Question about Fujitsu Computers & Internet
Return key fails to return to beginning of new line when working in word. This only happens when working on work saved in the cloud. Can you help please?
    Sergeant:
    Champion:
  • 212 Answers
Same problem in key boards
please reinstaltion windows and software and slove the problme
Posted on Oct 22, 2013
2 Suggested Answers
  • 72 Answers
SOURCE: return key failing to return to beginning of next
IF THIS HAPPENED ..TRY TO GO TO SYSTEM RESTORE...MAKING SURE U PIC THE DAY WHEN UR PC WAS STILL WORKING WELL...AND ALL WILL BE OK...HOPEFULLY..;;.IF NOT GO TO SETTING....OR CHECK DEVISE MANAGER IF NOTHING IS TICKET WITH A YELLOW MARK....IN KEYBOARD...IF IT DOES ...CLICK RIGHT AND CLICK REPAIR...
Posted on Oct 18, 2013
2006 Jeep Grand Cherokee (WK) heater issues
cloud of smoke.
you let the smoke out because rule one was not done
remove neg, battery lug first
cars have powerfeeds all over that are hot, key off.
like head lights that is how they work key off
and the clusters, on jeeps have brain, that store data in memory.
this memory is hot all the time. (mine has 3 power feeds in my cluster)
so you you shorted this line , you did in fact burn something up.
that smoke was destruction.
why is a dealer all you know, there are like 100,000 shops in usa not a dealer, check out find ASE shop by ZIP
hark./ all highly trained.
did you scan the pcm to see what errors you have.
or test fuse? yes, test them.
fuses that bad , are bad, (boom)
fuse that seem ok, can be bad, called HAIR line crackes, some are deeply hidden in the fuse. we test them
did you run the cluster self test stated in the free manual>?
posted WK fsm
300 + times
here it is one more time
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
RTM read the manual first then leap. and win.
Oct 27, 2016 | 2006 Jeep Grand Cherokee
Tip
How to add a tag / label cloud to your Google Weblog OR Blogspot Template
You can use several widgets that are available that require you to register and claim your like the leading website Technorati you will then be on their blogroll which you might as well do anyway. At the time of posting the widgets section is being revamped so if you just want a simple cloud just for your blog not linked to another site read on.
First you need to add Bloggers own Configure label widget through the dashboard., this may suffice for you needs but its not much of a cloud.
Next you need to add several lines of HTML code to your template in the editor I suggest you donwload it first for a backup copy should you make a mistake.
Next you need to do a search for this line of HTML code this the where you add the next two pieces of code
]]></b:skin>
Above this code add this code in place of the single line I suggest that you add a carriage return either side of it, you must not add it after the last </head> tag
/* Label Cloud Styles
#labelCloud {text-align:center;font-family:arial,sans-serif;}
#labelCloud .label-cloud li{display:inline;background-image:none !important;padding:0 5px;margin:0;vertical-align:baseline !important;border:0 !important;}
#labelCloud ul{list-style-type:none;margin:0 auto;padding:0;}
#labelCloud a img{border:0;display:inline;margin:0 0 0 3px;padding:0}
#labelCloud a{text-decoration:none}
#labelCloud a:hover{text-decoration:underline}
#labelCloud li a{}
#labelCloud .label-cloud {}
#labelCloud .label-count {padding-left:0.2em;font-size:9px;color:#000}
#labelCloud .label-cloud li:before{content:"" !important}
]]></b:skin>
<script type='text/javascript'>
// Label Cloud User Variables
var cloudMin = 1;
var maxFontSize = 20;
var maxColor = [0,0,255];
var minFontSize = 10;
var minColor = [0,0,0];
var lcShowCount = false;
</script>
NEXT : - Find this HTML code, best to leave Expand Widget unchecked, for the label widget and then replace it with the code in this download HERE
You need to then save your template and you will see your new label cloud.
You can change the details of the CSS section above to change the font typeface, size and colour if you want to for example to change the font to arial alter the line
change the font-family to one of your own choice like trebuchet.
#labelCloud {text-align:center;font-family: trebuchet.;}
If you do set the display to block you would probably want to change the sort frequency from alphabetical to frequency do this in the actual blogger label widget in the design dashboard. also change the display line from
display:inline to display:block to get the a flat listing.
on Jul 10, 2010 | Google Chrome
Return key failing to return to beginning of next line. only happening when working on work saved in cloud.
Oct 18, 2013 | Fujitsu AMILO PC Laptops
Problem with spacebar key
I don't quite understand why this would happen after pluggin in a USB mouse - but I've seen it numerous times after a liquid has been spilled on a keyboard.
Sounds like you need to replace the keyboard. Best way to test this is to plug in an external usb keyboard and see if you can type normally on it.
If the laptop keyboard exhibits this behavior, and the external keyboard doesn't - you should replace the laptop keyboard.
Dec 30, 2012 | Dell Computers & Internet
What says home or end keys
it is primarily used to return the cursor to the beginning of the line where the cursor is located. When the text is not editable, the home key is used to return to the beginning of the document; this can also be done in editable text if the key is pressed along with control.
The home key can also be used to highlight all the characters before the cursor in a certain line if pressed along with shift in editable text.
The home key will take you to the beginning of the line you are on - try it, type a bunch of stuff then hit the Home key and you will be brought to the beginning of the line. If you are in a multi-line document, hitting CTRL+Home will bring you to the start of the entire document.
Similarly, the end key will take you to the end of the line while CTRL+end will take you to the end of the document
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 18, 2010 | HP 381068-001 Pavilion ze2000 Keyboard
June 2010 scrambled channels I have lost all channels they say they are scrambled - i have the correct keys installed, the emu is set to on. I have returned to factory setting then re set the emu - but...
dont factory reset the box at any time now redo your codes and make sure you save each line you put in if you dont save the lines you will receive nothing after you have imput both lines and saved them then turn the emu on you should be working ???now can you post the keys you have to help other people
Jun 13, 2010 | StarTech.com StarView SV221DVI 2-port KVM...
I'm trying to uninstall Panda Cloud so I can install the new version. I can't do that because it returns an error 11 status. (No Uninstall and no antivirus). If I go into security it says Panda Cloud is...
Re-install program then go to safe mode and use control panel / add/remove programs
If that doesnt work you can download from Panda a program to get rid of all files for Panda
failing that you need to know what you are doing (Do not attempt if you arent confident) by accessing the registry and deleting threads that have Panda in it.
NB = back up registry first.
Mar 30, 2010 | Acer Aspire 5100 Notebook
Carriage return problem
The tab button may be stuck or the carriage release lever is stuck or a broken escapement.
Dec 24, 2008 | Smith Corona Wordsmith 100 Typewriter
Ibm wheelwriter 6
1press and hold the code key and type the # 1 thru 99 wher you want to store the job(chose any one number)
2 the store light should blink
3 the ARtn light comes on
4 the carrier returnes to the left margin
4 the printwheel spins
5you may begin typing when the store light is on solid
6 let the carrier return automatically at the end of each line of type
7close the store when finished by pressing and releasing the store key
Mar 08, 2008 | IBM Wheelwriter 30 Typewriter
Computers & Internet Logo
22 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
