Question about NetGear Computers & Internet
8 digit pin
I have bought a wifi repeater for our apartment which is on the 3rd floor. I am trying to connect it to the Netgear of my landlady(which is located on the 1st floor) and it keeps on asking me for a 4-8 digit pin. This pin number isn't on the back of the router and she does not know the pin. Instead of resetting everything, is there another way to get this code?? The Wifi is not secured with a code, so I don't see why I need a code to connect to the router?
    Master:
  • 359 Answers
  1. Connect to the router with a network cable to one of the LAN ports
  2. Open the admin menu at 192.168.1.1
  3. Login with admin / 1234.
  4. Click on GENERAL SETUP -> WIRELESS -> SECURITY SETTINGS
  5. Set "Encryption" to WPA Pre-Shard key
  6. Set the WPA UNICAST to WPA2 (AES) or WPA2 (Mixed)
  7. Set the pre-shard key format to passphrase.
  8. In the field Pre-Shared Key type in the password for the wireless network. It should be at least 8 characters in length. Write down this password. You will need to enter the password when you connect with your WLAN clients to the network.
  9. Click APPLY and APPLY again to restart the router.
  10. Wait for about two minutes, then re-scan your WLAN networks on your Windows 7 system and connect just like before. Now you need to type in the password you set up under step 8.
Posted on Oct 18, 2013
  • 41 Answers
SOURCE: My dataone WA3002G4 (BSNL) WiFi router keeps resetting
Try to upgrade the firmware of the router.
Posted on Jun 03, 2009
redhaze89
  • 854 Answers
SOURCE: Netgear 824, security = intermittent WiFi connectivity
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Jul 13, 2009
anandg27
  • 1272 Answers
SOURCE: netbook wifi connection to netgear dg834g router
To connect to the wireless network of the router follow the steps below:
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
Perform the steps below on the concerned toshiba laptop to connect to the network:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Aug 03, 2009
lserni
  • 466 Answers
SOURCE: How to reset the security code on a NETGEAR Wifi
Remember that this will ERASE ALL YOUR SETTINGS from the router, so either note them now, or be sure to have your owner's manual available.
That said, find a paper clip or suitable object and stick it into a small hole behind the router. There's a tiny switch inside. Keep it pressed for 30 seconds with the router ON, and you'll see all the lights flashing once and the router rebooting in the default configuration. Connect with an Ethernet cable and reconfigure as usual.
If it's a stock Netgear, the username/password is either admin/admin or admin/password. Keep in mind that if you got the router from your ISP or cable provider, there's no telling what they might have done with the settings, and the above procedure might leave you with an UNUSABLE router (unusable until you call the technician who knows the new factory password, that is).
Posted on May 29, 2010
Geekman
  • 32281 Answers
SOURCE: my blackberry is asking to
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings ie. WEP, WPA, or WPA2 and the SSID Now configure the wireless card in your Blackberry, computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Sep 10, 2011
Why doesn't my netgear extender ask for name and password when I try to use it to connect to internet. It tells me that there is an authentication problem
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-...
Oct 26, 2014 | NetGear N300 Essentials Edition Wi-Fi...
Netgear wn2000 states mover closer to router?
This message means your extender is too far away from your wireless router to make a good connection. Repeaters must be within a good signal range for the connection to work properly.
If you have a wifi enabled phone, tablet, or laptop, you can walk around your home and see where the signal reaches and how well. Repeaters should be placed where you still receive full or close to full signal.
Repeaters may have issues if the wireless router is on another floor, behind metal, or too far away.
Jul 04, 2014 | NetGear WN2000RPT Repeater
Should be a sticker on the router or the box it came in.
Jun 23, 2014 | NetGear Computers & Internet
Netgear extender not connecting
There's quite a bit to know about using WIFI network extenders / repeaters. Have a look here;
Simple Wireless WIFI range extender expander repeater
Apr 07, 2014 | NetGear Computers & Internet
Setup wizard
the password should be the same password of your wifi on the router...
Aug 21, 2013 | NetGear WN2000RPT Repeater
Netgear wn2000 connect to bt home hub 3
got that ! netgear wifi extenders ? go to mywifiext net mywifiext Setup for Netegar Wifi Range Extender as i never had issue with my netgear by once my friend had ! and he came up with this website saying in case if you need help then just simply call them ! but i never had issue so ! hope this will help for you ! and there was a another website too Mywifiext net setup both serve free service ! about netgear wifi extenders and genie setup ' mywifiext
Feb 19, 2012 | NetGear WN2000RPT Repeater
I have an old Victorian house with an apartment in the back above the barn/garage. I am trying to get wireless internet connections to all sections of the house but my current router (3 years old) is not...
Hello.
Yes. As you mentioned, you have a Victorian house, with very thick walls. I'd suggest drawing a diagram showing the rooms and floors that need access.
First, if possible, I would place your router in a centralized location, if all 5 people need similar strength access.
Then what you need are multiple repeaters to go with your router. Place them strategically, so that the wireless access signal can bounce off of them and go around walls, instead of through walls and floors.
Hope this helps.
Nov 22, 2010 | Computers & Internet
Using a Netgear wireless-G router wgr614 with an Actiontec GT704W
Try to avoid the breaker box and furnace as mutch as posible. Also you could try both computers wireless and put the router on first floor.
Mar 14, 2009 | NetGear WGR614 Wireless Router
Archos 5 - Wifi keeps failing
reset the router to factory default ,then set it again ,sometimes routers need this ,you should information in netgear website .
Its pretty simple and try setting up wpa ,its more secure
Aug 06, 2017 | Archos 605 WiFi Digital Media Player
Computers & Internet Logo
212 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
