Question about Ovens
Electrolux double wall oven model EW30EW65GSA powers on but cannot use controls
Powerman
  • 68 Answers
SOURCE: ge double wall oven repair
You need to tell us the model number. I can then give you specific information.
Posted on Nov 18, 2007
  • 905 Answers
SOURCE: I have an electrolux icon
yes, if the humming is not the loud sound then the fan may need some lubrication or if it is tripping the circuit it will need replacing , but if it seems like it is a viberating noise from the fan , then it could be that its bearings are bad , but the whole fan motor would still need to be replaced , but if it sounds like it just may be a loose fan motor , then tightening up the screws on the motor would stop the vibrating sound and or the fan blades from scraping metal( another sound you may be hearing )
Posted on Dec 24, 2008
barkencoa
  • 3463 Answers
SOURCE: Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Posted on Jan 11, 2009
  • 212 Answers
SOURCE: Main oven doesnt heat up. But temp light is on.
replace heating element
Posted on Jun 22, 2009
SOURCE: how to remove the control panel on Whirlpool double oven Model RBD305PDS14
Emge & Associates is investigating gas and electric ovens manufactured by Whirlpool, including such popular brands as Whirlpool, Jenn-Air, KitchenAid and Maytag.
The firm is investigating reports that the electronic control panel on certain models is subject to failure after a limited number of uses of the appliance’s “self-cleaning” setting. While most foods are cooked at temperatures reaching 375 degrees, the “self-cleaning” setting raises the interior oven temperature to 1,400 degrees. Due to defects in the design and or manufacturing, the electronics contained on many ranges are damaged by extremely high heat. Repairs to damaged control panels typically cost in excess of $300 per replacement.
If you have experienced failure of the control panel in your range after using the “self-cleaning” setting, you can join this investigation by contacting Emge & Associates at (800) 629-3409 or (619) 618-2974.
Posted on Dec 19, 2009
The top oven is over-heating with no change in temp display. A red-hot heating element on the left side of the oven (facing it) shows through the floor of the oven.
Good Morning Eileen, thank you for your inquiry!
I understand that your Electrolux double wall oven is having over heating issues. It is possible that this could be a faulty thermostat, control panel, or element. Since it could be anyone of these underlying having a technician out would help avoid any unnecessary part purchases. If you need help locating a technician you can visit your manufacturer's website for additional assistance with locating a technician. I hope this information is helpful to you. -Matt
Aug 09, 2015 | Electrolux 27" Built-In Double Electric...
Eecrolux combination wall oven / microwave is in demo mode model# ew30mc65jb
Good Morning Rolf, thanks for your post!
Based off the information you have provided your Electrolux wall oven/microwave combination is stuck in demo mode. The best way to remove demo mode from your wall oven/microwave combo is to hold the oven light button and the on/off keys at the same time and you should be able to toggle in and out of demo mode. Hopefully this is helpful. -Matt
Mar 09, 2015 | Electrolux 30" Built-In Double Electric...
Top part of oven not heating up
Thank you for your post, friend!
Based off what you have described your Electrolux double wall oven is not heating up inside the top portion. It could be a miscommunication within your oven and you can usually perform a reset to clear that out. In order to reset your oven you would need to flip the household circuit breaker off for roughly ten minutes. If you restore power and continue you having an issue with your oven I would suggest you could have a possible fault with the control panel, thermostat, element, or connectors. Typically, this is not a simple DIY job. You may need to look for assistance with replacing any electrical components and I would highly suggest having a professional technician help with that. Hope this is helpful. -Matt
Feb 23, 2015 | Electrolux 30" Built-In Double Electric...
Hi, I have a double oven electrolux icon model number e30ew8cgps6. I would like to tighten the handle but only see one screw on the right side and the are three plastic covers remaining and its but the...
Thank you for your post, Karen!
Typically the door of your Electrolux Icon wall oven has a lot of layers. Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the replacement part is installed correctly to prevent future issues. I hope this information helps to some degree. -Matt
Oct 19, 2014 | Electrolux ICON 30 in. Double Wall Oven
I'm getting a f24 code on my lower wall oven...what to do?
Hi. Error code F24 indicates that the controller has failed to communicate with the lower convection fan and oven lights control board. If the error code persists, I would recommend connecting with an expert repair tech to assist further and the display board may need replacing.
Sep 26, 2014 | Electrolux ICON 30 in. Double Wall Oven
Electrolux oven racks how do they go in oven?
Hi Friend, that's a great question!
I see that your post is listed under Electrolux Wall-Oven. May I have your model number please? You can normally find the serial tag (which lists your model number) on the front of the oven, on the left side, as you open the door. With this material I can provide you the correct instructions on how to place the racks in your Electrolux wall-oven. Thank you! - Z
Jul 20, 2014 | Electrolux 30" Built-In Double Electric...
Oven will not cut off
While it is under warranty, have them look at it. It sounds like a mal function of the control board. Let them fix it for free.
Jan 29, 2009 | Electrolux ICON 30 in. Double Wall Oven
Glass
glass is glass. wouldn't say its normal but not an unheard of complaint, YOu purchased an ICON, id call the manufacture, wouldnt be suprised if htey took care of that for you! thats their pride and joy!!!!!
Feb 27, 2008 | Electrolux ICON 30 in. Double Wall Oven
Ovens Logo
44 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
