Question about Electrical Supplies
Dek 6500 el
Need to make sure got wires put back in right order
  • 260 Answers
SOURCE: Just changed plugs and wires and engine is running rough.
google your make in model and the answer will find you. If it is still there check the timing and fuel filter
Posted on Apr 10, 2009
honeymokey
  • 3113 Answers
SOURCE: help w\spark plug wiring
Go to library and get a chilton repair manual.
Posted on Apr 19, 2009
motor1258
  • 6674 Answers
SOURCE: frustrated...can't seem to get spark plugs in right order
try this.
Posted on May 24, 2009
  • 118 Answers
SOURCE: 95 isuzu rodeo. 6 cylinder. hesitates, poor fuel
I would start with getting the right firing order you can look up the spec online at autzone on there site they always have diagrams than start by checking and making sure that your getting fuel either a clogged fuel filter or a bad fuel pump that is starting to go bad. Make sure you only have 1 fuel pump some cars have 2 if you have to chances are the one inside the gas tank is the one that 99% of time goes bad but check both for fuel coming out of them to be sure. To me it sounds like your ignition componenets need to be checked and make sure your confident on your firing order than start diagnosing .
Posted on Sep 24, 2009
daniel528
  • 142 Answers
SOURCE: TRYED TO PUT IN NEW CASE BUT PUT BACK IN OLD ONE
It sounds like a possible memory error code. See my previous post about checking the memory. Remove all memory sticks turn on and see if it sounds the same. Make sure memory slots are clean by using a can of air. Put one stick in. If you still get error beeps, try a different slot. If you still get error beeps, Try another stick of memory.
Posted on Apr 05, 2011
Change ram memory compaq presario 2200
1. Do buy the right ram for the laptop such as 512Mb/1Gb So-Dimm DDR PC2700.
2. Unplug the power source and remove the battery as well. Press the power button for 5 seconds in order to discharge all electricity.
3. Open up the ram compartment with the designated screw drivers and replace the old ram with the new one. Make sure the clip of the ram slot is clipping the ram ledge to make sure its installed properly.
Nov 16, 2013 | Compaq Computers & Internet
Need a replacement dek lamp with a asa code
DEK Lamps for Kodak Slide Projectors are almost always in stock at "Batteries PLUS Bulbs" retail outlets. If you don't have one of these stores in your area, try: www.bulbman.com
Jan 28, 2013 | Kodak Carousel 600 Slide Projector
I put new plugs in it started to skip so i put sparkplug wires on it still dose it what is the problem can u help
How sure are you that you put the wires back in the right order?: A dealer and see what the firing order is, and verify that you have the right club going to the right wire.
Jun 07, 2010 | 1999 Dodge Ram
Lost power wen i put new plugs and wires on
on 3.1 here is the firing order--1-3-5 is in back, 2-4-6 is in front. coil order from left to right. 5-2-3-6-4-1, on 2.4 it is--from left to right, 1-2-3-4.on 2.2 it is--left to right, 1-2-3-4 and wiring order is 1-3-4-2. hope this helps, also on 2.4 firing order is--1-3-4-2.
Sep 27, 2009 | 2001 Chevrolet Malibu
Replaced the plug wires, and now I have a slight miss at idle ?
Possibly a bad plug wire in the new set ..it happens.
Or you may have got two or more wires in the wrong firing order
Aug 27, 2009 | Nissan Pathfinder Cars & Trucks
I have an 85 and its backfiring out of the carburetor,i just re did the carb,and all top gaskets-intake manifold and valve cover,also put in new water pump and thermostat
Double check you spark plug wires to make sure you have the firing order right and aren't off time on the distributor. You should also re-check you timing.
Jun 24, 2009 | 1985 Chevrolet El Camino
Rewiring 1959 chevy el camino
Are you needing advice, links, tricks, or all of the above?
If it's advice you want:
If you are not buying an after market harness and all of the oem wiring is intact replace one wire at a time from the component all the way back to the fuse box. Its tedious but, it's a sure fire way to get it right the first time.
Secondly, I'd by a haynes manual or some other wiring diagram. Study it for at least a couple weeks or until you are completely comfortable taking on the task.
Color code your wires and label both the old and new ones with paper tape and a permanent marker so that you know what each one is for.
Last but not least, make sure that the battery is disconnected... ;o)
Jun 01, 2009 | 1982 Chevrolet El Camino
Power supply connection for pioneer eq-6500
top left - orange.....goes to aux or memory wire
top right - blue.......goes to the remote wire used with amps
bottom left - black.......goes to the ground wire
bottom right - red........this goes to your hot wire
May 31, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
Firing order for a 1996 EF ford falcon
EF & EL are 1,5,3,6,2,4
EF has a coil pack under the inlet manifold the EL has a distributor
EF uses a waste spark system so 2 plugs are fired at the same time eg 1 & 6 - 2 & 5 - 3 & 4
May 18, 2008 | 1983 Ford Fairmont
Electrical Supplies Logo
54 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
