Question about Fujitsu AMILO PC Laptops
Return key failing to return to beginning of next line. only happening when working on work saved in cloud.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
IF THIS HAPPENED ..TRY TO GO TO SYSTEM RESTORE...MAKING SURE U PIC THE DAY WHEN UR PC WAS STILL WORKING WELL...AND ALL WILL BE OK...HOPEFULLY..;;.IF NOT GO TO SETTING....OR CHECK DEVISE MANAGER IF NOTHING IS TICKET WITH A YELLOW MARK....IN KEYBOARD...IF IT DOES ...CLICK RIGHT AND CLICK REPAIR...
Posted on Oct 18, 2013
Tip
How to add a tag / label cloud to your Google Weblog OR Blogspot Template
You can use several widgets that are available that require you to register and claim your like the leading website Technorati you will then be on their blogroll which you might as well do anyway. At the time of posting the widgets section is being revamped so if you just want a simple cloud just for your blog not linked to another site read on.
First you need to add Bloggers own Configure label widget through the dashboard., this may suffice for you needs but its not much of a cloud.
Next you need to add several lines of HTML code to your template in the editor I suggest you donwload it first for a backup copy should you make a mistake.
Next you need to do a search for this line of HTML code this the where you add the next two pieces of code
]]></b:skin>
Above this code add this code in place of the single line I suggest that you add a carriage return either side of it, you must not add it after the last </head> tag
/* Label Cloud Styles
#labelCloud {text-align:center;font-family:arial,sans-serif;}
#labelCloud .label-cloud li{display:inline;background-image:none !important;padding:0 5px;margin:0;vertical-align:baseline !important;border:0 !important;}
#labelCloud ul{list-style-type:none;margin:0 auto;padding:0;}
#labelCloud a img{border:0;display:inline;margin:0 0 0 3px;padding:0}
#labelCloud a{text-decoration:none}
#labelCloud a:hover{text-decoration:underline}
#labelCloud li a{}
#labelCloud .label-cloud {}
#labelCloud .label-count {padding-left:0.2em;font-size:9px;color:#000}
#labelCloud .label-cloud li:before{content:"" !important}
]]></b:skin>
<script type='text/javascript'>
// Label Cloud User Variables
var cloudMin = 1;
var maxFontSize = 20;
var maxColor = [0,0,255];
var minFontSize = 10;
var minColor = [0,0,0];
var lcShowCount = false;
</script>
NEXT : - Find this HTML code, best to leave Expand Widget unchecked, for the label widget and then replace it with the code in this download HERE
You need to then save your template and you will see your new label cloud.
You can change the details of the CSS section above to change the font typeface, size and colour if you want to for example to change the font to arial alter the line
change the font-family to one of your own choice like trebuchet.
#labelCloud {text-align:center;font-family: trebuchet.;}
If you do set the display to block you would probably want to change the sort frequency from alphabetical to frequency do this in the actual blogger label widget in the design dashboard. also change the display line from
display:inline to display:block to get the a flat listing.
on Jul 10, 2010 | Google Chrome
Problem with spacebar key
I don't quite understand why this would happen after pluggin in a USB mouse - but I've seen it numerous times after a liquid has been spilled on a keyboard.
Sounds like you need to replace the keyboard. Best way to test this is to plug in an external usb keyboard and see if you can type normally on it.
If the laptop keyboard exhibits this behavior, and the external keyboard doesn't - you should replace the laptop keyboard.
Dec 30, 2012 | Dell Computers & Internet
What says home or end keys
it is primarily used to return the cursor to the beginning of the line where the cursor is located. When the text is not editable, the home key is used to return to the beginning of the document; this can also be done in editable text if the key is pressed along with control.
The home key can also be used to highlight all the characters before the cursor in a certain line if pressed along with shift in editable text.
The home key will take you to the beginning of the line you are on - try it, type a bunch of stuff then hit the Home key and you will be brought to the beginning of the line. If you are in a multi-line document, hitting CTRL+Home will bring you to the start of the entire document.
Similarly, the end key will take you to the end of the line while CTRL+end will take you to the end of the document
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 18, 2010 | HP 381068-001 Pavilion ze2000 Keyboard
I will be driving down the road and my jeep will just die on me and I can't get it started again. I wait about an hour and it will suddenly start.Happens about 2-3 times a week and I can't figure out what...
Most often that is a symptom of a fuel pump beginning to fail. As it runs, it begins to overheat and bind. After it cools down, it frees itself up and then works again. However, the same problem can also be caused by a crank position sensor going bad.
Next time it happens, turn the key on while someone listens to hear if the pump (inside the tank) is running. If not, likely that's what is failing.
Crank sensor can be tested with a digital ohmmeter, but many times it will not show up as bad until it completely fails.
Jan 28, 2010 | 1999 Jeep Grand Cherokee
I cant burn a cd in itunes when i try to burn a cd it says " the registry settings used by the itunes drivers for importing and burning cds and dvds are missing. this can happen as a result of installing...
    1. On the Start menu, click Run.
    2. Type regedit and click OK.
    3. Click the plus sign next to HKEY_LOCAL_MACHINE to expand the tree.
    4. Click the plus sign next to SYSTEM.
    5. Click the plus sign next to CurrentControlSet.
    6. Click the plus sign next to Control.
    7. Click the plus sign next to Class.
    8. Click to select the heading that begins {4D36E965- (don't click the plus sign here).
      It should look like this: ts2372_1.jpg
    9. On the File menu, click Export.
    10. In the dialog box that opens, make sure the "Selected branch" radio button is selected and save the file somewhere that you can find it.
    11. Right-click the LowerFilters key and from the shortcut menu, click Delete. Note: If you don't see a LowerFilters key then continue to the next step.
    12. If you see the UpperFilters entry right click on it and click Modify. Go to step 16. NB.If you don't see UpperFilters go to step 13.
    13. NB. If you don't see an UpperFilters entry you have to add it back in. Do step 14 and 15 to correct this.
    14. Right click on the right side of the screen and select New.
    15. Select Multi-String Value and name it UpperFilters. Go back to step 12.
    16. Select the entire contents of the text in the Value data text field.
    17. Right-click the selected text and from the shortcut menu, click Cut.
    18. Type GEARAspiWDM and press Return. Pressing Return adds a carriage return in the field and is important.
    19. Click OK.
    20. Restart the computer.
Dec 03, 2009 | HP Computers & Internet
Brother GX 8250: my problem is with the carriage.
Brother GX8250 typewriter; my problem is with the carriage. The return key returns the carriage to the original left-side position, but fails to advance to the next line.
Sep 08, 2009 | Brother Office Equipment & Supplies
Nakajim AE-710 Will not return to next line indents & makes noise
Check for debris below and around the carrier, put some light oil on the silver shaft that the carrier slides on (wd40 works well) DickyO
Jun 11, 2009 | Nakajima AE-710 Typewriter
Carriage return problem
The tab button may be stuck or the carriage release lever is stuck or a broken escapement.
Dec 24, 2008 | Smith Corona Wordsmith 100 Typewriter
Fujitsu AMILO PC Laptops Logo
21 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
