Question about HP LaserJet Office Equipment & Supplies
Hello, I have HP LaserJet Pro P1606dn. By
Hello, I have HP LaserJet Pro P1606dn. By default the type of paper is Letter ant I changed it to A4 but in the print properties is still show me that the available paper is Letter. In the web interface of the printer is show me that the default paper type is A4. I want it to show me the A4 not Letter
mickspaceNET
  • 115 Answers
SOURCE: my hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Posted on Oct 23, 2008
  • 85 Answers
SOURCE: HP Laserjet 3050, need to press ok each time printing
did it work before? check paper size for trays - suspect it is set for a4, change to letter size
Posted on Mar 13, 2009
the_fire
  • 432 Answers
SOURCE: HP Laserjet 5000dn
if you using office go to page setup and select the tray(s) that you want to use for the first page and other pages ( both must be the same ) unless you only want the first page as letter head and the rest on plain paper or something along those lines ?
Also if you go into the properties of the printer and go to advanced and then click on the printing defaults button and see if the options in there are the same or different to whats in printing preferences.
If they are set to tray 1 then it will default to tray 1
Posted on Apr 13, 2009
  • 121 Answers
SOURCE: Paper default keeps changing
you have to uninstall the program and reinstall all the drivers again.
Posted on Jun 19, 2009
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
MY hp laserjet 200 color m251 pcl 6 do not print full copy of A4 when printing via internet or wireless pls, i need a setting to make it print full copy . thank you.
I would check to ensure that the page size of both the driver and the printer are set to A4 and not letter. Most HP's will auto sub letter for A4 but if driver thinks paper is letter when it is actually A4 then the printout will not match.
Sep 16, 2016 | HP Color LaserJet Pro 200 M251nw
Hp laserjet P1606dn network adapter: no green
is it red... if no colour the wifi card has either come loose or not working any more.
Nov 03, 2013 | HEWLETT-PACKARD LASERJET PRO P1606DN...
Always showing the manual feed option when we printing. We would like to set it as automatic printing. How can we do that in default. Please help. We checked all the menus. example: in system set up paper...
If you are in Canada or US then you need to set the default paper size to Letter not A4. Most if not all software you use likely sends the print job in letter format. Because the printer is set in A4 it stops and waits for that size.
Mar 11, 2011 | HP LaserJet 3050 All-In-One Printer
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
My hp laserjet 4015n is very slow whiles printing after changing the setting to factory default
You need to set your paper tray correctly. If you are using Letter, make sure the tray is set to Letter, and if you are using A4, set the tray to A4.
"Any" is NOT a valid choice. You have to set the correct SIZE.
You will olso have to configure your driver correctly. Make sure the driver up to match your printers paper settings.
Good Luck.
Dec 15, 2009 | HP LaserJet P4015N Printer
How do I change the default paper size from Letter to A4 in my HP Officejet Pro 8500 Wireless?
Don't set by using the "Print" option.
Go to [Start]
[Printers and Faxes]
right-click on the HP Printer entry
! Don't select "Printing Preferences"! from there
Select [properties]
Select [Advanced] tab
Select [Printing Defaults]
[Advanced}
(I know, the screen looks the same, but it functions differently this way)
Change paper size to "Letter"
[OK, OK, OK]
*done*
Sep 25, 2009 | Office Equipment & Supplies
Whenever i change paper size from A4 to letter,
Go to [Start]
right-click on the HP printer entry
Select [properties]
[Advanced}
[OK, OK, OK]
*done*
Sep 25, 2009 | HP LaserJet 4350 Printer
Jun 19, 2009 | HP LaserJet 4000 Printer
Pc load letter
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
May 28, 2009 | HP LaserJet 4 plus Printer
Mar 12, 2009 | HP LaserJet 3050 All-In-One Printer
Seeker5211
Seeker5211
