Question about Reliance & 40 Gal Electric Mobile Home Water Heater
I want to check thermostat type R-7 of Bajaj majesty water heater
The power button wont come on to heat
Troubleshooting a Tank-Type Water Heater That Won't Start ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
Whether your water heater runs on gas or electricity, it needs a controller to cycle theheat on and off, or the water in the tank would either be stone cold or ... If the buttongoes in and stays in, the thermostat should start working again. ... Screw in a new element, reconnect the wires, refill the tank and turn the power back on.
Troubleshooting Electric Water Heaters in MINUTES ~ Step ...
? 7:01
https://www.youtube.com/watch?v=SlyStHM9Nr0
Oct 4, 2013 - Uploaded by electronicsNmore
AFTER you establish that there is power being supplied to thewater heater .... When the water is cold in the tank the top element will come on first, heating the ... is overly hot and then notice no hot water check the reset button.
Tanklets: Electric water heater problems
Jan 25, 2016 | Water Heaters
How can I reset a water heater that overheated?
There is only one reason a water heater will overheat and that is a faulty thermostat.
It is the thermostat that allows the temperature to rise to a preset or selectable temperature, depending on the type, and when the correct temperature is reached the thermostat will switch off the supply to the element.
The most common type of thermostat is the traditional bi-metal type which has proved long-lasting and reliable but electronics have moved in to this field adding expense and complications.
Whichever type is fitted to your heater, in any case of overheating the thermostat should be replaced or in the case of an electronic thermostat it should be repaired and calibrated.
Jan 24, 2016 | Water Water Heaters
Water temp stays at 160 degrees
Specific type of water heater does not show on web search.
I am guessing you have tank-type electric water heater.
Did you replace both thermostats and test elements?
Element could be cracked, thermostats can stick open, upper thermostat wired incorrectly, wire shorted.
We know that electric power to water heater is good, and circuit breaker is good.
Why is eco is not tripping? Why is TP valve is not leaking?
Copy following links for step-by-step:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Jul 21, 2012 | Rheem Water Heaters
Water gets to hot even when turned down all the way thus opening pressure release valve
I can get you started but might need more information.
Do you have tank-type electric or gas water heater?
Or indirect heater, or boiler, or tankless, or condensing, or under-counter?
If you have ordinary tank-type electric water heater, the thermostat is probably bad.
Replace thermostat(s)
If you have ordinary tank-type gas water heater, then thermostat can be bad, and thermostat is located on the gas control valve
http://waterheatertimer.org/images/Typical-gas-valve-300.jpg
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 25, 2011 | RELIANCE ELECTRIC WATER HEATER
Hot water system is not working- producing cold water. could it be a thermostat or is it to be replaced?? not sure how old but would guess 10 yrs +
Resourceful do-it-yourselfer can add a comment with type, make and model number of product for best answer.
1) Open following link if you have electric tank-type water heater, for tested, full service do-it-yourself diagnosis.
Open top cover and push in ECO reset button:
http://waterheatertimer.org/images/Jly-022-thermostat2-175.jpg
Find age of water heater using serial number located on label on side of tank:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
2) If you have tank-type gas water heater, thermostat is connected to gas valve, but you might have question about gas flame instead of thermostat.
Check manual, check flame, buy new gas valve at local home center.
Following link shows typical gas valve with brass thermostat:
http://waterheatertimer.org/images/316938_603.jpg
3) If you have tankless electric or gas, the problem can be varied from internal to external causes.
Check manual, call service technician.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 13, 2011 | Water Heaters
I have a Rheem model number is 81V52D and I think I need to check the thermostat. Do I need to drain the unit in order to check the thermostat?
No you do not need to drain water heater when checking or replacing thermostats:
Water heater is drained when replacing elements or cleaning sediment out of tank.
Also look at following links: These links can teach you everything about fixing ordinary tank-type electric water heater using generic parts from hardware store.
http://waterheatertimer.org/How-electric-water-heater-works.html
http://waterheatertimer.org/How-to-replace-element-and-clean-sediment-out-of-electric-water-heater.html
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 20, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
It has cold water comign out no hot
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Jan 18, 2011 | RELIANCE ELECTRIC WATER HEATER
Reliance & 40 Gal Electric Mobile Home Water Heater  Logo
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
