Question about Sharp Televison & Video
Tv trouble shooting guide
WHEN YOU SWITCH ON TV BOTH INDICATIONS ARE PRESENT P.ON AND STAND BY
    Top Expert:
  • Sharp Master
  • 75,320 Answers
It sounds that the power supply section do not get any start signal from the main digital board. The main board should be checked. This is not an easy work, that a normal user can do. It will be best to contact any service technician. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window
Posted on Oct 18, 2013
VIZIO VS470 WON'T TURN ON
do you mean the power indicator at the front panel doesn't light.ok this kind of trouble is in power supply section since the stand by doesn't work. the first place to be check is the fuse if blown. if blown with darkened color that was an indication that has other component part that get shorted. at this time you will need a proper trouble shooting using the a device like a digital or analog tester. if you don't have enough idea on how to do the job and necessary tools, just send it to the trusted service shop to fix the problem.thanks for using the fixya.
Aug 13, 2012 | Vizio VO370M LCD TV
The bike has power, but the turn signals don't turn on, it doesn't even acknowlegde that im pushing the indicator switches.
Contact me directly at wd4ity@bellsouth.net and I'll send you a trouble shooting guide for the turn signals. Don't forget to remind me of what you need.
Steve
Jun 28, 2011 | Harley Davidson XL 1200 C Sportster Custom...
The engine block indicator is on when engine running and only 2 sparks firing. loss of power.
the engine block indicator might be the computer check engine lamp. go to the local parts supply store that offer to plug into the computer to extract engine trouble codes. wright down all trouble codes. the trouble codes is only a guide for further trouble shooting.
May 03, 2011 | 2002 Mitsubishi Lancer
My le23r71b tv wont turn on red light on on/off button just flashing?
this kind of problem need trouble shooting then if you don't have an idea or experience you need qualified technician. anyway i can give you some guide so if you want to fix with your own . what you need is digital tester and capacitor checker much better. then open the back cover to access all the board for trouble shooting, smell burnt parts first and connectors. and then look for the power supply disconnect the connectors going to load side to isolate excessive load. then try to re connect the connector and turn on the TV check voltage going to control board, check busted fusible link observe the light indicator.then check voltage going to Y and Z sustain board if present, check all the fusible link if busted, check the Vs and the Va voltage.
Apr 24, 2011 | Samsung Televison & Video
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
I have a 1999 corvette showing trouble codes C1790 H, and B2606 HC can you help identify these codes
c1790 H ride control switch, the "H" indicates it has occurred at some point but is not present now. The H stands for history
b2606 HC is seat rear vertical position sensor failure. This code always appears as a history code. If this condition is current, your seat memory won't function.
Jan 15, 2010 | 1999 Chevrolet Corvette
Water is too cool for shower. Is there a thermostat?
I do not believe there is a separate thermostat. However the installation guide: http://www.eemaxinc.com/assets/files/FLOCO-install.pdf gives some trouble-shooting steps. More detailed trouble-shooting is here: http://www.eemaxinc.com/assets/files/floco-trouble.pdf
If the indicator light is off when the hot water valve is open: check your circuit breaker and the flow rate of water into the water heater (it must be over 1/2 gallon per minute). If those are okay, check the resistance of the element with a multimeter - 20 Ohms or less is good, 10,000 Ohms or so indicates a bad element. The trouble-shooting guide indicates the proper points to test.
If the indicator light is on, then check the flow rate at the shower head or faucet (reduce the flow until the water comes out hot), check that the unit is installed to the correct voltage supply and the resistance of the element.
If those are okay, then check that the printed circuit board is correctly installed and that the inlet filter isn't clogged.
After that, it's call the company for their technical support.
Dec 18, 2009 | Eemax EX95 "Flow Controlled" Electric...
Printing
Review online guide and trouble shooting for suggestions/
The manuals,online guide and trouble shooting sections could help you resolve your problem. Contact support has a chat facility on some pages that may help.
Click this Link
Under Select a Product Range
Choose Stylus CX5400 on the webpage
Under Select an OS
Choose the operating system1.gif on the machine where you will install the printer on the webpage
Click Confirm Selection
The manuals and documentation link will allow you to download manuals that were on your CD ROM
you may want to bookmark the online guide, if present, to help with future problems -- that probably was not on the CD
Click the back button on the browser
click the Drivers and Software Link
This allows you to download software files that were probably on your installation CD
Click the back button on the browser again
Trouble Shooting and Contact Support could be an interesting link in the future too when and if you have problems.
I hope this helps
Nov 19, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Help please
Click this Link
Under Select an OS
I hope this helps
Aug 31, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Televison & Video Logo
21 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
