When I type in an address it keeps sayig and printing hhh
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 57 Answers
Try to change the keyboard
Posted on Oct 20, 2013
My canon pixma mp495 printer keeps sayig papaer jam and pulls the paper in on one side only
There may be a bit of paper or a foreign object (paper clip, staple) stuck in the feeder rollers inside the printer. Lift and open every panel that you can and have a good look with a torch. pick out any foreign material you find.
Sep 17, 2015 | Canon Office Equipment & Supplies
My LG tv keeps sayig NOT PROGRAMMED
Try a hard reset first. Unplug the TV from AC mains wall socket, and re-plug it back after 30 minutes or so. This procedure must make it a hard reset. If it do not help you, be sure that its main system control memory IC is faulty. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 03, 2014 | LG 32LE5300 Widescreen 32 in. HDTV
Printer will not print the address onto the envelopes, it just keeps flowing them through
the envelope size is not selected in the printer properties. check the settings in the print properties and select the paper type as envelope and size of the envelope.
Oct 01, 2010 | Pitney Bowes AddressRight DA300 Printer
Printer keeps saying ram check and will not do anything else. No error code or anything. Just keeps sayig ram check
from what i know, some printers have a memory ram disk that holds the information for printing.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats. also see if there is information in this icon settings page about memory settings.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | OKI B4300 Led Printer
How do I memorize an address on this typewriter I need to memorize a sender and a send to address on a fedex form
If this is a WW30 on the L. side of the keyboard are three keys store, play and delete. To store hold the store key and type an address
01 - 99, release store, type info. press store again. To print it hold print type address release print, delete works the same way.
DickyO
Nov 04, 2009 | IBM Wheelwriter 30 Typewriter
IoGEAR printserver GPSU21 with VISTA
Yes, the GPSU21 is tested to work with Vista 32 and 64-bit Operating System. The things you need to do is listed below:
1. There's no need for you to install the CD that came with it, if the MFP Utility is already installed in another computer.
2. Get the IP Address of the GPSU21 from the computer that has the MFP Utility installed.
- Open the MFP Utility > locate TCP/IP at the lower portion of this window and click the plus (+) sign. > get the IP Address.
3. After getting the IP Address of it, go to your Windows Vista computer and ping the IP Address (just to make sure that Vista is seeing the Print Server).
- To ping, follow the steps below:
- Click the start menu and open the MS DOS Command Promt.
- On the black screen, type this "ping (type the IP Address of the print server): just like this
- C:WINDOWS\Desktop\Scott>ping 192.168.x.x and then hit enter.
4. Once you get ping statistics 4 packet sent; 0% loss. Then the Print Serve is communicating with Vista.
5. On you Windows Vista computer, make sure that the printer is working when directly connected to it. Because there could be a possibility that the printer driver is not properly installed that's why the server is not working.
6. On Vista, go to the Control Panel > Printers > Locate the printer icon (the one that is set as you default printer)
7. Right-click on the printer icon and then select properties > go to Ports tab.
8. Click on Add port button > select Standard TCP/IP > click on "New Port" (beside Cancel)
9. Hit next > type the IP Address of the print server. > Next
10. Click on Custom > Settings button
11. For Protocol: select LPR
12. For the Queue Name: type L1 > Click on OK > Finish.
13. Then under the printer properties, you will see the Standard TCP/IP is selected
14. Hit Apply so that the printer name would appear right next to that port > OK
15. Try printing a test page.
NOTE: After following the steps, you should be able to print using your Vista computer. I configured this print server with Vista several times and it does work with Vista.
Feb 19, 2009 | IOGear GPSU21 Print Server
Printer wont print (colured ink low) canon ip1600
TYPE IN ON ADDRESS BAR OR MENU
CANON PIXMA IP1600 PRINT ERROR 5200
ENTER
ROD
Feb 09, 2009 | Canon PIXMA iP1600 Printer
HHH Error Code
Generally, an HHH error code means the machine is sitll too hot from making the previous loaf. Keep the door open for a bit and allow it to cool down.
Dec 25, 2008 | Sunbeam 5891 Bread Maker
Maverick et 72 remote thermometer when it is turned on it reads HHH
If the receiver and/or the transmitter display LLL or HHH instead of the probe temperature,
wait for probe to reach room temperature. If LLL or HHH is still displayed it is likely the
internal probe wire has shorted out either through moisture or heat damage.
-Tha Mp3 Doctor
Nov 27, 2008 | Maverick Wireless Remote Smoker...
Computers & Internet Logo
David Payne
David Payne
