Question about J Concepts Bar Codes 2.2 1/10 Truck Tire Gold 2 R/C Car & Truck
I used my obd1 tester on my 93 oldsmobile royale 88 and brought up two codes. 17 and 23. what do they mean and what problems can they cause?
    Master:
  • 377 Answers
You are better off going to autozone and have them find the problem totally free
Posted on Oct 18, 2013
Hey guys looking for a 87 oldsmobile delta 88 royal brougham MAP sensor location..looked almost everywhere except the inside of the Manifold..please help!! Will post a pic so you can get a better idwa of...
Here you go copy and past then click on the first picture. It's number 5. https://www.google.com/search?client=ms-android-americamovil-us&ei=59KZWYn7DcPymQG4yoOIDw&q=1987+oldsmobile+delta+88+royale+brougham+map+sensor+location&oq=1987+oldsmobile+delta+88+royale+brougham+map+sensor+location&gs_l=mobile-gws-serp.3...4920.20339.0.21667.21.21.0.0.0.0.406.5585.0j1j16j2j1.20.0....0...1.1j4.64.mobile-gws-serp..1.17.4932...0j0i22i30k1j33i22i29i30k1j33i160k1j33i21k1.dB-spKCclH4
Aug 20, 2017 | Oldsmobile Cars & Trucks
My 1983 oldsmobile delta 88 runs til it heats up. Then it stalls out and won't start til it cools off. What could it be?
When it stalls out, if it cranks good but won't start, have a helper crank it while you visually check for spark at the spark plugs. A spark tester from the auto store doesn't cost much, you can carry it in your glove box. If the engine is hot, wear gloves.
With temp issues check the coolant temp sensor. How long since a tune-up, I'd also want to check fuel pressure. Check for applicable trouble codes. Your obd1, you should be able to check codes, yourself. You use a jumper wire between the A & B terminals at the data link connector, usually lower edge of dash between steering column and driver door. Turn key just till the dash lights come on, no further. The mil on the dash starts flashing, you count the flashes to get the codes. Your looking for two digit codes.
Nov 21, 2014 | 1983 Oldsmobile Delta 88
Why does my 1990 oldsmobile 88 royale idle rough and hitch and buck when I accelerate fast?
First I'd double check the plugs were attached in the right order if you mix a couple up it can cause symptoms like this. An auto parts store should be able to tell you the firing order for your vehicle. Hope this helps.
Sep 12, 2014 | 1990 Oldsmobile Eighty Eight
1983 Delta 88: how much MPG does a 1982 Oldsmobile delta 88 royal...
Personal experience between 13 - 20 for most models with the v-6 and v-8. the 5.7l is about the most fuel efficient at roughly 17
May 17, 2010 | 1983 Oldsmobile Delta 88
Check engine light on code P1640
it means driver 1 input high hope this helps
Oct 19, 2008 | 1995 Oldsmobile 88
J Concepts Bar Codes 2.2 1/10 Truck Tire Gold 2 R/C Car & Truck Logo
98 people viewed this question
Top Jconcepts Vehicle Parts & Accessories Experts
Lawrence Oravetz
Mike
Stan Ford
Are you a Jconcepts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
