Canon color imagerunner c5185
DISPLAY FROZEN
color_50
  • 22 Answers
SOURCE: Canon Color ImageRunner - Tab Instructions
To be able to print using tab paper from the driver
Since the tab paper can only be fed from Stack Bypass, single reverse tab paper cannot be
used. The tab paper must be single forward.
1. Go to the printer and put some tab paper in Stack Bypass
2. Press Letter on C3200 LCD panel and press Next
3. Select Tab paper and press Done
4. Go to Windows Start menu and choose Settings
5. Open Printers folder
6. Select Canon iR C3200 PS3’s Properties
7. Click on Device Settings tab
8. Click on Form to Tray Assignment button
9. Making sure that Stack Bypass is highlighted and Paper Size is Letter, select
Tab Paper by scrolling down the Paper Type list
Page 2
Hint:
In order to print to Tab paper, it is necessary to select Tab Paper in the Form to Tray
Assignment dialog box before using this option. Otherwise, the option of printing to Tab paper
is not available from the print driver.
10. Click OK to close Form to Tray Assignment
11. Click OK to close Properties window
12. Open Word document called “tabs.doc”
13. Go to File menu and select “Print…”, and change the current printer to Canon
iR C3200 PS3.
14. Click on Properties
15. Click on Paper Source tab.
16. Select Paper Type option
17. Choose Tab Paper from Paper Type list. As soon as you select “Tab Paper”,
Conflict Information dialog will appear. Click on OK.
Page 3
Hint:
In order to change the tab position, click on Tab Position button. Clicking this button opens a
dialog box for specifying the width for shifting the image data to be printed on the tab part of
the paper.
Hint:
The conflict information displayed pertains to the finishing of the document. Tab paper must
be grouped, not collated. Since the default value for finishing is Collate, the driver
automatically adjusted the finishing option to resolve the conflict.
18. Click on OK to close the Properties window.
19. Click on OK to print the tab paper.
20. Go retrieve your output.
Note:
Please note that this procedure for printing on tab paper is not the same for all drivers. CCD
drivers would be similar to this procedure, but depending on the OS Platform, exact buttons
and steps would vary. However, from such drivers as imagePASS-C1 PS and Macintosh drivers
would work completely different from this procedure. Although we will not cover each
procedure step by step, we encourage you to take time to make yourself familiar with the
procedures.
Posted on Mar 15, 2009
color_50
  • 22 Answers
SOURCE: Canon imageRUNNER C2058 color network
The printer Board B1: you must shut it down by hitting the Options button and then selecting Function >Shut down > Shut down sytem>OK. Then power the machine off with the main switch. If the Customer has not been shutting off the machine properly and you get the please wait message you might try reloading system software first before replacing the hard drive.
Or = remove and reseat the printer board, if that doesn't work then you'll have to reformat the HDD unit and reload system software from a laptop. If the problem remains, the printer board may need to be replaced.
The Color Network Printer Board -B1 has a shut down function. It is for preventing corruption of the HDD. Be sure to turn off the main power switch after performing shutdown.
To properly shut down the Color Network Printer Board -B1:
1. Press the Option key on the control panel if the copier is in copier mode.
2. Make sure that the LCD reads Idle.
3. Select Functions on the LCD.
4. Select Shut Down from the Functions screen.
5. Select Shut Down System from the Shut Down screen.
6. The message 'It is now safe to power off the system' appears on the screen.
7. Power off the main power switch located on the lower right side of the copier.
* Note- After powering off the copier, wait at least five seconds before powering the copier back on.
kenezz6396
  • 64 Answers
SOURCE: Canon C5185 networked printer. Printed a 437
you are filling up you memory, inless you want to buy more memory, you have to do it in steps.
if you reduce the output quality to draft, you can get more pages per set.
Posted on Aug 11, 2009
PATHAMPAD
  • 25 Answers
SOURCE: Printing double sided color copies.
CHANGE YOUR DUPLEX PAPER SELECTION MOTOR
Posted on Oct 31, 2009
redzventures
  • 149 Answers
SOURCE: I need to set up my canon color imagerunner for wireless access
What model number is it? I don't think it has wireless printing! You'll need a wireless hub.
Posted on Nov 08, 2009
Please, my canon imagerunner ir c5185 printer/copier has the error message E000350-0000. How do I solve the problem? Thank you in advance.
Main controller PCB error.Check the connectoon between the main controller PCB and subcontroller.If not good replace one or another
Apr 03, 2015 | Canon Office Equipment & Supplies
Error code on display E0000045-0000
Canon imageRUNNER iR C2880 Color Copierchange the drum unit, or try to dismantle it and clean but these is not recommended.
Aug 23, 2011 | Canon imageRUNNER iR C2880 Color Copier
When checking the meter reading on my canon ir c5185, there are the following codes before the totals: 101 102 108 230 321 322. Can you tell me their meanings?
Hello joe,hope you are well.Canon copiers have literally hundreds of "meters " that the device is constantly monitoring.Things like the number of 11x17 scans,reports printed,incoming faxes,outgoing faxes,prints at 600 dpi....etc.Its wild.The device is capable of displaying to the customer a total of six meters.The displayed meters may be customized for the customer by a technician as per the customers request or needs.Each meter is named by a number,for example "101".That particular meter indicates the total of how many sheets of paper(regardless of size) that have successfully exited the machine.102 meter indicates the total number of sheets that have been output using 8.5 X 11' as the basis.So a sheet of 11x17 paper would increment the 101 meter once,but the 102 meter would "click" twice.For billing purposes my company keeps an eye on the 102 meter to maximize profit,as it should be.Now how Canon determined the display of the other meters you see is a mystery.Again there is a meter named 958,which is the number of documents scanned to the MAILBOX. So, to completely answer your question: 108 is the total black and white copies made regardless of size.230 is just color and monocolor regardless of size.321 is{your gonna love this one}color prints on 11x17.322 is color prints on 8.5x11.So there ya' go! TMI city!!! Hope this helps.
Jan 07, 2011 | Canon Office Equipment & Supplies
Canon IR C-4580 with Fiery controller
No, but the fiery will just speed up your prints etc.. I have the c3380 and c5185, they are stand alone with no fiery. If you are buying this machine for office coping it will be fine. But remember! this is a Buisness Color machine. In my customer base the 80's have done well as long as you run them as an color machine and not the office black and white work hourse. The color prints are great without any help from fiery. Sales people will try to sell you all!!!!
Jan 06, 2010 | Canon ImageRUNNER 1670F Copier
Sep 17, 2009 | Canon imageRUNNER C3200 Copier
jasbo
jasbo
