Question about Intermec CK30 Handheld Computer
Ck30 freezing up - Intermec CK30 Handheld Computer
    Sergeant:
    Champion:
  • 266 Answers
You must have a network issue or the CK30 experienced a power surge, if you have others that work, then that unit could be defective and needs service.
Posted on Oct 18, 2013
Need repair manual for Komatsu CK30-1 Compact Track Loader
Download Komatsu CK30-1 Compact Track Loader Workshop Service Repair Manual Download A30001 and up
https://sellfy.com/p/gq3Q
Nov 23, 2015 | Cars & Trucks
Goodman ck30-1l, outside fan trun on doesn't speed up and stops, what is wrong any ideas?
Your most likely issue is a bad run capacitor. It a small silver can that is usually located in the controls area of your condenser. If the fan has been replaced it could be mounted somewhere around the fan. It helps motors run and when they fail they will run half speed,
Jul 08, 2012 | Goodman CKL49AR49 Air Conditioner
CK30 is cold booting when I remove the main battery. The supercap battery status is high and I am not depressing the cold boot button in the battery compartment.
Hello jcapsto. It could be that the backup or 'flash' battery isn't totally charged for one reason or another. This little internal battery keeps a minute current going to the units' flash memory that holds settings and other data and allows warm boots. I would recommend putting your CK30 in it's cradle with the main battery in overnight. Then trying removing the battery and it should spring right back to life. If not, then I would pin the issue on your backup battery and would implore you to contact Intermec or the vendor you purchased it from about replacement/repair. I hope this helps to at least isolate the problem. Good luck!
Jan 08, 2010 | Intermec CK30
WHAT IS THE COOLING CAPACITY OF MODEL CK30-17? GOOMAN MANUFACTURING CORP., AIR CONDITIONER (CONDENSER)
It is 30,000 btu, 2 and 1/2 ton system. Capable of cooling 1200 square feet satisfactorily.
Nov 01, 2009 | Goodman Heating & Cooling
Goodman CK30-1A Central AC Unit will not run by thermostat
double check your t-stat wiring your not getting 24volts to the contact at the cond. unit outside
Jun 20, 2009 | Heating & Cooling
Intermec CK30 Error Opening Wedge Problem
I was getting the same error and resolved it by removing the battery and pressing the reset button. When you turn the scanner back on all the data will still be intact.
Apr 24, 2009 | Intermec CK30 Handheld Computer
Intermec CK30 Won't Display Desktop
The ck30 does not have a desktop. Press the green then orange key to access the system menu. Alt then escape will bring up the task manager.
Nov 27, 2008 | Intermec CK30
3G connection keeps dropping / device freezes
Not sure if you fixed this but I had the same problem with Intermec CK30's a couple of years ago, and it was in relation to the number of terminals using the same username & password to connect to the client server - might be a indea for you to check out.
Nov 07, 2008 | Intermec CN3
Green light stuck on.
Left the ck30 powered off and removed the battery. Replaced the battery with a fully charged one. After a couple hours rebooted the ck30 and it booted normally. My ck30 was tied to the AS400 system. I think this may have been a factor with this issue.
Sep 12, 2008 | Intermec CK30
Intermec CK30 Handheld Computer Logo
110 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
