Question about Jambu Camping, Backpacking & Hiking
Battery in shoe wont charge - Jambu Camping, Backpacking & Hiking
New battery new alternator battery still wont charge ??
91 , (is the charge lamp glowing key on, (shoe drops)?????
there are many ways to make it stop doing 13.3v to 15vdc running,
lots. ill list them all..
the 2 stated. in blue above. and.
1: bad dash lamp this lamp boot staps the field current or the alternator is born dead. so is it dead key on, , yes, BINGO.
2: bad alt ground, or starter top bolt , ground to battery bad or loose.
3: bad wires to the rear of alt. all 3.
4: bad battery cables. (or just corroded ends or conn. wrong)!!!
5: alt belt loose or missing.
6: engine hot RPM not 750 to 850 Rpm if 500 BINGO.
and more.
http://www.fixkick.com/Charging/charging.html
here is the drawing.
IS the sense wire is dead, not 12vdc.???
http://www.fixkick.com/Charging/charge89.jpg
the reg inside can shut the ALT down for.
over voltage
over current.
or if it THINKS(sic) that the batter internal resistances is too high. for ANY REASON what so ever. it will shut down
these protections prevents the ALt. from blowing expensive electronics (all of it) to kingdom come. $$$$$
its a feature.
Jul 08, 2014 | 1991 Suzuki Sidekick
Light up shoes wont turn off
The battery is in the insole and you can remove it
Mar 26, 2014 | Skechers Clothing Accessories
How to get light up shoes to light again
It depends weather the shoes you have contains battery or they are chargeable or not. But you can buy the new arrivals of LED shoes that can be charged and they will be used by you for years. You can also buy LED Shoes that are best of my knowledge. They are really cool for the night parties or the rave party. You can easily switch ON/OFF the lights of your shoes with the hidden switch. And they can lighten for hours once you have charged them fully. You will definitely love the cool look that you get with these shoes.
May 05, 2013 | Converse Clothing Accessories
Changed battery but still wont start
Hi Anonymous, first when checking anthing in the starter circuit you must make sure the battery connections are clean and tight especially the negative cable at both ends and has a 12.5 volt or better charge. It must not fall below 9 volts during the cranking procedure with a volt meter hooked up. If it does fall below 9 volts do a proper load test on the battery and replace if necessary. Second replace the starter relay cheap $6 and make sure it's well grounded and getting 11.5 volts or better to activate. Third remove the back cover of the solenoid and de-arc/refurbish the contact plate and shoes making sure they are tight. If it still chatters replace the solenoid. Good luck
Apr 01, 2013 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
How do you change battery in Carter's kids light up shoes
There is a battery in the insole. Lift the insole and the battery will be in the heel
Jan 20, 2013 | Carters Carter Match Light-Up Shoes at...
Camera Canon Rebel XSI not recognise flash 430Ex. The shoe looks OK and contacts on Flash the same
Clean the Hot Shoe and make sure there is no sulfur layer or dirt. MOst of the time its happens for Sulfur layer and not proper connection with flash shoe and camera shoe. Make sure all this and let me know. Also make sure the battery of the flash are fully charged and thats turn on mode.
Jan 06, 2011 | Canon Speedlite 430EX TTL Flash
Acer aspire 5315 batt problem
Please run this unit on A/C only and see if it powers up like that. If it does not, then the A/C adapter is faulty and thus cannot charge your battery.
Service the battery by hitting it flat onto your hand palm or onto the back of your shoe and retry to see if it is charging.
May 25, 2010 | Acer Aspire 5315 Notebook
It wont power up at all. I have tried batteries,
1 - Check the battery contact and make sure the batteries in the flash are good.
2 - check the plug for the turbo, make sure it is not damaged, as well as, the high voltage plug on the 580 flash. If those contacts look dirty or mushroom shaped, you will nee the flash repaired.
3 - obviously make sure the turbo is charged
Sep 30, 2009 | Canon SPEEDLITE 580EX TTL Flash
Tomtom300 gps mains charging +
1= My battery is flat, but when i put it on charge in the house it doesnt charge and no green light comes on, on my sat nav why would this be?
Could be your house charger is bad or the power connector on the back of the Tomtom is bad.
2= But when i put it in car charge it works perfect 'Y'?
You are using the "power shoe" to charge the battery. For a test unplug the power cord from the power shoe and hook it to the back of the Tomtom. If this work then the house charger is bad. If this doesn't work then the Tomtom rear power connector is bad
3= If ever i have to change battery how is this done?
You will have to remove the faceplate and disassemble the Tomtom in order to get to the battery. Or you can find a shop that repairs small electronic. Find the battery on Ebay.
Jan 12, 2008 | Tomtom GO 300 GPS Receiver
Camping, Backpacking & Hiking Logo
753 people viewed this question
Top Jambu Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Jambu Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
