Question about Aerocool XPredator Black edition black
How can you remove the top cover to fix the start button or replaced.
How to replace start button on whirpool duet model WED9200SQO
Hello. If the outer soft-touch button is damaged, you will need to replace the outer console assembly, part# 10116694. If the internal button is damaged, you will have to replace the "center user interface board) part# w10031410. This is an INVOLVED repair. If you haven't worked on a dryer, don't attempt this. The top cover must be removed by removing its screws at the rear of the dryer. Slide the cover back about an inch and lift it up. POWER MUST BE REMOVED AT THIS POINT. The control panel has the boards mounted to it by screws--the function dial must be transferred to the new board as well as other parts.
Aug 13, 2015 | Whirlpool Dryers
My dinamap is showing error 950 when i hit the inflate start button. what is wrong?
HI From a Tech Guy,
Your issue is caused by motor over current.
Check the pump motor assembly under the foam cover.
remove torx screw on top.remove cover that has two nipples.
check inside mesh filter/ dust filter. if black is dust.
spray contact cleaner and blow with air. let dry.becareful not to use slovents may damage blue mushroom check valve.reassemble all.test should be ok.
hope it helps
cheers
Mar 12, 2012 | General Electric Dinamap ProCare Series...
GE Dryer MOD: BBXR463ED2WW SER: ZH775302A Dryer is getting louder when in use it creams when in use. think it might need a belt? other problem: When I turn the controll settings it goes on without turning...
The roller for the belt tensioner has a bad bearing. replace that item as well as the belt
The start button is stuck to the start position so replace that as well
The top & front panel will need to come off to repair both items
May 23, 2010 | GE DBXR463EDWW Electric Dryer
My washing machine power button has stopped working. Any ideas on how to fix it without having a service technician out to look at it (and charge me $65)?
To fix the power button in the machine is not that much difficult you just remove the top cover of the operational panel just lift the cover and remove the pipe which is connected to the drum then turn the panel you just trace the power cable and find out the power switch and there will be two screw will be present in it kindly remove those screws and fix the power button otherwise there will be holder which hods the power button just release it and replace the power button in the same manner
May 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
The start button on my creda tumble dryer model T630CW doesn't work. How do I remove the front panel to replace it?
You should be able to access the button by removing the top cover.
Please rate my solution.
Thanks.
Nov 21, 2009 | Hotpoint Dryers
Need to reset the soft top on a maserati spyder
Manual roof procedure
The procedure in the manual is just for closing the top.
A) Turn key to OFF for several seconds to bleed off hyd pressure.
B) Turn key to MAR (full electrical, but before start)
C) Remove cap on bulkhead behind the right-hand seat and use flat head screw driver to unfasten the hyd unit valve in order to relieve the oil pressure in the circuit.
D) Remove the cap on the bulkhead behind the left-hand seat and using screwdriver or allen wrench press until the top covering (panel behind roll bars that covers the convertible top well) until the panel's locks are released - you may have to tap the wrench to release the locks.
E) Lift the top covering manually and keep it open while extracting the top from its well.
F) Remove top from well until the front part is near the windshield frame.
G) Lift the rear part of top (rear window) upwards and lower the top covering until the hooks are resting on their respective locks.
H) While still keeping rear part of convertible top lifted upward press Button 1 to attach the top covering locks.
Button 1 is the forward one
Button 2 is the rear one.
I) Make sure locks are fastened. if not - try pushbutton 1 again. If necessary repeat D and H
J) Rest rear part of convertible top on top of covering.
K) At front of convertible top, open (deploy) the top's hooks by using allen wrench to turn the pin mechanism. (located in center of front headliner)
L) Press top unto windshield frame and use wrench to lock the hooks.
M) Press the rear of convertible top, so hooks on rear top insert into respective slots and press Button 2 to secure.
N) Keep Button 2 pressed until hooks properly fasten.
If the top is still tightly latched at the front, you can just start at step "G":
While holding the back of the top in the air, and the "top cover" resting down on its "hooks", press button 1 until it seats well.
Then lower the back of the top down to mate its "hooks" and press it down while holding button 2 until the top seats well.
Sep 10, 2009 | 2002 Maserati Spyder
I need to install a keyboard for a Dell Inspiron 1525. I need step by step directions
Before you begin, Follow these steps carefully;
  1. Shut Down to turn off your computer. Ensure that the computer is off and not in a power management mode. If you cannot shut down the computer using the operating system, press and hold the power button for 4 seconds.
  2. Disconnect your computer and all attached devices from their electrical outlets. Disconnect any telephone or network cables from the computer
  3. Remove any installed cards from the ExpressCard slot.
  4. To help prevent damage to the system board, you must remove the battery from the battery bay before you service the computer. to do this, Turn the computer over, Slide the battery release latch until they click into place. Slide the battery out of the battery bay.
  5. Turn the computer top-side up, open the display, and press the power button to ground the system board. Now you are ready to remove your Keyboard;
  6. Removing the Center Control Cover, Remove the two screws securing the center control cover from the battery bay,
  7. Turn the computer top side up, and open the display as far as it will open.
  8. Insert a plastic scribe into the indent to lift the center control cover on the right side and ease the center control cover up.
  9. Disconnect the cable from the media control buttons connector located underneath the center control cover. NOTICE: To avoid damage to the data cable connected to the system board, ensure that you do not pull hard when you are raising the center control cover. NOTICE: To avoid damage to the center control cover, do not lift the cover on both sides simultaneously.
  10. Remove the center control cover.
  11. Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
  12. Lift the keyboard and hold it up and slightly forward to access to the media control buttons connector.
  13. Disconnect the media control buttons connector and remove the media control buttons cable.
  14. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
  15. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer.
  16. Slide the keyboard cable out of the keyboard connector.
  17. Replacing the Keyboard
    1. Slide the keyboard cable into the keyboard connector.
    2. Rotate the keyboard connector latch to secure the cable.
    3. Align the tabs along the bottom of the keyboard and slide them under the palm rest.
    4. Press on the right edge near the top to snap the keyboard into place.
    5. Replace the two screws on the top of the keyboard.
  18. Replacing the Center Control Cover
    1. Reconnect the media control buttons cable to the connector below the keyboard.
    2. Align the tabs along the bottom of the keyboard and slide them under the palm rest.
    3. Press on the right edge near the top to snap the keyboard into place.
    4. Replace the two screws on the top of the keyboard.
    5. Reconnect the media control buttons connector to the center control cover.
    6. Insert the left edge of the center control cover.
    7. Press from left to right until the cover snaps into place.
    8. In the battery bay, replace the two screws that secure the center control cover.
Apr 17, 2009 | Dell Inspiron 1525 Laptop Jet Black
Cant eject cd
there is a corkscrew in the unit on the right side, you would hav to remove top cover to see it, its an easy fix, the corkscrew is made out to plastic, when it wears done it gets stuck so the unit wont open all the way and the sensor makes it go back up and then down several time, http://www.dualav.com/contact.html you might be able to get replacement parts, its an easy fix
Jul 27, 2008 | Dual XD-7500 CD Player
Right-click button has collapst on bottom side. have to click at top of button
To disable Aspire 5100.
1. remove battery, harddrive.
2. open all cover on the back of laptop.
3. removed wireless antena cable from wireless card.
4. remove power cover (power cover is cover that have power button)
5. removed 2 screws on the back that hold lcd.
6. removed 4 screws that hold lcd. (now you can remove lcd).
7. remove 2 screws on top that hold uppercase from lowercase.
8. remove all screw on the back.
9. remove heat sink, and remove 1 screw under heat sink.
10. that's all, you can remove uppercase and repair it.
i hope this help you. good luck
Mar 22, 2008 | Acer Aspire 5100 Notebook
Aerocool XPredator Black edition black Logo
44 people viewed this question
Top Aerocool Computers & Internet Experts
David Payne
David Payne
Are you an Aerocool Computer and Internet Expert? Answer questions, earn points and help others
