Sansui au 317 amplifier giving very low sound when turned to full volume
5 Suggested Answers
jerryg50
  • 1667 Answers
SOURCE: I have a Sansui AU-717
This company is not like they used to be. You can try the links below to see if you can find authorized service for your set.
Sansui:
http://www.sansui-india.com/
http://www.classicsansui.net/
Historic information about Sansui:
http://en.wikipedia.org/wiki/Sansui
I would personaly suggest to find a service center or a very good local tech who can do audio amplifier and reciever service.
Jerry G.
Posted on Apr 13, 2008
robotek
  • 1512 Answers
SOURCE: I own a classic Sansui
Hi mellemcee
Cool amp mate, and becoming collectable now to. Sansui amps from the era where the best in the world of HiFi. iT may have lost bias control to the offending channel, it may have dirty source switches, tape monitor switch, or even speaker switching. The speaker protection relay may also have a dirty contact, will usually burst back into life with a quick rotation of the vol control. Can you pin the problem down a little more with the info i have given you, try all the controls to see if it impacts on operations, you will need to fix those problems first. Low bias would make that channel sound distorted at low levels also. Is this what is happening to you??
regards
Graeme
Posted on Apr 18, 2008
robotek
  • 1512 Answers
SOURCE: My Marantz PM-32 Amplifier has
Hi
First thing to check is to see if someone has turned on the Tape Monitor has been turned on by someone. The symptoms you describe certainly sound like it. Check that out and get back to me if it does not solve the problem
regards
robotek
Posted on Nov 08, 2008
  • 21 Answers
SOURCE: sansui au-G90x integrated amplifier connetcted
Dirth control switches and/or dirty/corroded/worn-out speaker relay.
Posted on Sep 03, 2009
The sound output is very low even using earphones can the audio output be upgraded to give a normal listening level.
Probably not without using separate amplified speakers. Check the mixer levels are set correctly.
Apr 02, 2016 | Computers & Internet
VERY LOW VOLUME
Replace the speakers.
Jun 09, 2015 | Sansui 32" TV
Looking for an owner's manual for the Sansui Integrated Amplipier AU-D9.
Hi info851163...
Go to the following website and register to download your Owners/User Manual for your Sansui Intergrated Amplipier AU-D9.
Please take time to rate me thumbs up
http://www.hifiengine.com/manuals/sansui/au-d9.shtml
Also at this website...for $6.92 Canadian Dollar:
http://www.ioffer.com/i/Sansui-AU-D9-amplifier-Service-manual-79410631
Sep 15, 2011 | Audio Players & Recorders
Hi I have a Sansui Amplifier model AU-519 and the volume of this goes of quite often...only resumes when the volume knob is rotated anticlockwise and clockwise several times....is there a fix / solution to...
Sounds like it could be one of two things, either a bad soldering joint, weakend with time! Or dirt in the track of the control. This can be cleaned with Servisol Switch Cleaner (such as Video 40).
Aug 27, 2010 | Audio Players & Recorders
Sansui AU-X410R Amp, at power on, lights on but no sound (surge protection click doesn't occur). Sometimes powers off for no apparent reason.
One thing you could look at is that thing that makes the click, it could be a relay and they do go wacky sometimes (hence why it shuts down). If you are lucky it will tell you (on the relay) everything you need to replace it.
Jun 11, 2010 | Audio Players & Recorders
Sansui AU-7500 volume control problem - need replacement
Hi...
Is that the fancy pot with more than 6 leads..kinda square looking?
This place has some.
http://angela.com/
Rate my help if this helps...Thanks
Mar 11, 2010 | Audio Players & Recorders
Sound
Set your SAT receiver to full volume and use your Sony TV volume control as the master volume control. If you use an external surround sound amplifier do the same thing using the amplifiers volume control as the master volume control.
Consider that all source devices that have the ability to control their output volume will output what they call line level 0dB when the source device is set for maximum volume. If you set the source device to 1/4 volume your output to the amplifier may be around -25dB or lower. Introduce that low of an audio level to the amp and you will have to turn the amp up to half way or better causing the amp to amplify noise too.
Jul 04, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I own a classic Sansui intergrated amplifier (AU-717). It has a short in one channel. At low volume, the sound shorts out. I've had this unit for about 20 years now. Otherwise, it's a great product!
Hi mellemcee
regards
Graeme
Apr 18, 2008 | Audio Players & Recorders
44 people viewed this question
 Grubhead
Grubhead
