Question about Bernina Sewing Machines
Maindrive sync failed - Bernina Sewing Machines
Feed dog timing
It would be in the Service Manual for your machine. That is a common adjustment that technicians make quite often. It's usually a matter of loosening one or two Allen screws, adjusting to the correct position, and tightening the screws again. Sounds like over time, the screws in your machine have worked themselves loose.
Mar 05, 2014 | Singer 2662
Invacare bed
your question was put in the sewing machine catagory,,you might want to put it in a different catagory, so someone can help you.
Jul 08, 2013 | Sewing Machines
Seems to be out of sync. makes a knocking sound, not catching bobbin thread.
Is the needle in facing the right way? Flat shank to the back.
The knocking sound could be your needle is bent too, have you just had a threading jam up?
I'd remove the needle plate and bobbin and threads, clean everything and oil, put in a new needle, then slowly move the flywheel manually and watch the needle action to see if you can identify where the knocking noise is coming from.
Failing that, I'd say the timing is out, take it to a serviceman. The thread's not locking is usually a good indication of this fault.
Feb 26, 2011 | Brother XL-5130 Mechanical Sewing Machine
MACHINE WILL NOT STITCH - SUSPECT IT IS OUT OF SYNC FROM HAND WHEEL BEING TURNED CLOCKWISE. hOW DO I SYNC THEW MACHINE?
That usually is not a do it yourself job, because you have to have the right tools and know how. Only problem is that to get it fixed will cost more than you paid to buy it. You can check in your area.
Jan 01, 2011 | Singer Pixie Plus Sewing Machine
Needle and bottom plate out of sync
check to see if your needle is bent.
Sep 02, 2010 | Sewing Machines
How do i put the bobbin case back in correctly?
The zigzag setting should not have caused it to jam up unless the tensions were off and the thread was bunching up on the bottomside of the needle plate. If you ever jam or break a needle be sure to replace it with a fresh new needle. A slightly bent needle will cause all kinds of problems.
When putting the bobbin back in make sure you keep a good amount of thread hanging out and manually turn the hand wheel around until the needle make a full rotation. The hook should catch the needle thread and allow you to pull the bobbin thread out through the needle plate.
If you jammed it really good it is possible that the needle and hook timing is out of sync in which case you may need to have it re-timed.
Jun 08, 2009 | Singer 6038 Mechanical Sewing Machine
Singer 2210/replaced gear/now needle bobbing cam out of sync
look here:
http://www.vacsew.com/repair/singer-600-timing.html
Apr 24, 2009 | Singer Sewing Machines
Sewing Machines Logo
265 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
