Question about Axis Communications O2 Oxygen Sensor 0808 Harley Softail Rocker Lambda (015000101
2003 Toyota highlander code po 155, oxygen sensor bank 2 sensor one replaced, check engine lite still on after driving 130 miles
  • 2,113 Answers
Did you take the battery off for a minute or more to rest the computer? A search of this forum comes up with a member saying that after market o2 sensors (being cheap) had to be swapped with a manufacturers O2 sensor then the issue went away.
Posted on Oct 20, 2013
I need help to confirm location of sensor 2 bank 2. CEL detect P0161. There are 4 sensors in which two are above the catalyc converter and two are below the converter. The part department staff says the...
that Toyota has a 2.4 l 2az-fe 14of 155 hp and ran from 2001-2007 after which a v6 engine was installed
the sensor is the one before the cat converter as it is a heated oxygen sensor (KO2S) and reports on the gas composition to the ECM for air/fuel ratio adjustments
the oxygen sensor (O2) is after the cat converter and reports on the cat operation
have the cat converter checked at an accredited muffler shop
Jun 21, 2017 | Toyota Highlander Cars & Trucks
Need to replace the Oxygen sensor at location bank 2 sensor 1 where is the location of this sensor.
find #1 cylinder that side is bank 1, bank 2 is opposite. sensor 1 is closest to manifold.
Jan 10, 2013 | 2003 Toyota Highlander
Error codes po 134 po 153 po 154 po 155 po 171 po 174
PO 134 = 02 SENSOR CIRCUIT NO ACTIVITY DETECTED (BANK 1 SENSOR1)
PO 153 =02 SENSOR CIRCUIT SLOW RESPONSE (BANK 2 SENSOR 1)
PO 154 =02 SENSOR CIRCUIT NO ACTIVITY DETECTED (BANK 2 SENSOR 1)
PO 155= 02 SENSOR HEATER CIRCUIT MALFUNCTION (BANK 2 SENSOR 1)
PO 171= SYSTEM TOO LEAN (BANK 1)
PO 174= SYSTEM TOO LEAN (BANK 2)
I WOULD SAY YOU HAVE FAULTY OXYGEN SENSORS CAUSING THE ENGINE TO RUN TOO LEAN REPLACE THEM AND YOU SHOULD BE BACK IN BUISNESS
Feb 23, 2011 | 2004 Suzuki Grand Vitara
I took my Toyota to autozone because my check
oxygen sensor bank 2 sensor 1
do you have a 6 cylinders engine?
this sensor is on the rear bank ( next to the fire wall ) before the cat
Mar 06, 2010 | 2002 Toyota Highlander
08 highlander...VSC & check engine light came on....
Code PO158= Oxygen sensor, bank 2 sensor 2. On a V-6 it will be opposite side of engine from #1 cylinder & after catalytic converter
Feb 05, 2009 | 2008 Toyota Highlander
'08 Highlander...VSC & check engine light came on....
Hello/ The P-0158 code realtes to the Oxygen Sensor.
Specifically, it is as follows: Oxygen Sensor Circuit has High Voltage; Bank 2 Sensor 2.
If it under warranty, take it to a dealer to get it replaced free of charge. If not, go tho a dealer and tell them that you want Oxygen Senso Bank 2, Sensor 2, and have them tel you where it is. Please do not buy an "aftermarket" sensor, they have been known to read incorrectly, and you problem will not be solved.
I hope that this helps you, and that you will award me a "FixYa" rating for my assistance. 4 blue diamonds. Thanks.
Feb 05, 2009 | 2003 Toyota Highlander
Axis Communications O2 Oxygen Sensor 0808 Harley Softail Rocker Lambda (015000101 Logo
91 people viewed this question
Top Axis Communications Computers & Internet Experts
David Payne
David Payne
Are you an Axis Communications Computer and Internet Expert? Answer questions, earn points and help others
