Question about Garden
Pull start spool gardentec worn prematurely. - Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
If it's an off brand saw then who knows... I have never even heard of the brand
as for parts I hope you saved your manual
Posted on Oct 20, 2013
How do I change the spool on my gardentec strimmer
www.gardentec.cn/products.asp
Get a operating manual to find out how.
May 24, 2014 | Garden
Gardentec
http://www.gardentec.cn/upload/170-1.jpg
info@winplus-intl.com
I suggest you contact the above and ask where you can purchase the part,
May 14, 2014 | Garden
Purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
try Lowes or any Agway, and if that dowsn't work, try checking on line with your type of trimmer.
Apr 22, 2012 | Garden
String does not seem to feed automatically frequently have to take the spool out to re thread through the lottle holes
These things can be very sensitive with how the sting is coiled on the spool. Take your time and try to get it perfect. Look at the pre strung replacement spools for an example. also inspect the lever, usually under where the spool sits. Make sure its not to dirty and moves freely. After that when you want it to feed quickly pull and release the trigger a couple times. If you dont want it to feed the when you pull the trigger be sure to maintain how far you have it pulled back, then release it a little slower than usual. Lastly wait a few seconds before pulling again. If this doesnt work the lever may be worn out and defective. But they are super cheap and easy to replace.
Sep 11, 2011 | Homelite Consumer Products 4.0 Amp, 13 In....
WHEN YOU PULL THE PULLEY CORD IT SLIPS AND WONT START THE WHIPPER SNIPPER. IT DOESN'T GRAB ITS SLIPPING WHEN YOU GO TO PULL IT TO START. PLEASE HELP ME THAT WOULD
The piece on the recoil that engages with the fingers on the flywheel is worn. You have to get another spool that goes in to the recoil it is usually plastic and it wears.
Mar 19, 2011 | Garden
The recoil rope has pulled out of the chainsaw. How do I reattach correctly?
Did the cord break off or just lost the knot on the end? Remove the starter assembly from the case to expose the spool. You need to wind the return spring (turn the spool) CCW about 4-turns, then wedge it so that it doesn't unwind. Replace the cord if worn out and feed the cord end into the spool start point. Melt the end to prevent the knot from pulling out and tie an overhand knot in the end. Thread the cord around the spool 4 times, then feed the end out of the cord port, slide the handle on, melt the cord end, tie an overhand knot in the end, and tuck the knot into the handle. Pull the cord through several times to make sure it works correctly. Remove the wedge. Hope this helps!
Aug 12, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
The pull rope will not rewind. How do I reset it?
The cord should be removed from the spool entirely, then wind the spool spring CCW for a number of turns making sure the spool can be turned for about 6 turns more (during start). Wedge the spool so that it can't unwind the spring again. If the old cord was about worn out, replace it with fresh. Melt the cord end somewhat so that the knot won't pull out, then tie an overhand knot in the cord end. Feed it into the inner retainer on the spool, then thread the cord around the spool 5 or 6 times in a CCW direction. Once wound, feed the loose end out of the cord port, slide the pull handle on, melt the cord end, and tie an overhand knot on it. Stuff the knot into the handle and release the wedge from the spool so that spring tension pulls the cord tight. Pull the cord out several times to make sure nothing interferes with cord and mechanism, then install on the saw and check the start operation. The spring should never bind-up when the cord is fully extended. Hope this helps!
Jul 25, 2010 | McCulloch Garden
The starting cord has broken and I need to make repairs . I would like some guidence
Take the housing off for the pull rope. Inside you'll find a spool. Take that off and underneath you'll find a spring. Replace the pull rope and connect it to the spool like the old one is. With the handle outside of the case run the rope through the pull rope hole then attach it to the spool. Wind all but a foot or so of the new rope back onto the spool. The spring will have a way of attaching to the case and to the spool. Attach the springs to the case. There will be a notch cut into one side of the spool. You need to lay the rope into this notch and then place spool back into the case at the same time attaching the spring to the spool. Don't worry about tensioning the springs. Once the spool is back in you need to start winding up the spool in the direction that tightens the spring. You'll need to make about 5-8 rotations depending on the length of the rope. At this point, position the notch in the spool even with the hole where the pull rope enters the case. Pull on the pull rope handle until you pull the slack rope back through the notch and outside the housing. Then release the rope and the slack should be pulled back inside the housing and wrapped around the spool. Here is a video on changing a pull rope on a lawn mower. The idea is basically the same.
http://www.youtube.com/watch?v=i3ZMVFi0yqY
Nov 27, 2009 | Ryobi Garden
Renew pull start cord
Go to smalleng.com they have video on how to do what you need. Check it out awesome website!
Nov 24, 2009 | Husqvarna Partner Gas Powered Cut Off Saw...
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
