Question about Lavazza EP-850 Espresso Point Machine - [Red]
Hello and sorry for my bad English. Very often lately when i push the middle button, after i 've put the cartridge holding filter in its place AS TIGHT AS IT GETS, except of coffee, WATER falls FROM THE SIDES OF THE FILTER, no matter that the filter is completely tightend.
    Sergeant:
  • 347 Answers
Rubbers worn out, replacing them with new helps to solve problem
Posted on Oct 18, 2013
Replaced Frigidaire Pure Source 2 filter and it keeps popping out after about 10 min or after about 5 glasses of Water. This is not the 1st time we have replaced the filter. Could it be just a Bad Filter?
There was a redesign in the Puresource 2 filters (FC100 WF2CBs) that introduced a very very slight mismatch on the latching mechanism used. I've compared them and it's about a 32nd of an inch off. In the back of the socket where the cartridge is you will see two metal clamps. If you push the filter eject button, you will see them manually open and close. That is the mechanism that is not working due to the difference in the redesign. It is a design flaw in the new filters.
I understand it has been corrected but in the mean time, there are a lot of bad ones out there. If it does have this flaw, I've never been able to get them to latch in and hold. My final solution was to build a new sliding lever that would lock over the front of water filter and hold it in place. It's very easy to do. You just need to make a latch.
We are goint to Drill a small ( slightly greather than 1/8") hole about 1" to the right of the filter centered in the middle of the filter vertically. With the filter out, It should be hollow on the right side of the filter and you can reach your fingers around the right side edge and feel where the whole will be. Mark an drill your hole. It's 1/8" thick plastic and is easy to drill. Using stainless steel bolt, nut and washers a 2" flat metal with a 1/8" whole, and tighten it down firm and build a swinging latch. Push the water filter in place and close the latch. If the waterfilter has any room to play, try devising a wedge to hold it in place (the washer will do that, I used a little stickon rubber foot). The latch has to put pressure on the filter cartidge. Now try the water watching it. If done right, the filter will be held in place, no leaks or exploding waterfilters.
If your listening Electrolux/Frigidaire the old design was 100 time superior to the new design. It would be nice to be able to purchase the old model even if it cost a little extra.
Jan 01, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
When fax comes through paper is blank. I've tried 2 different cartridges
Replace the print cartridge
When you notice that the print becomes light or ink low or when install new ink
cartridge appears in the display, replace the print cartridge. The part number for
replacement cartridges is HP 701.
1. Take out a cartridge from its packaging and carefully remove the tape covering the
printhead.
Hold the cartridge by the colored top or black areas only. Do not touch the copper
area.
2. Press the Access Cartridge button on the control panel.
The cartridge carrier moves to the install position.
1 Access Cartridge
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
Care and maintenance 45
3. Open the control panel and cartridge compartment cover (it will click and remain
open).
4. Push the cartridge down and remove it.
5. To load the cartridge insert the cartridge as shown below. When the cartridge is
pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks
into place.
If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this
step.
1 Control panel
2 Cartridge compartment
cover
46 Care and maintenance
Clear jammed documents and paper
6. Close the cartridge compartment cover and control panel.
7. Press Start/Enter.
8. Press 1 for new cartridge, or 2 for the old one.
• When you put in a new cartridge, you must choose 1:New
• When you put in a used cartridge, choose 2:Used. This helps you to check the
correct amount of ink you have left.
TIP: If you mix up several used cartridges, it is not possible to check the correct amount
of remaining ink. Once you have put in a new cartridge, use it until it is completely
exhausted.
Nov 11, 2011 | HP 640 Inkjet Fax Machine
Just had a toner cartridge refill. The printer works but it still does not print
  • On laser printers, there is a "print head", and this could have died. I would try replacing the toner cartridge with a known good, barring that, the print head itself might have to be replaced.
    I am very familiar with replacing the print head on Lexmark laser printers, but I cannot speak for the Konica Minolta line as far as replacing it.
    Depending on the value and age of the printer, you might want to replace it rather than replace the print head as well.
  • It could also be a charge roller gone bad. This is the piece that goes in to the toner cartridge when you close the door, you can see where that is by closing the door partially with the toner cartridge out. If it is very dirty, you can try cleaning it with Isopropyl Alcohol and letting it dry FULLY before putting it back in place.
May 19, 2011 | Konica Minolta PagePro 1350W Laser Printer
Ink light of my tx101 keeps blinking
Hello, Amit.
From FixYa, give this a try:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Hope this helps.
Oct 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Ink Cartridge replacement
Downloadable Manuals please refer this manual.....
Sep 16, 2009 | Epson Stylus C48 InkJet Printer
Where do i change the ink on my canon mp830 pixma?
Hello paulphipps1,
That printer the ink is housed underneath the top portion of the printer. To open the top, reach down under the buttons or display area,, and left up, a blue plastic piece will slide out and lock the top into place. Once that up, look inside and the ink cartridges will eventually slide over to the left side of the printer. Look left towards the silver bar and you'll see two plastic holders for the ink. Take the ink cartridge out, by pushing down on the top edge of the cartridge, then out. To replace them, remember to remove the protective seal on the ink cartridge and put the ink cartridge in by holding the ink cartridge at an angle that has the copper control slip pointing upwards. Make sure you put it in below the top ridge of the plastic holders. Then once you slip the cartridge into the holder at the upwards angle, pull up again on the cartridge to snap it into place. That's it your cartridges are reset with new ink.
Good Luck
and don't forget to leave a rating based on my solution.
Mark
Apr 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannot take out the ink cartridge out of the epson aculaser C1100
You must follow these steps to replace the toner cartridges:
  1. Turn the printer on.
    getimage.ashx?id=912&w=
  2. Open Cover A.
    getimage.ashx?id=913&w=
  3. Push up the right lever to unlock the toner cartridge.
    getimage.ashx?id=914&w=
  4. Remove the toner cartridge from the printer.
    getimage.ashx?id=915&w=
  5. Take the new toner cartridge out of its package and gently shake the toner cartridge as shown below.
    getimage.ashx?id=916&w=
  6. Hold the tag and gently pull the toner seal upward and remove it.
    getimage.ashx?id=917&w=
  7. Insert the cartridge all the way until it stops securely with the arrow mark on the top of the toner cartridge facing toward cover A.
    getimage.ashx?id=918&w=
    TIP: Hold the cartridge in the middle as shown in the picture. Push it gently all the way through the rails. Make sure both sides of the cartridge are inserted at the same time. Keeping some pressure in the middle of cartridge until you hear a ‘click’.
  8. Push down the right lever to lock the toner cartridge.
    getimage.ashx?id=919&w=
  9. Close Cover A
Apr 02, 2009 | Epson Aculaser C1100 Printer
Compaq 5000 series JBL speakers
Hi Shockme17, sorry for late response I have been away. Gently remove the frame holding the material speaker cover by pulling it off from the top (the material speaker cover is just a push fit on the main body of the amp/speaker). Don't use any implement, you may damage the cover. Once you have worked the cover off iy will expose 4 screws holding the unit together. Remove those & the unit splits into two parts. JeffuH
Sep 05, 2008 | Compaq Presario 5000 PC Desktop
Hy- can you help me? mp 140
hello yah that tool dont work on this model what u can do is buy a new cartridge non genuine ink work fine on this printer very easy to refill to because original cartridge cost a lot u can also try to hold down stop reset button for more than 5 seconds it will override ink level check
May 26, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Error 1681 more than one Cyan cartridge installed
I have the same issue as well - I just open the printer, pop out the cyan cartridge, and reinsert it (the same one). This generally works - sometimes I need to do it once or twice. I figure I'll be patient and keep doing this until I a) finish the cyan ink cartridge, b) replace it out of annoyance, or c) through the printer out the window in total frustration.
Interesting to hear about "faulty" cartridges though - I shell out for the "authentic" Canon cartridges which you would think would be reliable - maybe I should switch to using the imitation ones if I'm going to have issues with them anyway...?
Feb 03, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Lavazza EP-850 Espresso Point Machine - [Red] Logo
54 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
