4400:011A error Help. My pc won't boot. Diagnostics show several errors:. 0f00:065. 0f00:133C and 4400:011A Any advice
  • jayne Oct 18, 2013
    Thank you so much. Sadly, even after running diagnostics, I still can,t boot. Does this mean I need to have someone who knows what they're doing look at it?
    Master:
  • 359 Answers
Yes it looks like a Failing Hard Drive. I suggest you backup all your data. Press the F12 key at the Dell Logo, select diagnostics and run an extended diagnostics on your hard drive.
Posted on Oct 18, 2013
2 Suggested Answers
Quick-Tech
  • 83 Answers
SOURCE: hai i cant start my pc. when it strats an error
Your OS may be corrupted, you can do a recovery by pressing F11, F10 or F9. BE ADVISED THAT YOUR SYSTEM MAY NOT HAVE THIS FEATURE.
Posted on May 26, 2010
Hello I have a pc which is stuck on a reboot loop and pressing f8 won’t work, if it may help you the first image is of “rm” which I assume is the company of the pc but i don’t know can you help me?
have you also tryed f5 for safe mode. or try getting into the bios to disable automatic reboot on error. or to run diagnostics. or use the os boot disk to do repair windows. if it windows 10 it's much harder to do. boot it to the rm screen than turn off power switch, turn back on switch boot it again. may take 3 times before it goes to repair your computer or other diagnostics
Apr 05, 2018 | The Computers & Internet
Boot error "Remove disks or other media"
Set the hard drive to boot first, I find this fixes most boot errors.
Jun 07, 2012 | Dell Inspiron N4010 Notebook
Dell Inspiron 9100 running XP boots up but then won't work. Diagnostics results in the fololowing: --DST Short Stats Test-- Test Results: Faill Error Code: 1000-0142 Msg: Unit 4: Drive Self Test...
Hard drive has bad sectors. Before your replace your hard drive when getting this error, try this- Boot from a Windows XP CD and choose Repair at the first prompt to get the recovery console. Type "chkdsk c: /p/r" at the prompt. Repeat until there are no errors found. Exit and reboot. It worked for me.
Jun 14, 2011 | Dell Inspiron 9300 Notebook
I have a dell inspiron E1405 laptop. when i am not using it for half an hour after opening it it is going into the following error: error code: 0148 message error code: 2000-0148 message unit:...
Go to
http://support.dell.com/support/0148
For further support as you have a hard drive error.
Hope this helps.
How to run PSA Diagnostics
Article Summary: Instructions on how to run the PSA Diagnostics, and an Error Code list with possible solutions. Table of Contents:
  1. Start the PSA Diagnostics
  2. Error Code List
Step 1: Start the PSA Diagnostics
  1. Restart the system.
  2. At the Dell logo screen, press <F12>.
  3. new_note.jpg Note: Some systems do not have an F12 key, to access the boot options you have to press the <0> (zero) key at the Dell logo screen.
  4. At the One Time Boot menu, press the <Down> arrow key to highlight Diagnostics, then press <Enter> to begin PSA.
  5. Write down any error codes listed.
  6. Use the list provided in the next section to see what the error code means.
Feb 16, 2011 | Computers & Internet
Cannot boot - goeas into start up repair. Diagnostics test show errors with hard drive error code 0f00:075d
If you are running the Dell diagnostics and you get this particular message then the problem is with the Hard drive and it needs to be replaced.. Please call Dell at 18006249896 if you are in warranty so that they will provide free of cost.. Out of warranty.. Get a new hard disk from a local shop...
Sep 17, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Dell D610 will not boot to hard disc
in os installed not corrected driver (s).
1. when goin bott press F8 and select "Dont reboot when error..."
windows go in blue screen, and write to screen what still by error (file name)
2. Try boot in safe mode. Find and delete this file.
3. Boot in normal mode.
If dont work. Boot with help WinPE bootdisk and scan your system by Viruses and Malware
Nov 07, 2009 | Dell Latitude D610 Notebook
Dvd boot error problem....
That error probably came from the CD ,doing a search on "bootscriptor" returns several links regarding bootable CDs.
Jul 15, 2009 | E-Machines T5082 PC Desktop
Xerox Phaser 8500N Printer Error 09,037.45:9085
You have to go into Diagnostics. Once in Diagnostics arrow down to function menu.
Then select
Then arrow down to ClearISCfaults hit OK
follow instructions on screen.
Nov 24, 2008 | Xerox Phaser 8500/DN Printer
Computer giving error: "harddrive error press ctrt alt sup to restart" on start up please help.
Generally, such an error indicates the hard drive has had a severe failure and needs to be replaced.
If a portable, you can try reseating the drive. If a desktop, you can reseat the cables.
Check in the system BIOS, see if the hard drive is identified by size/model, if it is, then you can try running diagnostics on the drive to see if you can get a failure code.
if diagnostics pass, you can try booting to your Windows CD, and run tools like CHKDSK and BOOTCFG /rebuild to fix the file system.
But you are getting a BIOS level error from what you describe and that usually means replacing the hard drive.
Jun 30, 2008 | Computers & Internet
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
