Question about Bernina artista 200
How to turn off bobbin sensor - Bernina artista 200
Bobbin thread low, have lost the message which indicates the bobbin needs to be changed?
Make sure there is no dust or lint in the way of the sensor. Any lint there will stop the sensor from advising you that the bobbin needs to be replaced.
May 09, 2016 | PfaFF Sewing Machines
While embroidering, the bobbin sensor message comes on alerting me to low bobbin thread. I'm using a prewound bobbin.
perhaps dust on the sensor . personally I dislike all these new fancy machines as they seem to fail where my old ones just keep on doing their jobs .
Aug 28, 2015 | Sewing Machines
How to Turn Off the Bobbin Sensor in the Bernina Artista 640
make sure you're using the appropriate bernina bobbin, others can confuse the sensor. This video(by Bernina Boys) shows how to clean lint to prevent this problem which is what often causes this error. Or go into settings by pressing the diamond with right hand arrow inside of it. The eye with the speaker next to it should get you where you need to go to turn it off.
The manual on Bernina's website is here:
https://www.bernina.com/en-US/SupportData/BERNINA-Nah-und-Stickmaschinen/artista/Manuals/031508-50-04_0601_a640_EN
page 98 has the information you want.
Jan 22, 2015 | Bernina Sewing Machines
Bobbin sensor on 730 keeps coming on but bobbin door is closed and the bobbin area is clean. Why?
could be a problem with the motherboard, sensor could be going back, also check to make sure the bobbin is inserted correctly.
Dec 08, 2014 | Sewing Machines
Husqvarna mega quilter
Each machine is different. Most of the machines that are electronic have a sensor to shut it off if you place the bobbin on the winder and push the winder into its position to wind. Give it a try. Also, check your spindle at the end to pull it outwards or attempt to untighten like you do a jar. This is the old mechanical machine but it is possible this machine uses it. Next you must look on your monitor for a particular symbol that represents the bobbin. This would likely be a button to turn it off and on.
Apr 26, 2014 | Sewing Machines
Does not recognize when bobbin thread has run out
Clean out the bobbin area. Try to determine where you sensor is and used canned air to clean that. Hopefully it's just a dirty sensor and not a bad one.
Good luck
Sep 08, 2012 | PfaFF Sewing Machines
Babylock espire bobbin sensor not working
This is normally caused by lint in the bobbin area, the lint blocks the sensor causing it to be blind. Try cleaning the area and see if that helps.
May 28, 2010 | Yamata FY101-1A
Can you tell me what the bobbin image on the artista 640 means? It will only sew for a few stitches and then stop
Hi, most likely your bobbin sensor is being blocked by something. Common causes are a dirty sensor. Q-tip on the eye of the sensor inside the bobbin door. Or there is fuzz blocking it. Next take out the bobbincase and the bobbin. Look in the bobbincase and you will see a round spring. This spring acts like a brake for the bobbin. Sometimes these springs will get moved and out of position blocking the little space that the bobbin sensor reads through. Reposition the spring so you can see through it and the bobbincase.
That should do it.
Good luck.
Rick Engel
Bernina tech
Mar 02, 2010 | Bernina Artista 180
I have a Bernina Artista 730. Very few inches of
I know this is a long-overdue response, but maybe it will help someone else. I had the same problem, and it turned out that the cause was that my bobbins had oxidized. Rubbing them with a bit of steel wool or fine-grain sandpaper did the trick, and I was up and running again.
Oct 07, 2009 | Bernina Sewing Machines
Not being notified when the bottom bobbin thread is running out
There is a light sensor that "shines" through the bobbin and lets the computer know when your low on thread. If you were looking straight down on the bobbin it's beam runs from the 10 O'clock positoin to the 5 O'clock positoin straight through the bobbin. Sometimes lint gets in the way of the sensor on the left side.(the 10 O'clock side) Take out your bobbin case, turn the handwheel until the opening on the spinning thread hook in the machine exposes the 10 O'clock positoin and using a can of air or a compressor, blast that area to knock the lint out of the sensor. The sensor is located below the gray plastic housing to the left of your bobbin area. You won't be able to see it but you can see a slightly raised area in the plastic that covers it if you inspect the area. You have to tilt the machine back and look under the gray bed to see the "updent" in the plastic. Blow out that area for your best chance. Other than that It could be a number of adjustments and even a bad sensor. Good Luck
May 21, 2009 | Husqvarna Sewing Machines
Computers & Internet Logo
43 people viewed this question
Top Bernina Computers & Internet Experts
justwinwin
Jim Goldsmith
Jim Goldsmith
Du?an Zima
Du?an Zima
Level 1 Expert
Are you a Bernina Computer and Internet Expert? Answer questions, earn points and help others
