Question about Nikon D100 Digital Camera
Shutter count - Nikon D100 Digital Camera
Why does my Cannon 600D Shutter stays open and doesn't work
maybee you are shooting the camera at very low shutter speed try to check the shutter speed first . if this does not resolve the problem you may need to drop the camera and the nearest service center and have you curtain checked . you might have reached the maximum shutter count and this needs replacment
May 03, 2014 | Cannon Cameras
How to reset shutter count on nikon dslr
Why do you want to reset the shutter count? Are you trying to put one over on a buyer? The shutter count is set to zero at the factory in the camera's firmware. Unless you have access to Nikon's program and the knowledge and equipment to flash it to new ROM (Read Only Memory), you are out of luck.
May 25, 2012 | Nikon D50 Digital Camera
My canon 50d squeals when shuter is released
The shutter is a moving part. It is also made up of several plastic leafs that rub together when opening and closing. Lift the mirror to see if any of them are damaged. You will have to fire the shutter each time before you look as there are 2 sets of shutter leafs. 1 set at the top and 1 set at the bottom firing in rotation. 1 set is of 4 and 1 set is of 2 leafs. also check the action of the mirror. Both are run from the same motor and both have springs to help operation. metal on plastic tends to wear so how many shots have been fired? To check shutter count look up astrojargon and download the EOSinfo software (free) and plug your camera in to your pc. Should give you a shutter count.
May 11, 2012 | Canon EOS 50D Digital Camera
HOW DO I CHECK SHUTTER COUNT WITH MY NIKON D-90
I think you mean shutter speed. If this is the case, there are two spinning dials on the camera. When the camera is set in manual mode, one will opperate the F Stop or appature. The other will operate shutter speed.
The f stop numbers will look like this:
1.0 1.2 1.4 1.7 2 2.4 2.8 3.3 4 4.8 5.6 6.7 8 9.5 11 13 16 19 22
The shutter speeds will look like this:
  • 1/1000 s
  • 1/500 s
  • 1/250 s
  • 1/125 s
  • 1/60 s
  • 1/30 s
  • 1/15 s
  • 1/8 s
  • 1/4 s
  • 1/2 s
  • 1 s
May 07, 2011 | Nikon Cameras
Cannon EOS500D, taking a picture in creative modes I have to press the shutter button twice to take a picture.(not counting the half pressing of the shutter button. the second pressing of the shutter...
Hi kevinmullen8 - was this ever resolved? My mum was mucking around with my camera (eos1000d) and I have the exact same problem (press shutter twice in creative mode). Factory reset was of no assistance.
Please help!!!
Dec 05, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
D8o's shutter count up to end.. where i can fix it in the phils
Hi lixia_pogs, if you are speaking about the 10,000 number the camera count, on obtaining 10,000 it will flip over then again starts at 1. Your camera will continue to work as it always has. Hope this is what you were looking for
May 28, 2010 | Nikon D80 Digital Camera with 18-135mm...
D80 LCD not responding and Focusing Issue
If you were not half-pressing the shutter button when you turned on the camera, then you may need to have this problem serviced.
LCD being unresponsive also seems like a servicing type problem.
I don't think your shutter count of 5000 is an issue as I know a lot of people with more shutter counts who do not face this issue. Its likely that the cam was dropped or exposed to the elements so it needs to be serviced
Oct 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
Canon EOS 20D shutter error
Hello - I figured it out. I had the exact same problem. The shutter failed and it had to be fixed by Canon. Apparently that happens after the shutter fires so many times (like a click-count on a printer). I just got my camera back and it's doing awesome now.
Feb 19, 2009 | Canon EOS-20D Digital Camera
Digimax 4500 shutter response
Unfortunately, delayed shutter response happens on some digital cameras.
Sep 10, 2017 | Samsung Digimax 4500 Digital Camera
Nikon D100 Digital Camera Logo
16 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
