Battery c mos wont keep event has changed with new ones
  • 1,511 Answers
Replace the Cell.
Posted on Jan 20, 2014
Why wont it charge the battery when using the wall plug
Sir,
the charger must be tested, if it not giving the out put voltage, you have to change it, check the connecting point for possible loose contact or corrosion inside the jack.,clean it.
Dec 30, 2015 | Panasonic HC-V100M Digital Camcorder -...
Power supply recently changed now it it reading mos error
Not sure what a MOS error is or what its related to
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Hope it helps.
Jan 03, 2013 | Dell Vostro 410 Desktop Computer
Wont let me do anything looking for f1 to set time and date
first remove the power and check the c mos battery for 3v if the battery have no voltage cange the battery also look for the jumber pins in your motherboard near the c mos battery and bios you will see two pins shorted with an juber move the jumber to the third pin normally the jumber setting are 1 and normal 2and 3 clear c mos
Oct 30, 2011 | Toshiba Computers & Internet
Battery keeps going dead. Have had 3 new altanators & 1 new battery. 5 mechanics has worked on it over the last 12 mos.has cost quit a bit of $. but still same thing. Seems to go down when setting over...
Try disconnecting the battery after you park the car in the evening. If there is a short, then the battery should still be good in the morning. if not, the battery is no good. Most common sources of shorts are the alternator ,or the starter. Good luck You take a voltmeter and take a reading across the battery posts. There should be no power on in the vehicle at all...everything turned off and key in the off position. A normal reading may between 12 and 14 volts. Record this reading in a notebook. Now..go pull a fuse in the fuse box. Just one..and go back and take another reading at the voltmeter. Was there any change? No? Pull another fuse. Now you have two fuses out. Take another reading. At some point...that reading will change. It will show an increased reading. You have just found which circuit is causing the drain. With the drain removed the available battery voltage will go up. just follow the affected curcuit, until you find the drain. if alternator curcuit is ok!! then you should have at least 14.2-14.7 volts at battery when running with everything off. good-day ! and good-luck!
Sep 11, 2011 | Mercury Marquis Cars & Trucks
It no longer keeps time right and the person who sold it to me told me to replace the c-mos battery but I was told its internal and I would need help even though I work on my 5 desktops all the time.
The c-mos battery does need to be changed, the outer casing should have a few screws "remove side panel" and that will expose the large motherboard, now! if you look carefully you will see a round battery that is shaped like a silver coin, remove it carefully and pay attention to the polarity + or - that way no mistakes are made when you install it. ( Before you begin unplug the computer)
Feb 10, 2011 | Computers & Internet
Clock needs to be reset every time I switch on.
There are 3 reasons for that.
  1. Your CMOS battery ran out of charge. You may have to replace it. (Note: You can check whether it has no charge by using a Muti-meter or your mouth).
  2. You are Synchronizing the Clock from a Different Time Zone. Double click on Time panel in the task bar. Go to Time Zones and check. Check the Internet Time to check whether you Synchronize with a proper Time Server. (Note: You can try to start the PC without internet and check whether the time is changing)
  3. You have installed a Patch / Crack to a Software and it resets your Timer. Probably a Patch to an Anti Virus Software, Game or any other Application. You may have to Remove it to keep the clock Steady if it matters you.
If anything gives negative results what you have to do is to check the Event Viewer for any System/ Application related errors. To get the Event Viewer: Start -> Run (or hit Win key + R) and type in Eventvwr.msc and hit Enter key. Go to System and Application and Sort them using Date / Time (usually it is the default). Then watch for errors related with the System Clock. (Note: errors are in the color of Red with an X mark. Warnings are Yellow with an ! mark). If you are unable to understand let me know. You can Copy and Paste Here.
Please feel free to contact further. Please rate the answer if this solution helped you to solve the issue with a Testimonial.
Thanks for contacting Fixya!
Jun 08, 2010 | Compaq Presario SR1000T (568657) PC...
My Mobile Mouse 3000 is about 6 mos old- put in
do you still see any light indicator activity on the mouse itself? if none, even if you already change the batteries, then it needs replacement
Apr 09, 2010 | Microsoft Wireless Mobile Mouse 3000
My dell inspiron 8500 wont start up whit the battery
if it is the original battery, it most likely needs replacement. Portable batteries have a expected life of 300 to 500 recharge cycles (18 to 24 mos) If a new battery does not charge, then a motherboard replacement is warranted.
Oct 01, 2009 | Dell Inspiron 8500 Notebook
Moultrie I60 battery life.
extreme hot/cold effects battery life...also # events, whether pics taken or not 2 million gray Ark. squirrels, that never stop moving like red squirrels will use up batteries in a hurry...even still I get 3-4 mos out of 6-dcells on my I-40s
Nov 14, 2008 | Moultrie MFH-DGS-200 Digital Camera
Time or Clock changes
check with antivirus software. same problem came again battery only problem!
Jul 01, 2008 | IBM ThinkPad T43 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
