Question about Toshiba Office Equipment & Supplies
Sir, estudio212 photocopy machine showing tonner not reconised error. I already tonner replaced
    Champion:
  • 219 Answers
Be sure that the part numbers are exact, if still doing the same thing return and replace.
Posted on Oct 18, 2013
Patrillica
  • 141 Answers
SOURCE: Error code F35 on my konica 1212 photocopier
That's a fuser error condition...I'll have to get back to you because i have to check in my book to remember how to reset it...Thank you for your patient !
Posted on Apr 02, 2008
Cogz
  • 1326 Answers
SOURCE: canon ir 400 photocopier
What is the sub error code E805-" " -007 is is a blown fan and a blown fuse on the DC control. " " -002 could be a broken connection or pinched wire under the adf pillar on the right rear near the fixxing unit. If your have more info. on the code let us known..... Good luck
Posted on Apr 14, 2008
  • 990 Answers
SOURCE: Replace tonner catridge error
Dear Sir; You fill up the cartridge that's fine,but you forget to change RF chip, it located right behind the cartridge, if you don't replace it , machine not going reset .
Posted on Jan 10, 2009
spinal
  • 287 Answers
SOURCE: SIR IAM FAFCING THIS
Hello Om,
I gotcha fixed! The Canon IR3220 uses an infrared beam that detects the waste tonel level. So even if the bottle is truly empty it win't make the copier happy. Look at the "neck " of the waste toner bottle. If you look closely you will see a set of "windows"( Round disks) that the copier shines light through. When the waste toner level rises to the point that it blocks the light then the copier assumes the bottle is full. Now, even though you have emptied the bottle, those disks/windows are still clouded and so the light can't shine through. Clean them with a Q tip or remove them and clean them. You did it!!!!!! Aren't you smart!!! Please let "FIXYA" know I helped you. Have a good weekend,weekday, week life! :-) SPINAL
Posted on Mar 05, 2011
SOURCE: sir, i have samsung ml 1640, it stopped working after 2000 pages, gives message for replace tonner, i have already refill it, but it is not working
Pls open back cover of the printer and go to logic card ,there is a four leg small bios type chip. after the fund, pls take paper pin ang short the it's 1 and 4 leg's but don't catche the pin in hand when shorting it.
Posted on Nov 09, 2012
I am Thomas from South Sudan my Kyocera Photocopier 1635 Series error code : C6000.What to do sir?
Mr Thomas, this code means Fixing error, firsf switch on your Photocopier Machine then press 1,0,8,7 again 1,0,8,7 display will change will show u000. then press 1,6,3 press start key two times. machine will go off and on again. try that ,if will not work i will give you onather way.
Jan 20, 2013 | Kyocera Copystar CS-1635 Copier
Hi Sir. I got a problem of my Toshiba e studio 3510c printer, when I swich on the button, the screen shows there is a sentence said ;'disposal of the used tonner', should I replace the wasted...
It said exactly what? If it mentioned waste toner, emptying that tray (Toshiba has nice zero-waste-to-landfill toner recycling program) should have pretty much cleared things up; it appears that the sensor for that still sees lumps of toner..or something...coming up close to the paper path. Check it out carefully and replace the tray.
Sep 10, 2011 | Office Equipment & Supplies
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
Jan 08, 2009 | Xerox CopyCentre C118 Copier
Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Feb 19, 2008 | Office Equipment & Supplies
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
