Question about Eton E5 Radio
My Eton E5 will not reset when I put a paper klip in the reset hole.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 16 Answers
Unplug the AC adapter. Remove the batteries. Press & hold down any front panel button for about 10 seconds. Repeat for any 2 more buttons. Then reset with the paper clip. Do not install weak batteries, or try to restart or reset the radio after it shut off because of weak batteries. Weak, dead, or shorted batteries, tend to make the processor inside or the reset function to screw up.
Posted on Jul 03, 2015
2 Suggested Answers
  • 3 Answers
SOURCE: Eton E5
This may be caused by a problem with some AC adapters supplied with these radios. (It is a known problem with the Grundig G5, which is supposed to be an identical radio.) I have read that you can request a replacement adapter from Eton.
Posted on Dec 26, 2007
Booting Fail
I assume you have that in a 8300?...
In any case.. try To warm-start (no diagnostic tests are run), press the Reset button for less than 5 seconds. To press the Reset button, insert a small pointed object (for example, an unbent paper clip) into the Reset button hole.
if you need more help. please give us more information!
Feb 19, 2016 | Nortel DS1404076-E5 8393SF 8 x SFP...
My eton E5 will not reset when I press the reset button.
Oct 18, 2013 | Eton E5 Radio
How to reset nokia e5
You got two ways to reset Nokia e5.
Soft reseting : Soft reseting can restore Nokia e5 user setting and soft reset will not erase any data like image , sound, video.
Press *#7780# on the screen and after few seconds soft reset will start.
Hard reset : This option restores the original oprating system from the rom. Press *#7370# on the screen and after few seconds you may put the security code and reseting process will begin. It`s recommended to back up data before hard reset.
BYE !!!
Sep 19, 2013 | Nokia E5 Cell Phone
Eton e5 sw shot
The SW FET preamp transistor, Q1, on the underside of the circuit board blows if a static electric discharge hits the whip antenna. In my case, a cat rubbing against me & the radio on a very dry winter day did it in. The back & circuit board has to be removed to get at it. The micro transistor & the solder connection are very tiny, so hard to replace. The antenna jack should still work, because the preamp is only for the whip antenna's SW reception. An easier solution would be to just run a wire from the antenna jack to the whip antenna, but you would no longer have the whip's preamp benefits, or just use a longwire antenna connected to the jack for SW. Also beware plugging into the jack disables the AM ferrite antenna inside, so you might not want anything plugged into it for AM reception because the internal ferrite seems to perform better than any external antenna.
Jan 17, 2013 | Eton E5 Radio
How to keep it on when you have pressed buttons i am not to sure about their function
Your question is too vague to be answered. I thimk you should consult the user's manual. Here is the link to it.
Aug 23, 2011 | Eton E5 Radio
Resetting an eton fr-360 weather radio. it will not come on even with new batteries. how do i reset it.
I had the same problem so I sent an email to Eton's customer service, this was their response and it worked for me:
Please use the following procedure to reset it. Please remove your AAA batteries and unplug the rechargeable battery. Let the radio sit for 30 to 45 minutes, then put them back in. To play it from the AAAs press and release BATT first, then POWER. To play if from the rechargeable, first press DYN/SOL, then turn the crank for 90 seconds, then press and release POWER.
To charge the unit with an AC adapter, plug in the AC adapter, press the DYN/SOL button and make sure that it reads SOL/DYN in the lower right corner of the display. Let it charge for about 8 hours. Make sure that it still says SOL/DYN and press the POWER button. It should play for about 5 to 6 hours, depending on the volume.
Apr 27, 2011 | Eton SolarLink FR360 AMFMWeather Radio
Tret
Don't really know what you're asking, but here's a link were you can download and print the full owners manual for your radio:
http://www.etoncorp.com/upload/contents/307/E5_Manual_US_062007_low.pdf
Bill B.
San Antonio
Apr 01, 2009 | Eton E5 Radio
Users manual for the grundig g5 shortwave radio
I can't find one either but there is a downloadable manual for the Eton E5 at Retrevo.com  Just search for Eton E5
Jan 24, 2008 | Grundig YB 400PE AM/FM/SW Radio
Eton E5
Aug 23, 2007 | Eton E5 Radio
My Garmin Streetpilot c340 is locked up.
There is usually a small hole somewhere on such units that lets you insert a paper clip or a pen to reset. It is often marked reset, but not always. Look for a round hole about 1mm diameter or less. On a Garmin such as yours it should be on the back. It might actualluy be to small for a paper clip, to you might try a safety pin or soething thinner. Make sure the hole isn't a speaker, as you might ruin it by putting a paperclip in. Also check your manual to see where the reset hole is located. It should state this in the trouble shooting section. My TomTom Go 700 has the reset hole on the mounting bracket on the underside.
Mar 09, 2007 | Garmin StreetPilot c340 GPS Receiver
Eton E5 Radio Logo
292 people viewed this question
Top Eton Audio Players & Recorders Experts
Mike carichael
Level 1 Expert
k24674
RobertFonner
RobertFonner
Are you an Eton Audio Player and Recorder Expert? Answer questions, earn points and help others
