside your remotes.
Feb 11, 2015 | 4103LX 4Button Remote Start System with...
Ford f150 Avital 4103
You can put an amp meter on the battery, an amp clamp meter is easier and safer or a multimeter with 20 amp rating or better, find remote starter unit, find fuses for unit red wire on most starters is 12 v constant, you can put amp meter between the Avital fuse but there may be multiple Red wires or run the ampmeter on the battery + terminal through the ampmeter, DO NOT START THE CAR with the meter connected, just hook it up and close all the doors and wait 2 hours for all the car computers to reset and idle, record your amp readings, its tough to say what your truck actually drains per hour, I am guessing under 60ma is ok, remember when you open the car door you will activate the SJC computer "smart junction box in most Fords and it will drain current for a little while, disconnect your Avital and then see what the current is after an hour, remember most Digital volt meters shut off now after 5 minutes and you have to push buttons or flip knobs to activate them, doing this may disturb the current reading tests because you might open the circuit , try an old analog amp meter if you can find one.
Mar 01, 2014 | Avital Vehicle Parts & Accessories
I have an avital 4103 in my 2004 silverado. It won't unlock the doors and it starts but immediately quits.
There is a bypass module that communicates with the truck. It's in addition to the 4103 system. It's lost its programming or is disconnected. Sometimes you can unplug the module, turn the key on, plug module back in, turn key off, then on and start. All should be working fine again.
Jan 14, 2014 | 831002/4100 4100 REMOTE START SYSTEM WITH...
I need to know the steps ( opening driver door, turnig the key on n' off etc,etc. ) to activated the alarm 4103
The 4103 is not an alarm! It's a keyless entry and remote starter. So...what are you trying to do.
Feb 13, 2013 | 4103LX Remote Start System with Two...
I have a problem with my avital 4103 remote starter everytime i try to start try to start my car my car alarm goes off
If this is the factory alarm going off when you remote start the vehicle, the factory disarm wire is not connected. If you would list the year/make/model of the vehicle, I could direct you to the wire.
Feb 24, 2011 | 831002/4100 4100 REMOTE START SYSTEM WITH...
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
Hello. I have an Avital 4103 system and the key light on the dash does not go out after starting the car, inserting the ignition key and turning. I can drive the car, but the key light keeps flashing and...
I have a Dodge Caravan 2001 SE. Had the Avital 4103 installed. My question is, before installation i had a Chrysler car alarm in the van. When the remote start was installed they removed the alarm.
The shut down toggle switch was not installed, also the push button valet switch was not installed also. Is this a correct installation, I was told that I did not need the last two items to be installed.
Oct 27, 2009 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Remote Start System  Logo
73 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
